Airfix 1/72nd Sea Harrier FA.2 Completed page 2
Posted by Bish on Sunday, October 4, 2020 6:10 AM
I have never built a Harrier, but i have 5 1/72nd Airfix kits in the stash so figiured if i am doing one i might as well do 2 together. This is the Sea harrier FA.2.
I'll be adding an Eduard PE set and Quickboost resin exhausts.
I started out with geting the pit parts prepped and painted.
Not a lot of detail in the pit OOB, all the instruments are added with decals. After painting i just went straight to the PE.
Then the pit was fitted and the fuselage put together. No fit issues here.
You can see in the pic above that there a rim of plastic inside the intakes. I didn't know it at the time but this would be a problem. Its not suppossed to be there and will have to be removed. Its not flash as its thick plastic, and there is no indication on the instructions. As i went to fit the iner part of the intake attached to the fan i realised it neeed sanding back. I did this just enough for it to fit. But when i went to fit the outer part of the intake, i needed cutting all the way back. The left hand intake is fitted here, but not the right.
The wings did go on nicely, no issues there.
There was some filler needed around the intakes. tail is fitted just need to do some clean up of the filler.
More soon.
Posted by Don Stauffer on Sunday, October 4, 2020 6:47 AM
Looking good.  Those new Airfix 1:72 kits are great, aren't they?
Posted by Bish on Sunday, October 4, 2020 6:48 AM
Thanks Don. Yes they are, a huge leap ahead from what i grew up with in the 80's.
    June 2017
Posted by fotofrank on Sunday, October 4, 2020 8:06 AM
I'm going to go to school on your build here, Bish. I have the Airfix 1/48 Sea Harrier FRS Mk1. I'm sure there will be some transfer of knowledge from 1/72 to 1/48 that I can use.
The kit looks pretty good. Nice detail. I'll probably build it OOB to depict a Falklands Harrier.
OK. In the stash: Way too much to build in one lifetime...
Posted by Bish on Sunday, October 4, 2020 8:57 AM
Thank frank. I have the 72nd FRS. 1 in the stash. I wil be hosting a falklands war GB next year if your interested, i plan on doing a GR.3 for that.
    November 2003
Posted by tempestjohnny on Monday, October 5, 2020 9:39 AM
Bish
I'll break out my GR.3 for that too
Posted by Bish on Monday, October 5, 2020 9:43 AM
Nice.
Posted by Bish on Monday, October 12, 2020 4:17 PM
Construction of the Shar is complete so ashide from masking the canopy and intakes, its ready for primer. After some advice from a member on another forum, i realised i had used the wrong intakes. Airfix offers 2 options but doesn't explain which option should be used for in flight or on the ground. While i was able to remove the intakes, i could not take them apart. So i ordered the resin Pavla set which was swiftly fitted. The doors and hatches will be done off the kit.
And while its in the paint shop, i'l get to work on a tractor for the diorama.
    June 2017
Posted by Chemteacher on Monday, October 12, 2020 5:30 PM
That’s looking really fine. Thanks for posting.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    April 2015
Posted by Mopar Madness on Monday, October 12, 2020 11:29 PM
I have this kid in the stash. What is the difference between the in-flight versus the on-the-ground intakes? That little tractor will make the perfect complement to this beautiful bird.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by Bish on Tuesday, October 13, 2020 2:56 AM
Thanks guys.
Chad, its those square holes around the outside of the intakes. They have flaps on them which are not srung. So when on the ground and shut down, the upper ones are open while the lower ones shut. Once in flight, they all close from the airflow coming in through the intakes. Real G explained it in the VTOL GB.
    December 2018
Posted by Tosh on Tuesday, October 13, 2020 9:44 AM
Very nice work Mr. Bish!  I like the way in which you made adjustments for the intake!
Your friend's, Toshi & Ezra
Reside in Streetsboro, Ohio
    June 2014
Posted by BrandonK on Tuesday, October 13, 2020 10:19 AM
Nice work. I always liked the Harrier. This one looks really good. Too bad about the instructions. Perhaps you could let Airfix know of the issue so they can correct it for future kits.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    May 2013
Posted by Greg on Tuesday, October 13, 2020 10:52 AM
Only just realized you have two Harriers going on.
Both looking good, my friend. Yes
    August 2015
Posted by crown r n7 on Tuesday, October 13, 2020 11:32 AM
looking good..
 Nick.
Posted by Bish on Tuesday, October 13, 2020 1:04 PM
Thanks guys.
I am posting these builds on the Airfix website forum, not sure if that will have any impact.
    November 2003
Posted by tempestjohnny on Wednesday, October 14, 2020 5:40 AM
I recently sent Airfix a question regarding if they were going to make an early version of the Mustang (no fillet for tail) in 72nd. No reply yet
To me since there are no good early version Mustangs without surgery in 72nd that if they did it would be a license to print money. I know I'd buy at least a dozen.
    June 2008
Posted by lewbud on Tuesday, October 20, 2020 11:51 PM
That's looking good Bish.  Saw this on Aztec Models website.  There is a part one, but it's only available in 1/48.
https://aztecmodels.com/products/d-063-war-for-the-falklands-malvinas-2?variant=35133382688918
Buddy- Those who say there are no stupid questions have never worked in customer service.
Posted by Bish on Wednesday, October 21, 2020 4:31 AM
tempestjohnny
Is not the Academy B kit an early one, or is it just not a good kit.
Posted by Bish on Wednesday, October 21, 2020 4:32 AM
lewbud
Thanks for that link. If i am seeing that rightm, it includes markings for one of the Phantoms based on Ascension during the war. I might have to be picking myself up another Airfix kit for that.
    September 2011
Posted by falconmod on Thursday, October 22, 2020 12:24 PM
Bish
Do you have a sign up page for that GB yet?
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
Posted by Bish on Thursday, October 22, 2020 1:37 PM
falconmod
Bish
No, i won't be starting it until July so it can run to June 22 to mark the 40th anniversary.
    July 2014
Posted by modelcrazy on Thursday, October 22, 2020 2:01 PM
Bish
falconmod
Bish
I've been looking on occasion for a 1/700 HMS Antelope or HMS Sheffield for this GB for the past couple of years and they seem to be on perpetual backorder, or too outrageously priced on eBay to bother.
I may have to look for a Super Etendard instead. Confused
Steve
Posted by Bish on Thursday, October 22, 2020 2:29 PM
With any luck, Dragon might re-release them for the 40th.
    June 2008
Posted by lewbud on Thursday, October 22, 2020 11:57 PM
Bish,
The Academy B/C is probably the best B/C kit in 1/72.  TJ is referring to an early D-5 model, which had a filletless tail and fabric elevator surfaces.  Obscureco makes a conversion for the -5 including the early style radios and batteries.  I think it would be possible to adapt the Academy tail to the Tamiya D and make a decent -5.  If you build that other scale, the new tool Airfix D is filletless tail and Eduard makes one as well. To further complicate things, there was a field modification for the B/C which added the fillet.  I've seen pics of the modification on USAF, RAF, and RAAF birds.
    December 2018
Posted by Tosh on Friday, October 23, 2020 12:36 AM
This sir, is turning out to be a much antisapated build.  Great job and being that the Harrier is an awesome subject this is turning into a blast to view!  Ezra said he wants to make a Harrier as well, he watched True Lies movie.
And at the end of the climatic battle, two Sea Harrier blast a bridge and land behind the Nuclear safety zone blast.  That's one movie maybe the only movie Ezra and I enjoy especially the end scene!
Posted by Bish on Friday, October 23, 2020 2:40 PM
Thanks for that info lewbud.
Posted by Bish on Friday, October 23, 2020 2:41 PM
Thanks Tosh. Ye, i remember seeing that movie years ago. Even Bond has never flown a harrier.
Posted by Bish on Monday, November 16, 2020 1:25 PM
Been a while since i updated as both the harrier builds slowed a bit, partlydown to some issues with the GR.9. But here is the Shar painted and decaled and ready for some weathering.
Hopefylly won't be as long till the next one.
Posted by Bish on Sunday, November 29, 2020 7:46 AM
One short final update before i wrap up this build. The Shar is now finished and ready to attch to the base. I just gave it a light flory wash and the final mat coat, then adde stores, canopy and the final bits. For the canopy i used the PE Det cord which came with the Eduard PE. I atached this to the inside useing future and i much prefer this over the decal i used on the GR.9.
And i also finished the F59 tractor. This is a nice litle kit. It is missing some markings, namely the brand name of the company that makes it.
And i have just noticed that little chip in the yellow behind the door, so will touch that up.
So, i just need to add some RBF tags and fit this all to the base, and sort out a figure. Should be done by next weekend.
