Allison 501 turboprop - Completed!
Posted by Don Stauffer on Wednesday, June 10, 2020 12:56 PM
Recently picked up the Atlantis repop of the old Revell Allison turboprop engine.  I love to build engine models, and this is a neat kit.  While very old, so am I, so I figured I could handle a kit from about 1960.  It has some flash but not that much.  To get the compressor section, however, any rotor disks must be trimmed carefully or you will not be able to get the rotor into the compressor case.
I  do not plan to operate the finished model, and felt the prop reduction gears were not that interesting, so didn't add them.  Here is the gearbox with the door glued in place and gaps filled, ready for finish paint (subsequently painted.)
The instruction color callouts are for a "exploded view" display, so I plan to find out as much as possible to finish it in more appropriate colors.  I am planning on using a lot of Alclad.
Trying a new Alclad color call high gloss aluminum.  I didn't want a perfect mirror finish, but still shiny stainless steel color.  Since I wanted a slight blue tinge to it, I tried it directly on the plastic.  The blue base did not come through- this stuff is thicker than the other metallic colors and worked fine.
    May 2011
Posted by Real G on Wednesday, June 10, 2020 1:02 PM
Looking great Don!  I think it's neat that we can build kits from yesteryear from fresh boxes!  That gloss aluminum looks fabulous.
Now build three more and add a C-130 Hercules to display them on.  Stick out tongue
“Ya ya ya, unicorn papoi!”
    July 2014
Posted by modelcrazy on Wednesday, June 10, 2020 1:03 PM
Well excelent Don.
Looking forward to another beauty Don engine
Steve
    July 2008
Posted by jeffpez on Thursday, June 11, 2020 6:34 AM
I first built this kit when I was 12 or so and always remembered it because of the variable pitch propellers. When I saw that Atlantis had reissued it I grabbed one and it's now sitting in front of me as I type this. Each section of the engine rotates as it should but combined I'm unable to get it to work so I probably needed to shave a bit more off the turbine blades. The only part that works flawlessly is the prop and reduction gears. Once you think you've got things fitting well take a little bit more off just to play it safe. I really like the color you chose for inside the engine. The instructions call for some sections to be orange and I only had some Tamiya orange. It looks just like the molded plastic before painting and I wish I hadn't used it.
    March 2015
Posted by JohnnyK on Thursday, June 11, 2020 1:26 PM
That looks like a really fun build.
    September 2012
Posted by GMorrison on Thursday, June 11, 2020 1:36 PM
These things, in particular the V8; were notorius for not really working. Look forward to seeing it done.
Yes, that scale Hercules will have a 13.2 foot wingspan.
Posted by Don Stauffer on Thursday, June 18, 2020 9:33 AM
Here are some progress photos.  Includes the black accessory section, the compressor section, the burner section and an unmounted burner can, the exterior casing of the turbine section, and the firewall and front of the turbine section.
Now I need some help.  I lost a part- the turbine coupling shaft!  I cannot find it, and have lost hope that if I leave it alone, it will come home wagging its tail behind it.
If anyone has the kit, could they make some measurements for me, so I can scratch the shaft?  I believe, from the holes it goes through, it is about 1/8 inch in diameter.  But I need to know the length.  And, it has three bosses along it- a rectangular one and two cylindrical ones.  I need to know the spacing along the shaft for these bosses, and their size.  Can anyone help?
Posted by Don Stauffer on Tuesday, June 23, 2020 1:00 PM
I made the shaft out of eigth inch styrene tubing.  Didn't need the bosses- they hold the turbine rotor from moving axially, but that is captured by the vanes.
Have mounted the rotor in the turbine case now.
Also got the compressor mounted to firewall and intake section.
I had lost one of the fuel nozzles!  I used one of the others to make a mold from that RTV moldmaking putty.  Then, cast the nozzle with casting resin.
Bet you can't tell which is which.
Had another whoooops.  I had spilled a little bit of lacquer thinner on the bench.  While cleaning up I dropped a kleenex on the bench and it happened to land right on the wet spot.  A minute or two later I was picking up parts to get them out of the way, and I dropped the burner can assembly right in that wet Kleenex and didn't notice.  When I did, I found pieces of wet Kleenex stuck on a couple of cans, with steel color washed off others.  Not a big thing- sanded everything off with 1000 grit, and I'll touch up the next time I use the steel color.
Posted by Don Stauffer on Saturday, July 4, 2020 6:42 PM
Got a lot done lately.  Fixed those two burner cans fine. The turbine section (interior, anyway), is finished and fastened to the compressor section.
Got a decent Alclad aluminum coating on the spinner and blades, so these are ready to install.
I am now putting all the bangles and beads (piping, wiring and small accessories) around the outside of the engine. Back half of compressor section went fairly well, but the compressor door was a nightmare.  Almost every piece had fit problems.  I trimmed some as best I could, even replaced some of the piping with some aluminum wire I had.
This is the view of the junk on the other side of the compressor case.  Next step is stuff on bottom.  After that I can assemble all the sections and make some new mounts (I think the kit mount is not up to the level of the rest of the kit.
Starting to work on a base, but had to cut some strips of oak today, and saw blade is just to worn out, so it will be tomorrow or Monday before I go out and buy a new one.
    March 2007
Posted by armornut on Saturday, July 4, 2020 6:50 PM
   That is really cool Don,  I might have to add one to my stash....being an airplane machanic.
we're modelers it's what we do
    July 2014
Posted by modelcrazy on Saturday, July 4, 2020 7:51 PM
Oh wow Don! Excelent!
I saw on of these at HL the other day and though about getting it, now I think I will.
Steve
    December 2018
Posted by Ted4321 on Saturday, July 4, 2020 8:23 PM
Don this is great. I enjoy your engine builds. You do nice work for sure.
T e d
    June 2013
Posted by bvallot on Saturday, July 4, 2020 9:17 PM
Very cool Don!! This is a lot of fun to see come together. =] Hang in there.
On the bench:
Tamiya F4U-1  Kenneth Walsh
Posted by jeaton01 on Sunday, July 5, 2020 12:06 AM
Mighty fine, Don.
John
Posted by Don Stauffer on Sunday, July 5, 2020 10:42 AM
armornut
If you have a Hobby Lobby near you, they carry it, and with their weekly coupon it is quite cheap.
    April 2015
Posted by Mopar Madness on Sunday, July 5, 2020 11:33 AM
I've never seen anything like this. It's propeller driven and uses jet propulsion?
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2014
Posted by modelcrazy on Sunday, July 5, 2020 2:34 PM
Chad, turboprop. It uses the engine to drive a reduction gear for the prop. No thrust from the exhaust. About half  of turboprop engines use a centrifical flow engine the rest, axial flow like Don's
Actually not to disimilar to a turbofan on airlines, but the exhaust there is for thrust and the fan is for cooling, extra thrust and sound deadning.
Steve
    September 2012
Posted by GMorrison on Sunday, July 5, 2020 4:23 PM
They are a very fuel efficient propulsion system. The prop (s) is/are the main propulsion, and there is some residual thrust.
Prime examples currently are the C-130 Hercules, P3 Orion and the T-34 Mentor.
Commercial aircraft- the various Embraer short and midrange aircraft.
Private civil- the Beech King Air.
The Douglas A2D Skyshark, following the A-1 Skyraider, was an Allison turboprop set up driving counter rotating props on a single axis.
That powerplant had 5,000 equivalent (prop plus thrust) shaft horsepower, compared to the 2,700 hp of the Skyraider's R3350 radial engine.
You are no doubt familiar with the Russian Tu-95 Bear bomber. It has enormous Kusnetsov turboprops driving counter rotating props and develops about 12,000 equivalent shaft hp each.
A good spotting feature in photos is the single very large exhaust port per engine. The primary spotting feature in real time is the incredible NOISE!
Power and eficiency make them excellent endurance powerplants for patrol aircraft.
Bill
    January 2020
Posted by Space Ranger on Sunday, July 5, 2020 4:52 PM
modelcrazy
The exhaust of a turboprop does provide some thrust, but typically less than 10% of the total. And the fan of a turbofan provides as much as 70% of the total thrust; it's not just for "cooling, extra thrust and sound deadenimg."
Posted by CapnMac82 on Sunday, July 5, 2020 5:13 PM
Space Ranger
It's also important to remeber that a turbofan creates an area of low pressure into which it is draw rather than just mushing air upon air.
The compressor stages do a great deal of pressure change.  That semi-laminate airflow over the power section will reduce engine noise significantly, though.
There were some facinating experiments with external blades on turbofan engines in a hybrid semi-turboprop configuration.  The fuel economy was good, but the sound signature from exposed supersonic blade tips was a detriment.
    April 2015
Posted by Mopar Madness on Sunday, July 5, 2020 5:41 PM
Great, now I want one of these kits!
Chad
On deck: Who knows!
Posted by rangerj on Sunday, July 5, 2020 6:06 PM
Anyone who thinks that building models is playing with toys should read this and many other posts in the various sections of this web site. the knowledge being passed on is phenominal. It includes history, mechanics, physics, philosophy, and a whole lot more.
Model building teaches some very important skills, such as following directions, hand-eye coordination, working with tools, and more. (patience?)
Keep it coming Folks. And Don, I will PM you a few picture of the bundle of control cables that run along the ceiling of the B-17G as soon as I find the right file with those pictures. Food for thought, the C-130 and the B-52 started production in the early 1950s and they are still flying. American engineering.
Posted by rangerj on Sunday, July 5, 2020 6:10 PM
Oh and thank you Frank Whittle.Big Smile
Posted by keavdog on Monday, July 6, 2020 12:00 AM
And if I recall correctly after doing the S2 tracker radial to turbo conversion research, the turbos are lighter than their radial counterparts.
Thanks,
John
Posted by Don Stauffer on Monday, July 6, 2020 1:41 PM
Another long lived plane was the Beech D-18, a pre-war aircraft that was in production for many decades, and some are still flying (if they did the expensive main spar retrofit).
    September 2012
Posted by GMorrison on Monday, July 6, 2020 1:53 PM
The British Westland Wyvern carrier based aircraft was a pretty successful design, again with a counter-rotating prop arrangement. 3500 hp plus another 1100 lbf of residual thrust. They saw action in the Suez Crisis.
The Westland Wessex helicopter was a version of the UH-34, powered by a turboshaft engine mounted in the nose where the original radial engine was mounted.
dmk
    September 2008
Posted by dmk on Monday, July 6, 2020 2:42 PM
Nice job Don!  You had some grief with that one and it's really looking good.
CapnMac82
Wasn't it the Republic F-84H "Thunderscreach" that litterally made people sick from the noise of the supersonic prop tips?
That's why they stick those reduction gearboxes on the front of turboprops. I'd imagine the torque multiplication from the high RPMs of the gas turbine stepped down to prop speeds must put out some incredible power. I believe making those gearboxes reliable under all that torque was a big engineering problem for a while. One they figured how to keep the gearboxes from self destructing, gas turbines driving shafts are used in all sorts of applications.
Helicopters are almost exclusively gas turbines now (Helos were really limited by piston engines, jet engines are relatively simple and light weight for the power they put out). A lot of ships have them too (destroyers and patrol ships anyway). Electric power generaton plants use them. I'm sure a lot of other stuff.
Posted by Don Stauffer on Tuesday, July 7, 2020 8:45 AM
dmk
CapnMac82
They had a good start in that recips of large power were already using reduction gears.  Those huge radials like the R-2800 and the 3350 helped develop reduction gear technology.  And, in the thirties when gas turbines were being developed, the original idea was the turboshaft.  There were gas turbine/turboshafts of a thousand horsepower driving locomotives in Europe before the Whittle and Von Ohain engines first ran.  The turbojet did not precede the turboshaft.
dmk
    September 2008
Posted by dmk on Tuesday, July 7, 2020 6:47 PM
Don Stauffer
The big radials weren't spinning at the RPMs of the gas turbines, but that's interesting about the land based gas turbines with reduction gears. I wasn't aware of that. Maybe the problems they had were due to trying to lighten the gear boxes for use with the turbines in aircraft?
    September 2012
Posted by GMorrison on Wednesday, July 8, 2020 12:14 AM
Also, full frontal area of a gear box can hide in front of a big radial. Offsets work.
Therree was an interesting time where turbo props were perfomance monsters, before turbo jets were reliable.
The P-3 Orion's origin was the Lokheed Electra. As a commercial airliner, it failed becaiuse of a failure to design a engine/ airframe solution.
But Vickers designed Viscount.
The Russians had a number of short hall Antonovs, as did the Shorts.
