1/48 Tamiya F4F-4 Wildcat VGF-29 "Operation Torch" (Finished)
    February 2012
Posted by lawdog114 on Monday, June 15, 2020 2:39 AM
I wasn't going to do a work in progress for this one, as I've built several Tamiya Wildcats in recent years, but I figured I'd share it anyways.
I've been tasked with an F4F4 Wildcat from Operation Torch.  I can admit it isn't a subject I know much about, so I decided to read up on it. I learned Operation Torch was the November 1942 allied invason of French Morocco and Algeria during the North African campaign and there were some US Navy carriers used for support in these landings.  I chose a VGF-29 Wildcat from the USS Santee who was tasked with covering the landings.  It was weird learning that the stubby Grumman Navy fighter's primary adversaries during the campaign were the American P-36 and the French D.520 (the latter a build I have coming up soon as well).  Not confirmed, but I believe John "Tommy" Blackburn of Jolly Rogers fame flew this particular subject while assigned to VGF-29.
The Tamiya cockpit is good out of the box.  I cut out the floor to make it somewhat more accurate.  It's my understanding Grumman used a darker green in the pit on early cats, similar to dull dark green.  I used AK Real Colors version of it.  I used a PE instrument panel and Ultracast seat.  I forgot how great Ultracast seats were detail-wise.
Opps on the Interior Green color Eduard used.  I should have just matched that.  Oh well, it will be hard if not impossible to see once closed up.
These pretty much build themselves. Always a great fit.
The machine guns on this kit are comical, not unlike the ones on their P-51D which is the same late nineties vintage.  I drilled these out and added brass tubing replacements. They are a vast  improvement.
I had some spare Maketar masks so I used them. These work much better on the Wildcat's curved and rivet laden fuselage than the not so pliable Montex vinyl masks.
One of the weaknesses of this kit is their P&W R-1830.  It's average at best and the ignition wires are poorly molded onto the front of the cylinders.  I sought to improve this by adding a new one over it, essentially hiding the molded ones. These should disappear in the shadows of the cowl.  Much easier than trying to shave off the molded ones.
Some careful paint and weathering yielded a decent 1830.
That's all I got so far.  Time for paint.
    February 2017
Posted by Tubosteve on Monday, June 15, 2020 4:18 AM
A sterling start Lawdog, looking very nice indeed.
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
    November 2003
Posted by tempestjohnny on Monday, June 15, 2020 12:34 PM
This is going to be good
    February 2012
Posted by lawdog114 on Monday, June 15, 2020 4:04 PM
Tubosteve
Thanks Steve
    February 2012
Posted by lawdog114 on Monday, June 15, 2020 4:05 PM
tempestjohnny
Thanks Johnny
    July 2019
Posted by Hoss WA on Tuesday, June 16, 2020 2:04 AM
Looking great so far. Cool history.
    January 2017
Posted by damouav on Tuesday, June 16, 2020 4:07 AM
There is only one who can wield a hobby knife and have a jar of tamiya cement to produce such KICK A$se builds, and you wear that badge. I have learned allot over the past few years of being on this site, but of all the most Important techniques have come from you.
Thanks for posting.
Damian
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    June 2017
Posted by Chemteacher on Tuesday, June 16, 2020 11:40 PM
Looks great. This is going to be an awesome build as always. For a great read on Operation Torch, checkout Atkinson’s book, An Army at Dawn.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    February 2012
Posted by lawdog114 on Wednesday, June 17, 2020 8:50 PM
Hoss WA
Thanks Hoss
    February 2012
Posted by lawdog114 on Wednesday, June 17, 2020 8:51 PM
damouav
Thanks for posting.
Damian
Ha! hardly, but thanks for your kind words Damian.  Your welcome.
    February 2012
Posted by lawdog114 on Wednesday, June 17, 2020 8:53 PM
Chemteacher
I will....and thank you for the kind words.
    February 2012
Posted by lawdog114 on Thursday, June 18, 2020 3:33 AM
Quick update.  I finished masking the stars then got to painting.  I started with the underside.  I started with XF-19 Sky Grey then added some XF-2 White to fade it.  I did the reverse basing technique and went back and forth to achieve a marbled look.
For ANA 608 I used XF-18 Medium Blue cut with XF-2 White.  I used the same basing technique. The Maketar masks worked perfectly. I may use these from now on.  They seal better han the Montex vinyl and come up clean without the adhesive residue.
To backtrack a bit, I wasn't sure if all the stars on Operaton Torch Wildcats got yellow surrounds. These photos prove it was only present around the fuselage stars.
I painted accordingly........
I wanted to replicate the fading on the upper wing stars seen in this superb photo.
To simulate this, I used heavily diluted XF-2 sprayed from a distance to fade the wing stars a bit.  It worked great.
A post shade with diluted XF-69 NATO Black and XF-64 Red Brown was used as postshade weathering. I went heavier on the underside.  I'll do an oil wash later.
    November 2008
Posted by plasticjunkie on Thursday, June 18, 2020 8:22 AM
LD that paint fading looks awesome Yes
 GIFMaker.org_jy_Ayj_O
    June 2017
Posted by Chemteacher on Thursday, June 18, 2020 3:47 PM
Paint job looks awesome. It really pops the detail.
    February 2012
Posted by lawdog114 on Friday, June 19, 2020 12:48 AM
plasticjunkie
Thanks!
    February 2012
Posted by lawdog114 on Friday, June 19, 2020 12:49 AM
Chemteacher
Thanks!
Posted by jeaton01 on Friday, June 19, 2020 10:58 AM
Very nice, Joe.
John
    July 2019
Posted by Hoss WA on Friday, June 19, 2020 10:05 PM
Wow. Looking great.
    February 2012
Posted by lawdog114 on Wednesday, June 24, 2020 3:17 AM
Thanks John and Hoss.
I finally finished this turkey.  It's your typical Wildcat off the USS Santee during Operation Torch.  Not much to really say about the kit, the Tamiya Wildcat is a pretty painless build.  The only additons to the kit were a PE instrument panel and an Ultracast seat.  The engine was wired and I replaced the guns with brass tubing.  I also painted on all the markings except the numbers which were Wolfpack Design decals.
Posted by keavdog on Wednesday, June 24, 2020 4:01 AM
Wow lawdog - another beauty.  Really like the weathering on this one.  Well done!
Thanks,
John
    November 2003
Posted by tempestjohnny on Wednesday, June 24, 2020 4:55 AM
Holy (cow). That's gorgeous
    November 2008
Posted by plasticjunkie on Wednesday, June 24, 2020 6:40 AM
Fantastic finish as usual.Toast
    August 2015
Posted by crown r n7 on Wednesday, June 24, 2020 7:21 AM
Most impressive
 Nick.
    February 2017
Posted by Tubosteve on Wednesday, June 24, 2020 8:09 AM
That is one fantastic Wildcat, the weathering is 'to die for', absolutely gorgeous!!!
Posted by Tojo72 on Wednesday, June 24, 2020 8:40 AM
Fantastic work as usual
Posted by jeaton01 on Wednesday, June 24, 2020 11:10 AM
Well done, Joe.
John
    January 2017
Posted by damouav on Wednesday, June 24, 2020 3:04 PM
The techniques you employ to these builds make them just pop.
And with that, we have another first class build!
Thanks for taking the time to post, I look forward to the next.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    May 2011
Posted by dazzjazz on Wednesday, June 24, 2020 4:18 PM
Lawdog is there a good tutorial you could recommend so I can learn to paint and weather like that please?
    June 2017
Posted by Chemteacher on Wednesday, June 24, 2020 5:05 PM
Wow! Incredible job.
    July 2010
Posted by docidle on Wednesday, June 24, 2020 10:26 PM
Awesome work Joe. Love the aircraft and the flight deck!
Steve
