I have never built a Harrier, but i have 5 1/72nd Airfix kits in the stash so figiured if i am doing one i might as well do 2 together. This is the Sea harrier FA.2.
I'll be adding an Eduard PE set and Quickboost resin exhausts.
I started out with geting the pit parts prepped and painted.
Not a lot of detail in the pit OOB, all the instruments are added with decals. After painting i just went straight to the PE.
Then the pit was fitted and the fuselage put together. No fit issues here.
You can see in the pic above that there a rim of plastic inside the intakes. I didn't know it at the time but this would be a problem. Its not suppossed to be there and will have to be removed. Its not flash as its thick plastic, and there is no indication on the instructions. As i went to fit the iner part of the intake attached to the fan i realised it neeed sanding back. I did this just enough for it to fit. But when i went to fit the outer part of the intake, i needed cutting all the way back. The left hand intake is fitted here, but not the right.
The wings did go on nicely, no issues there.
There was some filler needed around the intakes. tail is fitted just need to do some clean up of the filler.
More soon.
