1/48 Eduard Fw 190D-9, Black 4, II./JG 301 (Complete)
    July 2019
Posted by Hoss WA on Saturday, September 4, 2021 8:52 PM
It's back to the Luftwaffe with Eduard's new D-9 Weekend Edition.
I was looking for an interesting late war subject and found W.Nr. 500576 in EagleCals #124 and in Jerry Crandall's Dora book.
This plane was captured at Wunsdorf airfield as the Allies advanced in the last weeks of the war. There are a few B&W photos of this dora. Black 4's W.Nr. is close to 500570 (Blue 12), of which there are several excellent photos, including one in color.
My planned camo scheme for Black 4 consists of RLM 81, RLM 82 and the blue-green version of RLM 76 on the fuselage, natural metal, RLM 81 and blue-green on the underside, and RLM 76 and RLM 81 on the upper wing surfaces.
The new Eduard Weekend Edition kit is a reboxing of the earlier version with new markings. As those who've built this kit know, it is a battle at every step with fit issues, especially if you want closed covers, but can be made into a decent looking Dora with patience. My kit had a severely warped right fuselage half that I salvaged by heating it up in hot water and carefully bending it back in shape.
It's mostly OOB with the addition of Eduard seat belts, brass tubes for the 20mm cannons, some scratch built items (throttle) and a few PE parts from the spares box (canopy hand crank, cannon door hinges, wing reinforcements and supercharger exhaust shield). I'll use Mr. Color paints, Eagle cals and Montex masks for the main markings.
Here's the front office.
If you're planning to build this kit, I recommend an aftermarket instrument panel detail set or decals. I couldn't get the kit decals to conform well to the surface features.
Here are some shots of the PE extras.
The main build is complete and my Dora is ready for priming and painting.
    July 2019
Posted by Hoss WA on Wednesday, September 8, 2021 8:07 PM
The priming and main painting is now complete. I really got a kick out of this wild, late war camo scheme. The relentless pressure and disruption on aircraft production coincident with a paint scheme change-over (RLM 74/75 to RLM 81/82) resulted in some interesting and unique color schemes across the various factories assembling Doras. Black 4 was produced at the Mimetall factory, with subassemblies -- wings, engine, tail, etc. -- coming from various distributed suppliers.
Mr Finishing Surfacer 1500 was applied as primer, followed by the red and yellow JG 301 bands. Gloss black was applied before the natural metal Mr Color Super fine silver.
After the metal section was dry and masked, RLM 76 was applied to the ailerons, the top surfaces of the wings and stabilizers, and the rudder. The paint was applied unevenly with the addition of highlights and shading.
After masking, RLM 81 was next. Apparently there were three versions of RLM 81, with varying degrees of green and brown. My Mr. Color mix was 5 parts RLM 81 and 2 parts Red Brown. RLM 81 was applied to the wing and stabilizer upper surfaces as well as the  front portion of the underside of the wings and the landing gear doors.
After masking the wings and stabilizers, the fuselage and tail were painted a lightened version of Mr. Color Duck Egg Green to represent the blue-green version of RLM 76. RLM 81 was then applied along the spine from nose to tail. The engine cowling and sections of the spine near the tail were sprayed with RLM 82 bright green. RLM 81 and 82 mottling was then applied to the tail.
The profile indicated some rust colored primer/putty near the tail and around panels underneath.
After some general clean up and then chipping and scratching in wear areas, GX100 gloss was applied and now Black 4 is ready for decals. I had some previously used  Montex masks but they weren't in good enough shape to re-use unfortunately. The Eagle Cal decals look good.  Thanks for looking.
    June 2017
Posted by Chemteacher on Wednesday, September 8, 2021 8:32 PM
Wow! That looks awesome. Beautiful job.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    April 2020
Posted by JBRaider on Wednesday, September 8, 2021 8:41 PM
Coming along nicely Hoss
I just used Eagle Cal decals on a 1/72 Dora and they were some of the best decals I have worked with.
    July 2021
Posted by Flight Line Media on Thursday, September 9, 2021 4:29 AM
Wow! That looks great! Great work.
Andrew
www.flightlinemedia.co
Follow us on Instagram: from.the.ariel.view
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 6:25 AM
Chemteacher
Thanks Chemteacher!
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 6:27 AM
JBRaider
Thanks JB. The decals are going on great so far.
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 6:28 AM
Flight Line Media
Wow, that looks great! I look forward to seeing this build completed.
Thanks Flight Line! Making slow progress.
Posted by keavdog on Friday, September 10, 2021 8:23 AM
Looking sharp!  I really like the lines of the Dora.
Thanks,
John
    March 2012
Posted by mustang1989 on Friday, September 10, 2021 8:50 AM
Dunno how I missed this but I've gotta say....this is one helluva build. D-9's are my all time favorite aircraft. Just a beautiful bird.
 Forum | Modelers Social Club Forum (proboards.com)
    April 2015
Posted by Mopar Madness on Friday, September 10, 2021 3:04 PM
I like the look of these late model 190s. Incorporating bare aluminum panels really makes these things pop!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 9:05 PM
keavdog
Thanks John! Me too.
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 9:07 PM
mustang1989
Thanks Mustang. I've been learning a lot about Doras for this build. I've built a couple before but didn't realize the extent of the variations of camo schemes. And the Dora's lines are certainly iconic.
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 9:09 PM
Mopar Madness
Thanks Chad!
    July 2019
Posted by Hoss WA on Friday, September 10, 2021 9:16 PM
The markings are now complete and I figured I'd share a couple of photos. The decals went down without any major issues.
More weathering is next. Thanks for looking.
    August 2015
Posted by crown r n7 on Saturday, September 11, 2021 8:34 AM
very interesting camo. most impressive.
 Nick.
    March 2012
Posted by mustang1989 on Saturday, September 11, 2021 7:37 PM
Great work so far Hoss!! YesYesYesYes
    July 2019
Posted by Hoss WA on Sunday, September 12, 2021 7:18 PM
crown r n7
Thanks Nick.
    July 2019
mustang1989
Thanks Mustang!
    July 2019
Posted by Hoss WA on Sunday, September 12, 2021 8:19 PM
My rendition of Fw 190D-9 Black 4 from II./JG 301 is now complete.
The research project was as involved as the build itself. I used a number of references including Jerry Crandall's Dora books, Smith & Creek's Focke Wulf books and various articles and references on the web to try to make sense of the plane details, history, color schemes, markings, etc.
Black 4 (W.Nr. 500576) was found at Wunsdorf airfield when the British 6th Airborne Division captured the Luftwaffe airbase on 8 April 1945. The pilot is unknown. The aircraft was manufactured at the Mimetall factory near Erfurt and apparently sports camoflage typical of aircraft from this factory. I found a number of different interpretations of the exact colors and patterns but from what I was able to piece together, the basic scheme is as follows:
  • Underside: RLM 81 on the forward part of the wings, natural metal aft of the landing gear bays, RLM 76 ailerons.
  • Fuselage: RLM 76 blue green, RLM 81 on the spine from the nose to tail with areas of RLM 82 applied. Mottles on the tail.
  • Upper wings: RLM 81 and 76 camo pattern.
I used the profile from Jerry Crandall's book, the Eagle Cals #124 profile and other references to create my hybrid camo pattern. I mostly followed the profile in Jerry Crandall's book. There are a few photos of Black 4 in pieces, without a complete view of the assembled aircraft. Detailed analyses of the well-documented Blue 12 from JG 6, which has a Wk. Nr. only 6 units before my subject, was also helpful.
As for the build, I added the following goodies:
  • Brass tubing for the 20mm cannons and pitot tube.
  • Hollowed out ends of the exhaust tips and MGs
  • Spare PE and parts for the lower antennas, landing gear indicators, hinges for cannon bay doors, exhaust deflector, wing support plates
  • Stretched sprue for the main antenna cable.
  • Eduard seat belts.
  • Eagle Cals #124 - worked very well.
  • Landing gear struts from the spares box - the kit parts were molded horribly.
  • Scratch built the ETC rack braces and added some panel line detail
  • Wheels from the spares box - the kit wheels looked a little narrow.
This is the third 1/48 Eduard Dora I've built and it was not any easier than the first two. This is a kit that fights you at every step. It's designed to be completed with open covers for the MGs and cannons -- closing the covers is not straightforward. Every part seems to be a project in itself, unlike the Tamiya kits that fall together. That being said, I think the end result with the added goodies is a reasonable representation.
For main camo, I used Mr. Color paints exclusively. RLM 76 and RLM 82 were from the bottle. My ultimate version of RLM 81 Brown-violet was 5 parts Mr. Color RLM 81 and 2 parts Red Brown. The fuselage RLM 76 blue green was Mr. Color Duck Egg Green mixed 1:1 with Flat white. Of course extensive fading and shading was done for all colors. I primed with Mr. Surfacer 1500.
The spinner was painted on -- I tried several decals from different sheets but was unsuccessful.
Decals were great - no issues with the Eagle Cals (except for the spinner, which was most likely operator error).
Mr. Color GX100 was used for the gloss coat -- great stuff.
Flory washes of various colors were used for the panel lines and rivets -- Dark Dirt for RLM 82, Black/Dark Dirt for RLM 81 and gray for RLM 76.
For the camo masking, I used paper cut out pattern with small tape rolls for the wings and white-tack rolls for the fuselage. Mottling was all free hand.
Chips and scratches were applied with a combination of paint and colored pencil. A thin, black-brown mix was applied to most of the panel lines, especially near the engine and control surfaces. The exhaust pattern was slowly built up with brown and black, carefully following reference photos.
The cannons and MGs were painted with Mr. Color Dark Iron and buffed.
The final flat coat was Model Master Flat Clear Lacquer.
All-in-all, the centerpiece of this project is the unique and interesting camo and marking scheme. Plowing through Edward's kit to get to the painting phase was a little tedious but I'm happy with the final result. Thanks for following along!
    April 2020
Posted by JBRaider on Sunday, September 12, 2021 9:08 PM
Beautiful work Hoss!
It could pass for the real thing in those outdoor pics.
    September 2019
Posted by Nikola on Monday, September 13, 2021 1:15 AM
Now that is simply BEAUTIFUL! Brilliant work Hoss! It's a pleasure to look at. Well done man!
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Monday, September 13, 2021 2:13 AM
Hi Hoss,
I forgot to ask - do you freehand the camo or do you ''worm'' mask first? If you freehand, which nozzle, airbrush and paint settings do you use? It just looks perfect and so well controlled.
Thanks in advance,
Nikola
            www.shelfforce.com
    July 2019
Posted by Hoss WA on Tuesday, September 14, 2021 3:48 PM
JBRaider
Thanks JB! Much appreciated. I like to try to display these birds in their natural habitat.
Beer
    July 2019
Posted by Hoss WA on Tuesday, September 14, 2021 3:49 PM
Nikola
Best,
Nikola
Thanks Nikola! Glad you like it.
    July 2019
Posted by Hoss WA on Tuesday, September 14, 2021 4:04 PM
Nikola
Hi Hoss,
Thanks in advance,
Nikola
Great question. I use a combination of techniques, but here was my approach for this one:
Wings - Paper masks with little rolls of masking tape keeping the masks about 0.5mm above the surface.
Fuselage - "worm" masks of white tack about 2mm in diameter. I freehand some of the edges, especially those that are too sharp, to make the edge a little uneven or change the position a bit.
Mottles - I freehand the mottles for size and location and first. I then lightly apply a coat of the base RLM 76 to fade the mottles a bit, since the edges tend to be too dark and grainy. I then come back and darken just the center of the mottles to make them look like they were sprayed on with faded edges.
For all of the edges I often use a #6000 or #8000 sanding stick to clean up extra overspray. In general, I use a combination of the sanding stick to tighten up the edge and freehand spraying to soften the edge.
My airbrush is an Iwata Eclipse HP-CS with a 0.35mm nozzle. 20 psi at the compressor is usual but sometimes I reduce it depending on the thickness of the paint and the task. Most of the camo was painted at 20 psi.
Hope this helps. Thanks again.
    January 2020
Posted by wpwar11 on Tuesday, September 14, 2021 5:23 PM
Beautiful job.  I have an Eduard Dora in the stash too and was considering building that one next.  I also got the same decals.  Im hoping I get the great result you did.
    September 2019
Posted by Nikola on Wednesday, September 15, 2021 12:50 AM
Hoss WA
Nikola
Hi Hoss,
Thanks in advance,
Nikola
Thank you very much for the tips Hoss! Means a lot. Appreciated!
Best,
Nikola
            www.shelfforce.com
    February 2012
Posted by lawdog114 on Wednesday, September 15, 2021 2:09 AM
Absolutely scruptious.  Again, I love your photography.
    November 2003
Posted by tempestjohnny on Wednesday, September 15, 2021 3:56 AM
lawdog114
Yea what he said
