The Mavis took a tumble last night!
    March 2005
Posted by philo426 on Monday, January 11, 2021 8:23 AM
I accidentally knocked over the Mavis last night and it looked bad!The wing was detached from The hull ,2 cowlings were knocked off ,had some broken off prop blades as well as one of the wing floats!Luckily the seams did not open up and although one of the hull blisters popped off the clear parts were in tact.I was able to get it back together ,just have to re rig the radio wires.Could have been a lot worse!
    March 2005
Posted by philo426 on Monday, January 11, 2021 8:26 AM
    March 2005
Posted by philo426 on Monday, January 11, 2021 10:37 AM
I took a couple pieces of 3/64 brass wire and drilled a 1/32 hole in each one to hold the 4 lb test fishing line.Drilled 1/32 holes in the vertical stabs and fished it through secured with binder clips  to properly tension the line  added a drop of CA to fix the line in place.Should I paint the line black or silver?
    July 2014
Posted by modelcrazy on Monday, January 11, 2021 10:46 AM
Good save.
Black
Steve
    March 2005
Posted by philo426 on Monday, January 11, 2021 11:25 AM
Thanks!it us bigger than the Coronado!
    March 2005
Posted by philo426 on Monday, January 11, 2021 9:34 PM
Posted by keavdog on Tuesday, January 12, 2021 12:01 AM
Well done!
Thanks,
John
    January 2017
Posted by mawright20 on Tuesday, January 12, 2021 12:18 AM
Maybe it thought it was making an attempted water landing.
    March 2005
Posted by philo426 on Tuesday, January 12, 2021 7:26 AM
Could be!lol!
