AVG P-40 color scheme
    May 2006
Posted by Brews on Friday, June 23, 2006 4:48 AM
Type S means a smooth finish matt paint. It has no meaning with respect to colour.
However, there is a Sky Grey and Sky, which is the familiar pale green that was applied to late Battle of Britain a/c, and undersides of most RAF diurnal a/c through to (I think) early 1942, when the temperate sea scheme was substituted for temperate land scheme (or something like that). The Sky was commonly kept as a spinner colour, and for the rear fuselage band on fighter command planes.
I think that Sky Grey is a Fleet Airm Arm colour, so would not be as likely as the pale green sky (also known as duck egg blue/ duck egg green, I think).
As I painted my P-40 with Azure blue undersides, I'm keen to determine that this was correct (I'm afraid of the truth!).
One reason I used Azure blue was because it seemed to be the correct shade, based on a colour photograph on the cover of a book called "The Illustrated Encyclopedia of Combat Aircraft of World War II", by Bill Gunston. However, looking at the cars parked in the background, the photo may date from the '50s rather than the '40s.
    December 2005
Posted by sidewinder77 on Friday, June 23, 2006 4:50 AM
thanks jwb,
im not really sure about that detail tho. i built the cockpit practically oob but ill still send em to ya as soon as i get more pics. by the way, i recall it was dark earth and dark green as indicated in the instruction sheet.
james
On the Bench:
Tamiya 1/48 Beaufighter
ICM 1/48 P-51B Mustangs
ICM 1/48 Spitfire IX
Hobbyworld 1/48 Huey
Academy 1/72 P-51B Mustang / F6F-3 Hellcat
Italeri 1/72 F-117 Nighthawk
    April 2006
Posted by Dark Green Man on Friday, June 23, 2006 6:36 PM
type S meant 'Smooth' as in semi-gloss , not flat.
what I meant is 'sky type s grey' is actually a combination of sky grey and sky type s, but that is two different paints. there seems to be some confusion over what color it was supposed to be so they combined them together, only making it more complicated.
Yes , that is Sky Type 'S'
Sky Grey was used for codes on RAF planes , not just FAA
according to Dana Bell's book 'Azure Blue' was specified for the P-40's sent to the desert of Africa.
it was Du pont 71-052 and it would later be ANA 609
was that an aircraft that served in Africa? that might explain it.
    March 2004
Posted by Mark Joyce on Friday, June 23, 2006 9:22 PM
 Nelson Ott wrote:
Hi guys,
I'm currently building the Trumpeter 1/48 P-40B that I would like to finish in the AVG scheme, more specifically using an old SuperScale Decal sheet (48-12) with markings of the 2nd PS, aircraft no. 38 flown by H. M. Geselbracht. The color scheme demarcation lines as indicated in the SuperScale sheet doesn't seem to be very accurate, so I'll paint it in the scheme recommended on Cutting Edge AVG decal sheets. Can anyone confirm to me I'm doing the right thing ?
Thanks a lot
Nelson
Hi Nelson.
P-40s leaving the Curtiss factory with a camo scheme were painted with some type of mask, such as wood or rubber, so they had 'hard edge' demarcation lines.  There's a profile of these lines in a 1995 Finescale Modeler issue.  I have Cutting Edge decals for AVG tomahawks, along with the Black Magic/Cutting Edge paint masks for the Monogram kit, and both look accurate in regards to the profile in the magazine.  I agree with you in going with the Cutting Edge pattern vs. the Superscale.
And Sidewinder77:  Nice job on the build!
Mark
Ignorance is bliss
    October 2005
Posted by gulfstreamV on Saturday, June 24, 2006 2:44 AM
 sidewinder77 wrote:
hey jwb,
ive done chuck older's tiger 2 years ago, i never figured theres a debate on the real color. i just followed the color guidelines of the academy 1/48 kit. heres a couple of pics.
The prop is life, one that  beat up and chiped means poor performance
Stay XX Thirsty, My Fellow Modelers.
Posted by Nelson Ott on Monday, June 26, 2006 11:34 AM
Thank you very much, Mark.
Nelson
jwb
    February 2006
Posted by jwb on Tuesday, July 11, 2006 4:14 PM
Just to drag out this discussion a bit more.... Wink [;)]
I have come to the conclusion that short of inventing a time machine and going back to an AVG airfield in late '41 or '42, the world may never truly know what the colors looked exactly like, even with the numbers of the colors.
And I've spent far too much time researching this, but it's been fun.... Big Smile [:D]
So the best I can conclude, after reading too many Google hits and saving literally MB's of photos to examine.... (and this is what I'll paint my P-40B with Boyington's markings):
Upper surfaces- RAF dark earth with some yellow added in for fading and RAF Dark green with a hint of OD and a hint of yellow to fade/dirty it. The dark earth I'll keep playing with until it takes on the slightest greensih hue, but still look brown.
The undersides will be something as close to Dupont light Sky gray as I can get, with a hiny of Sky Type S (the greenish color) thrown in for giggles.
Of course, that may change once I actually mix the paint and see what it looks like.
I finally threw in the towel and said "OK, Jon, just settle on something" when I saw some old but decent color photos- all the same photo, coincidentally- and depending on it's age and quality made it look like green on green over gray, or maybe Sky.... or green on brown over sky.... or was it gray....
In one photo- the aircraft in the background looked different than the one in the foregound! Shock [:O]
So however it turns out, I'll post pics.
Isn't this hobby sometimes insanely addictive but pure fun! Big Smile [:D]
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    May 2003
Posted by DrewH on Tuesday, July 11, 2006 9:10 PM
Can't drag this thru the mud enough. So, you settled on the seemingly "status quo" for colors. Banging the head a bit much on this subject myself, I did essentially the same. Research article after article and come up with mostly nothing new. I know that one too well.
Addictive- I hope so!Thumbs Up [tup]
Insane- Seen my visa bill latelyTongue [:P]
Fun- With this bunch....ALLWAYS!!Smile,Wink, & Grin [swg]
Take this plastic and model it!
    October 2005
Posted by gulfstreamV on Wednesday, July 12, 2006 12:04 AM
jwb, go with it.......it will look great........................Cool [8D]
