JASDF E-767 AWACS
    May 2011
JASDF E-767 AWACS
Posted by Real G on Wednesday, September 25, 2019 6:07 PM
Just in from jolly olde England (Hannants), is a conversion kit from Cut then Add (CtA), which turns a stock B-767-200 into an AWACS operated by the Japan Air Self Defense Force.  The set is very complete, with resin parts for the all-important rotodome, its support struts, various sundry detail bits, and a decal sheet.
The recommened base kit is Zvezda's 1/144 B-767-300, which requires shortening to the -200 configuration.  The nice color instructions clearly show how to do this, plus gives color/marking information.
1/144 aircraft are not my usual fare, but I took a fancy to the E-767 after seeing it in a book.  I figured there never would be a kit of the type, but never say never in the 21st century!
Now to wait for the B-767 to arrive...
“Ya ya ya, unicorn papoi!”
    August 2005
Posted by Phil_H on Wednesday, September 25, 2019 7:44 PM
That looks pretty cool. When you've finished that, you can build a "baby brother" 737 based Wedgetail to display beside it. Smile
    May 2011
Posted by Real G on Wednesday, September 25, 2019 8:01 PM
And has the US decided to go with the 767 for their next gen tanker?  Maybe the next US AWACS will be based on the 767 as well, given advances in compact electronics and automation.
And speaking of the 737, there is no injected plastic 1/144 P-8 Poseidon yet.
    May 2013
Posted by Greg on Thursday, September 26, 2019 10:30 AM
Wasn't aware of CtA. That looks pretty neat.
    April 2015
Posted by Mopar Madness on Thursday, September 26, 2019 10:42 AM
I've never heard of CtA. I'd like to see how this turns out.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    May 2011
Posted by Real G on Thursday, September 26, 2019 11:22 AM
Zey are flom Russia.  (And you have to read that, like in Russian!)
I think the rotodome was copied from the Minicraft E-3 kit, as the halves are very thin and have locator pins and sockets.  If someone were to make aftermarket decals for the E-767, you could do the conversion using the Minicraft kit.  But it would be more expensive, and you’d have to make your own tailcone mods, air scoop and wingtip antennae!
BTW, my Wiki-Fu tells me that only 4 aircraft were procured by the JASDF, so an aftermarket decal company could do all of them on one sheet.
I don’t know about everyone else, but I have always thought JASDF aircraft to be attractive.  Maybe because they keep them so clean; something embedded in the cultural mindset maybe. I was made in the USA with parts from Japan, so I got this drilled into me while growing up!
    May 2011
Posted by Real G on Monday, October 7, 2019 1:02 PM
I was a little down this weekend (went to a model estate sale of a club member), so I wanted to cut some plastic.  I tracked down a Zvezda 767 from Latvia of all places, but for $24 it was the best deal around.
Man, I really have to practice my razor saw-fu.  The other side will be neater.  Pinkie promise.
    March 2007
Posted by armornut on Monday, October 7, 2019 1:09 PM
Nothing alittle putty, glue , and elbow grease won't fixBig Smile
     I have a mind to put one of my 747s under the knife to create SOFIA a NASA research aircraft that carries a telescope to very high altitudes for cosmic research. I got to work on a throttle quadrant from one awhile back so technically.....I worked for NASA. I plan on using a 1/200 747-200, it has a shorter bump on top.
we're modelers it's what we do
    May 2011
Posted by Real G on Monday, October 7, 2019 1:39 PM
Armornut,
Is SOFIA based on a 747SP?  If so, hold that knife!  Eastern Express announced an injection molded SP in 1/144.  IIRC the FSM article that converted a standard 747 to the SP version was quite involved (simplified flaps and larger stabilizers among other things)  Can you source an aftermarket decal sheet?  That sounds like a cool project!
And to fulfill my role as the Model Devil, NASA also operated a C-141A with a telescope.  And Caracal Decals has markings for it!  You have to shorten and modify the Roden kit, which is a stretched "B" model, and make the sliding cover and fairing, but hey you'll have a unique model!  ...aaaand if the decal sheet is OOS, I have one that I can give you.  Devil
Ha-ha.  A-ha-ha-ha.  Mwu-ha-ha-ha-ha-ha!
Posted by keavdog on Monday, October 7, 2019 3:32 PM
Cool project
Thanks,
John
    March 2007
Posted by armornut on Monday, October 7, 2019 4:53 PM
 Yessir it is, the telescope is mounted inside the fusalage aft of the wings with a roll up type door. I figured the hardest part would be re-creating the pressure dome forward of the telescope....mmmm, might talk to ya about the other project.
   With as much as I think I know about airplanes, thete is so much more I don't know lol. Thanks for the info, I will hold short for an actual SP.
    May 2011
Posted by Real G on Monday, October 7, 2019 9:56 PM
    May 2011
Posted by Real G on Tuesday, October 8, 2019 6:04 PM
Chop chop!
Ooh, I made some crooked cuts!  No peeking until I have them patched up.
BTW Armornut, the C-141 decal sheet is sold out, but I would be more than happy to give you the markings for the NASA version.  I can also scan you the instructions.  LMK if you want them!
    May 2011
Posted by Real G on Monday, October 21, 2019 6:04 PM
I glued in the windows to fill the openings and added some plastic strip to help secure the cut sections of fuselage.
For some odd reason the fuselage cuts on the second half fared worse than the first.  I could have sworn the guide line tapes were straight.  Well afterwards, I swore when I saw they weren't.
Not a huge deal, some strip filler will fix it.  Still have to replace the kit's tail cone and decide what to do about the empty cockpit.
    May 2011
Posted by Real G on Tuesday, October 22, 2019 1:09 PM
I lopped off the kit's tail cone and test fit the resin replacement.  Heh-heh, I KNOW that most resin inserts exhibit some shrinkage, but I cut pretty much up to the recommended cut line and... dun-dun-dun...the resin part is a skootch smaller all around.
It's not insurmountable though - the fuselage could be shimmed and tucked.  Or a sheet plastic spacer could be added to the cut face of the fuselage.
I only now realized the fuelage around the cockpit area is not circular.  Nuts, now I have to fake a bulkhead and floor.  I should have taken a contour gauge to the fuselage prior to closing up the nose!
    July 2014
Posted by modelcrazy on Tuesday, October 22, 2019 1:41 PM
Excelent, G Yes
Steve
    February 2005
Posted by RadMax8 on Wednesday, October 23, 2019 3:10 PM
Hey G, given that you're working in 1/144 scale, could you just fake the cockpit with a decal, or paint what you have a dark color? I know a lot of those kits have issues in the cockpit area.
    May 2011
Posted by Real G on Wednesday, October 23, 2019 3:38 PM
I have seen airliner window decals with people in them, and they look pretty effective.  The pilots can look weird if you look at more than one window pane at a time though.
Being lazy, I might just make a fake instrument shroud and “popsicle stick” seats.  I have a resin one piece cockpit for the Zvezda 787, and aside from no control yokes, it’s nice.
    February 2005
Posted by RadMax8 on Friday, October 25, 2019 6:44 PM
Hmm I feel like that's a pretty important feature of the cockpit!
I'm sure whatever You come up with will look great on this kit. I've seen a lot of 1/144 airliners lately, kinda getting the itch to do one myself.
    November 2019
Posted by Cut then Add on Friday, November 29, 2019 2:14 PM
Hi!
You're right, I'm really from Russian Federation.
I'm glad to see someone building this kit. If interested, here is my build thread
Also, rotodome was designed in 3D, like all other parts.
CTA 1/144 E-767 AWACSCTA 1/144 E-767 AWACS
    May 2011
Posted by Real G on Monday, December 2, 2019 5:00 PM
WOW, you did the conversion set because you wanted one?  Holy cow, the level of finish is like a kit from one of the big boys!  Well done!  I had a look at your build and I agree a PE set for the antenna farm would be helpful.
I hope my kit turns out as well as yours.  One thing I was thinking of trying is to use a mask and paint in the faint window marks.  The way I cut the fuselage disrupted the position of the windows, so I'm going to fill them in and sand the fuselage smooth.  I'll use a slightly lightened base color.
    November 2019
Posted by Cut then Add on Friday, December 6, 2019 1:40 PM
Usually, this is exactly what happens. I want something (which is not in nature) and do it. Then, sometimes conversion sets come out of it. Fuselage windows can be drawn in a graphical editor, then printed on decal paper (with all-over base clear coat) using a printer.
