The Race Into Space GB, October 2018 - July 2019 (Ended)
    July 2014
Posted by Bakster on Sunday, January 20, 2019 8:41 PM
GAF
LIVE FROM THE MOON
Wow, that is cool... We are looking through the mind of a youngster. Very cool. Clearly, the space program had an impact on you, as it did on many of us.
GAF
    June 2012
Posted by GAF on Sunday, January 20, 2019 8:45 PM
Not sure I was a "youngster".  I was 16 at the time.  I would write regularly to various NASA installations requesting information, and they were happy to send out packets of stuff (photos, memos, booklets, etc.)  Try to get anything like that today!  Smile
Gary
    July 2014
Posted by Bakster on Sunday, January 20, 2019 8:49 PM
littletimmy
Your at least going to put Gum under the pannel .... aren't you ???
Lol! Right? Hey Ridley, got any Beemans? Loan me a stick would you?
    July 2014
Posted by Bakster on Sunday, January 20, 2019 9:22 PM
GAF
Gary
Man... you were all over it with requesting info too! You should post some of that too.
I know that I posted this on the forum in another thread, I hope I am not repeating myself in this one.
When I was a kid my Dad bought our family a telescope through Sears. It was a cheap scope, but good enough to enthrall me many an evening. It had a few eyepieces that greatly magnified it’s power bringing the moons craters to pretty good detail. During the moon landing mission I was outside viewing the moon through the scope. This was post landing. I had the strongest eyepiece on, and I was scanning the moon for the landing site. As I was doing this an object came into my view. I immediately realized what it was. It was the command module that was orbiting the moon. I could clearly see it’s outline, and the sun was reflecting off the shiny surface of the capsule. I watched it for about three seconds. The scope is not made for tracking and I quickly lost it. Even to this day I can scarcely believe the luck I had in spotting it. It’s one of those things I can look back on and say, dang, that was cool.
    March 2010
Posted by mach71 on Sunday, January 20, 2019 9:48 PM
Thanks for the info on priming/painting the vinyl figure!
Wow! lots of stuff happening!
Bakster, I love your Instrument panel!
Very well done indeed!
Having spent my life in aviation, most wireing bundles I have seen are wrapped in a white or sometimes black covering. The wires themselves are almost never exposed. Your color is a great choice. And yes you can see the back of the instrument panel through the windscreen.
Gary, Your moving along great now!
Not much new for me. I finished the last few details of the retro pack.
I'll be away for 10 days so nothing new will get done.
    July 2014
Posted by modelcrazy on Sunday, January 20, 2019 9:48 PM
GAF
I was 8 and remember watching the brodcast with a friend of mine.
Steve
    July 2014
Posted by Bakster on Sunday, January 20, 2019 11:46 PM
mach71
First, thanks for the kudos. Second, thanks for confirming the colors and that you can see the bundles from the back. After my first post I went and tested the panel in the fuselage. Sure enough, you can see a lot. If you have any other suggestions about my wiring, please let me know. If you think white is better and or if the wires should be bound together... that sort of thing. Or mix and match the colors even. Or, just leave it alone Is good too.
Thanks...
    December 2003
Posted by scottrc on Monday, January 21, 2019 11:02 AM
Baks,
I'd also stay with black.  This was the era where harness jackets were made from woven cloth and were coated with thick coats of laquer.  The color was probably whatever the interior was, so in the case of the windscreen, black would have been the obvious color.
Posted by Gamera on Monday, January 21, 2019 11:04 AM
Great looking stuff guys and great progress!!!
I did get the second leg of my astronaut cleaned up, working on the left arm now. At this rate hopefully I'll be done by the end...
Mach 71: I've been using spray cans of 'rubber bumper' paint from the auto parts store as a primer on vinyl figures. So far haven't had any issues with it. It seems to work fine as a primer to paint acrylic paint over.
    December 2003
Posted by scottrc on Monday, January 21, 2019 11:15 AM
I've set everything up on my drafting table and have begun an adventure of making a scale rocket of the Saturn V that I hope I can launch in time for the anniversary.
I even dusted off the old slide rule for some nostalgic ambition.  I haven't tried to use it since 1979.
Custom cradle built to support the 4" diameter main body.  Its going to grow over the next couple of weeks.
And having fun with card stock wraps.  One of the joys I did not miss from my early days of rocket building.  Measure 2000 times, then cut, and do it all over again.
    July 2014
Posted by Bakster on Monday, January 21, 2019 11:27 AM
scottrc
Baks,
Giddy up! That sounds great! I'll shoot some flat on it and call it done. Thanks for the input.
    March 2010
Posted by mach71 on Monday, January 21, 2019 11:27 AM
I'd stick with the black. I would not mix it up at this stage.
Having never seen a late 40's Bell aircraft wireing bundle I can't
say for sure but Scottrc's logic sounds good.
Gamera,
Thanks for the tip! I'll pick some up.
Scottrc,
Have fun with the SV! I built, and flew, mine about 10 years ago.
The Rocketry Forum has TONS of great info on building it.
I converted mine to a 5 engine cluster with good results.
    July 2014
Posted by Bakster on Monday, January 21, 2019 11:28 AM
scottrc
Oh man... we are in for a treat. A scratch build. Yes
GAF
    June 2012
Posted by GAF on Monday, January 21, 2019 9:25 PM
Bakster> That's a really cool story about the telescope!  A one in a million... Smile
Mach71>  Thanks, and see you in 10 days!  Be safe!
Scott>  That is some serious scratch-building you're attempting!  Look forward to seeing it come together.
My own project was mostly gluing those folding panels together (that super glue sure takes a long time to harden), and beginning to mask things for paint, which tomorrow (weather permitting) I'll begin spraying on the first coat of white.  Plus some other things like the SM engine nozzle (black and aluminum) and SM heat shield (gray and aluminum).  Hope things turn out okay. Oh, and that D-7 is masked up ready for a 2nd color.
That's it for today!  Hope everyone is surviving the cold weather.
Gary
Today in Space History:
1960 January 21 - . 14:23 GMT - . Launch Site: Wallops Island. Launch Complex: Wallops Island LA1. Launch Vehicle: Little Joe 1.
  • Mercury LJ-1B - . Nation: USA. Agency: NASA. Spacecraft: Mercury. Apogee: 14 km (8 mi).
  • Little Joe 1-B (LJ-1B) was launched from Wallops Island with a rhesus monkey, 'Miss Sam,' aboard. Test objectives for this flight were the same as those for Little Joe 1 (LJ-1) in which the escape tower launched 31 minutes before the planned launch, and Little Joe 1-A (LJ-1A), wherein the dynamic buildup in the abort maneuver was too low. A physiological study of the primate, particularly in areas applying to the effects of the rapid onset of reverse acceleration during abort at maximum dynamic pressure, was also made. In addition, the Mercury helicopter recovery system was exercised. During the mission, all sequences operated as planned; the spacecraft attained a peak altitude of 9.3 statute miles, a range of 11.7 statute miles, and a maximum speed of 2,021.6 miles per hour. Thirty minutes from launch time, a Marine recovery helicopter deposited the spacecraft and its occupant at Wallops Station. 'Miss Sam' was in good condition, and all test objectives were successfully fulfilled.
Posted by Gamera on Tuesday, January 22, 2019 11:59 AM
Scott: That's friggin' awesome!!! Looking forward to watching her come together!
Bakster: That is a very cool telescope story. Very lucky on your part and one hell of a memory to cherish!
GAF
    June 2012
Posted by GAF on Tuesday, January 22, 2019 2:36 PM
I had to abort my painting today.  The weather was not cooperating.  Too cool and too windy.  I did attempt to paint the second color on the D-7 model, and the interior of the LM Storage Area. I'm afraid I got some "orange peel" effect on the D-7, so I decided that was it for any further attempts.  I'm letting them dry (inside) to see what damage if any.
Meanwhile, I'll just keep plugging away at the small things, such as fixing a LM landing leg that's broken, working on the astronaut figures, etc.  Not sure if there will be anything else to report tonight.
Gary
1968 January 22 - . 22:48 GMT - . Launch Site: Cape Canaveral. Launch Complex: Cape Canaveral LC37B. LV Family: Saturn I. Launch Vehicle: Saturn IB.
  • Apollo 5 - . Payload: Apollo LM-1. Mass: 14,360 kg (31,650 lb). Nation: USA. Agency: NASA Houston. Program: Apollo. Class: Moon. Type: Manned lunar lander. Spacecraft: Apollo LM. Decay Date: 1968-02-12 . USAF Sat Cat: 3107 . COSPAR: 1968-007B. Apogee: 374 km (232 mi). Perigee: 169 km (105 mi). Inclination: 31.6000 deg. Period: 89.90 min.
  • NASA launched Apollo 5 - the first, unmanned LM flight - on a Saturn IB from KSC Launch Complex 37B at 5:48:08 p.m. EST. Mission objectives included verifying operation of the LM structure itself and its two primary propulsion systems, to evaluate LM staging, and to evaluate orbital performances of the S-IVB stage and instrument unit. Flight of the AS-204 launch vehicle went as planned, with nosecone (replacing the CSM) jettisoned and LM separating. Flight of LM-1 also went as planned up to the first descent propulsion engine firing. Because velocity increase did not build up as quickly as predicted, the LM guidance system shut the engine down after only four seconds of operation, boosting the LM only to a 171 x 222 km orbit. Mission control personnel in Houston and supporting groups quickly analyzed the problem. They determined that the difficulty was one of guidance software only (and not a fault in hardware design) and pursued an alternate mission plan that ensured meeting the minimum requirements necessary to achieve the primary objectives of the mission. The ascent stage separated and boosted itself into a 172 x 961 km orbit. After mission completion at 2:45 a.m. EST January 23, LM stages were left in orbit to reenter the atmosphere later and disintegrate. Apollo program directors attributed success of the mission to careful preplanning of alternate ways to accomplish flight objectives in the face of unforeseen events.
2003 January 22 - .
  • Last transmission received from Pioneer 10 - . Nation: USA. Spacecraft: Pioneer 10-11.
  • The signal received was very faint with no telemetry received. NASA's Deep Space Network (DSN) did not detect a signal during the final contact attempt on 7 February 2003. The last time a Pioneer 10 contact returned telemetry data was 27 April 2002. NASA had no additional contact attempts planned for Pioneer 10. Pioneer 10 was at 82 AU, or 12.3 billion km from Earth. The last signal took 11 hours and 20 minutes to reach earth. The spacecraft was headed in the direction of the star Aldebaran, 68 light-years away. It would reach the vicinity of the red giant star in about two million years.
GAF
    June 2012
Posted by GAF on Wednesday, January 23, 2019 9:14 PM
Project Report:
Fixed the LMs broken landing leg today.  Looks like it will hold.  Began work on the couches for the CM, added padding to the seats and began painting the astronauts.  I considered making the suits silver since they're closer to Gemini suits than Apollo, but went with white instead.  Folding doors continue to give me fits.  They're a bit warped from age, so I'm trying to straighten them a bit.  Not sure when my next break in the weather for painting the major pieces will be.  I did order a replacement color ink cartridge today, so I should be able to print decals and instrument panels soon.
Mission Director (GAF)
1969 January 23 - .
  • The assassination attempt is made on Brezhnev, instead hitting the cosmonaut's car, on the way to the Kremlin. A muted press conference follows. All the cosmonauts are there, except Feoktistov, who is on honeymoon with his second wife, and Nikolyaev, who has the Hong Kong flu.
1970 January 23 - . LV Family: Shuttle. Launch Vehicle: Space Shuttle.
  • NASA Houston in-house study of shuttle concepts - . Nation: USA.
  • The study was in an attempt to resolve disputes between the centres as to the best approach. Houston's Faget straight-wing two-stage vehicle was in competition with concepts from other centres - recoverable versions of Saturn boosters, and an advanced single-stage-to-orbit Aerospaceplane. Payload for the Faget vehicle was to be only 5,700 to 6,800 kg to low earth orbit, and the system was to be operational by the end of 1975, after the last Apollo flight.
GAF
    June 2012
Posted by GAF on Friday, January 25, 2019 11:11 PM
Project Report:
Not much happening at this time due to weather.  Cold conditions are hampering construction operations.  Smile  (Jeez!  The breaker for my HVAC keeps kicking off!  Need a repair guy!)  Work on the base for the Apollo model continues, and I am cutting ribs to go along the side, while a top has been cut out.  I intend to scribe it into panels for painting.  Want to see how it turns out.  Painting on the astronauts is coming along slowly.  Detail work has begun.
1969 January 25 - Launch VehicleN1.
  • Apollo vs Ye-8-5 - . NationRussiaProgramLunar L3LunaApolloFlightApollo 9Spacecraft BusLuna Ye-8SpacecraftLuna Ye-8-5.
    America is preparing Apollo 9 for flight, and Kamanin muses that the Soviet reply will be the N1 and Ye-8-5, neither of which is proven or reliable. The Soviet Union would have a better chance of sending a manned L1 on a flight around the moon during the first quarter of 1969. Meanwhile Mishin's bureau has a new L3M lunar lander on the drawing boards. This will land 4 to 5 men on the moon, but require two N1 or seven UR-500K launches to assemble in orbit.
2004 January 25 - .
  • Opportunity Rover Mars Landing - . NationUSASpacecraftMER.
GAF
    June 2012
Posted by GAF on Saturday, January 26, 2019 9:04 PM
I actually feel like asking "I wonder where Gunter Wendt?"  Kinda lonely around here.
Project Report:
No painting, and just trying to stay warm with the heat pump on the fritz.  Got a small space heater, and the apartment has not fallen below 66 degrees (with a nighttime low of 25.  Luckily, the carbon dioxide levels have remained constant.  Big Smile  Monday I'll have to get the apartment people to send a repair guy out.
I've been cutting wooden sticks and gluing them around the base.  Trying to replicate the look of the Apollo launch platform.  Still got a couple of dozen to attach.  Still, once the top is detailed and painted gray, I think it will look rather good.
1956 January 26 - .
  • Satellite symposium. - . Nation: USA. Related Persons: Van Allen. Symposium on "The Scientific Uses of Earth Satellites" held at the University of Michigan under sponsorship of the Upper Atmosphere Rocket Research Panel, James A. Van Allen of the State University of Iowa, Chairman.
1962 January 26 - . 20:30 GMT - . Launch Site: Cape Canaveral. Launch Complex: Cape Canaveral LC12. LV Family: Atlas. Launch Vehicle: Atlas Agena B. FAILURE: Agena B second stage guidance system failure. Failed Stage: U.
  • Ranger 3 - . Payload: NASA P-34 (RA-3). Mass: 327 kg (720 lb). Nation: USA. Agency: NASA. Program: Ranger. Class: Moon. Type: Lunar probe. Spacecraft Bus: Ranger. Spacecraft: Ranger 3-4-5. USAF Sat Cat: 221 . COSPAR: 1962-Alpha-1.
  • Lunar impact probe; missed the moon by 36,874 km and went into solar orbit. A malfunction in the booster guidance system resulted in excessive spacecraft speed. Reversed command signals caused the telemetry antenna to lose earth acquisition, and mid-course correction was not possible. Some useful data were obtained from the flight. Of four scientific experiments only one was partially completed: gamma-ray readings of the lunar surface. Attempts to relay television pictures of the moon and to bounce radar signals off the moon at close range were unsuccessful.
1967 January 26
  • NASA planned to form an "embryonic space station" in 1968-69 by clustering four AAP payloads. - . Nation: USA. Related Persons: Mueller. Spacecraft Bus: Skylab. Spacecraft: Orbital Workshop.
  • At a NASA Hq briefing, Associate Administrator for Manned Space Flight George E. Mueller stated that NASA planned to form an 'embryonic space station' in 1968-69 by clustering four AAP payloads launched at different times. The first mission would be the launch of a manned spacecraft followed several days later by a spent S-IVB stage converted into an OWS. After the two spacecraft had docked, the crew would enter the Workshop through an airlock. Twenty-eight days later they would passivate the OWS and return to Earth in their spacecraft. In three to six months, a second manned spacecraft would be launched on a 56-day mission to deliver a resupply module to the OWS and to rendezvous with an unmanned ATM, the fourth and last launch of the series. The cluster would be joined together using the multiple docking adapter. Emphasizing the importance of manning the ATM, Mueller said that 'if there is one thing the scientific community is agreed on it is that when you want to have a major telescope instrument in space it needs to be manned.'
GAF
    June 2012
Posted by GAF on Saturday, January 26, 2019 9:09 PM
Been going through a bunch of stuff and found these.  Got quite a few, but not a complete set.  Sad
Anyone remember these?
Gary
    July 2014
Posted by Bakster on Sunday, January 27, 2019 3:15 PM
GAF
Been going through a bunch of stuff and found these.  Got quite a few, but not a complete set.  Anyone remember these?
Hey Gary-- for some reason I didn't get an email about your post. Here we go again. Son of a ...
I have to say that I don't remember those cards. Did they come with bubblegum?
    July 2014
Posted by Bakster on Sunday, January 27, 2019 3:30 PM
My X-1 office is pretty much done.
The fuselage is not glued, just for show.
Next on the roster? I decided to make an LED light cluster and mount them behind the jet exhaust. I don't know if it'll be worth the effort in terms of effect. What the heck--why not try it. It won't add too much of a time suck.
    June 2018
Posted by DRUMS01 on Sunday, January 27, 2019 7:39 PM
WOW, your X-1 is looking X-cellent!
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
GAF
    June 2012
Posted by GAF on Sunday, January 27, 2019 7:55 PM
Bakster> Yep, the e-mail notification is down again.  Bummer!  And yes, those are bubblegum cards from the 70s.  A set of around 100.
Your X-1 pit is looking fantastic!  I bet the led lighting will look just as good!
Gary
PS> Hoping tomorrow will be nice and allow me to get some painting done before the big storm hits Tuesday.  Still having to watch the heat pump, however.  Heat is a bit iffy.
GAF
    June 2012
Posted by GAF on Sunday, January 27, 2019 7:59 PM
In Memoriam:
1967 January 27 - . Launch Site: Cape Canaveral. Launch Complex: Cape Canaveral. LV Family: Saturn I. Launch Vehicle: Saturn IB.
    July 2014
Posted by Bakster on Sunday, January 27, 2019 10:38 PM
DRUMS01
Ben
Thanks Ben!
    July 2014
Posted by Bakster on Sunday, January 27, 2019 10:39 PM
Thanks Gary...
    July 2014
Posted by Bakster on Sunday, January 27, 2019 10:49 PM
GAF
Those were the days when just a few bucks got a person so much. Those cards are cool, Gary. Who knows... I may have bought them too, I just don’t recall. I used to buy bubblegum cards as well. I don’t have a single one of them of them now. They are long gone. Kudos that you saved them!
    July 2014
Posted by modelcrazy on Sunday, January 27, 2019 10:56 PM
I just hate the thought of losing those men in Apollo 1, especially that way.
Poor Gus just had all kinds of bad luck in the program.
Steve
Posted by Gamera on Monday, January 28, 2019 11:36 AM
Gary: Cool work there on the platform. It's going to look perfect under a coat of paint.
And cool cards there, funny I always remember Schirra from an aspirin commercial he did back in the '80s...
Bakster: Great job there on the X-1 cockpit. And the LED sounds awesome. Are you going to add some cotton balls for the smoke billowing out of the rocket?
BTW: I visited the Apollo 1 fire pad years ago on a NASA tour. One of the most friggin' depressing places around. Turned cloudy and overcast when we pulled up...
