Strategic Air Command (SAC) Group Build II
dmk
    September 2008
Posted by dmk on Wednesday, January 7, 2009 9:25 PM
 DesertRat wrote:
Always a good excuse to Polish up on the NMF skills! I for one will be doing it for the first time! I may very well be tapping you guys on advice when it comes painting timeBlush [:I]
I just thought of something. With all these big SAC birds, this GB is probably going to consume most of the current supply of Alclad and Metalizers. Burger [BG]
 I'd better hit up my supplier before you guys buy it all!  Whistling [:-^]
    February 2007
Posted by DesertRat on Wednesday, January 7, 2009 9:52 PM
Yeah, and I'm only going to account for maybe half of thatWhistling [:-^]
Warmest regards,
Roger
    September 2008
Posted by WarHammer25 on Thursday, January 8, 2009 6:39 AM
Well, with two 1/72 B-36's, one 1/72 B-52, and one 1/48 B-58, the supply of Alclad and Metalizers should drop significantly. Big Smile [:D]
The only easy day was yesterday - U.S. Navy Seals
    August 2006
Posted by HawkeyeHobbies on Thursday, January 8, 2009 8:19 AM
 BUFFbuff wrote:
 HawkeyeHobbies wrote:
I'm in...I've got several kits on the shelf ready to start that are part of my SAC collection...for sure I'll be doing an EC-135 that my dad served aboard, callsign: "Grayson" which was based out of Westover AFB, MA.
I've got several  (some mulitiples of) -135, B-52, B-47, B-36, B-58 as well as many others on the list of aircraft that qualify.
8th AF ABNCP no doubt, huh? When was he there? Was he part of the CP crew or the flight crew? Just curious.
He was part of the CP crew...it would have been '69-71 In those years he worked from three locations...base command post...the "Notch" alternate command post or aboard the Grayson.
Gerald "Hawkeye" Voigt
    February 2007
Posted by DesertRat on Thursday, January 8, 2009 12:29 PM
And Alclad is the official sponsor of the SAC GB II!Smile,Wink, & Grin [swg]
Warmest regards,
Roger
dmk
    September 2008
Posted by dmk on Thursday, January 8, 2009 12:39 PM
Cool!  Do we get a member discount?  Tongue [:P]
    February 2007
Posted by DesertRat on Thursday, January 8, 2009 12:41 PM
Sigh [sigh]If only...
Warmest regards,
Roger
    March 2007
Posted by MattSix on Thursday, January 8, 2009 4:08 PM
I think the US supply of Future will take a big hit too! Laugh [(-D]
    February 2007
Posted by DesertRat on Thursday, January 8, 2009 4:37 PM
Oh, Negative!!!!!!!!!!
I've got enough future stockpiled to clear coat a house! (Not that I ever would)Whistling [:-^]
Of course, I'm only speaking for myself...Wink [;)]
Warmest regards,
Roger
    March 2007
Posted by bondoman on Friday, January 9, 2009 1:42 PM
Whoops, Spike! Mr. Hawkeye there is the purveyor of a fine competing product, which his modesty keeps him from advertising, but I would say honestly this would seem like a fine time to ask Gerald about acrylic nmf. Alas, my subject this time around is black.
Hey, and do you guys have a project list up?
    March 2007
Posted by MattSix on Friday, January 9, 2009 2:14 PM
I plan on using the Talon Acrylics Aluminum and Dark Aluminum on my F-86d.
The Talon line of paints produce some awesome results! Big Smile [:D]
    February 2007
Posted by DesertRat on Friday, January 9, 2009 6:59 PM
Really? I had no idea there was anything else in the way of options! I'll send an inquiry here in a bit...
I've incorperated the project list into the first post. That seems to be the way to do it hereBlush [:I]
Warmest regards,
Roger
    August 2006
Posted by HawkeyeHobbies on Saturday, January 10, 2009 5:00 PM
Started my first of a couple (I hope) builds for this GB. AMT 1:72 EC-135C.
One of the challenges are the inside of the engines, removing the injector marks...they're visible both on the intake and exhaust ends of the engine. I use two tools in my Dremel, a small sanding drum and a round ended deburring bit to remove them with minimal effort.
Another issue to deal with is to make the mid wing seam (underside) disappear...even with it being "under" the # 2 & 3 engine pylons doesn't make hiding it any easier...but I'm up to the task.
    March 2007
Posted by bondoman on Saturday, January 10, 2009 11:18 PM
That is a nice project. I wish I could find one- the KC and C- series get underrepresented.
It looks like the Heller wing combo- center under, one piece uppers each side, under on the ends. I found the best method after knocking out a couple three Constellations was to put the under center in the fuse, then glue on the uppers against the fuse, then tailor the under ends to fit. Usually involved trimming off all the locator pins.
    August 2006
Posted by HawkeyeHobbies on Sunday, January 11, 2009 7:07 PM
This is the AMT kit...I have several. The -135R has been rerelease by Italeri...grab them while you can. I hope they do the A model again too...I'll be grabbing a couple more of those.
    August 2006
Posted by HawkeyeHobbies on Sunday, January 11, 2009 9:40 PM
I had a KC-135A in the spares stash...so I decided to pull it out and breath new life into it. I'll have to pick through the spares to see if I can find the missing parts...doors and a few other odds and ends.
It has a wild camo pattern on it, but my plans are to scrub her down and repaint it in a NMF. I start by wet sanding...I use Windex as a solution to suspend the sanding dust.
I'm going to back date this some to an early A before the reenforcement ribbing was added...primarily since I have to sand it down to repaint and the ribbing is going to see some wear and tear in the process.
I'll also rework the refueling boom/pod some to make it a pure C-135A. I'm using my micro razor saw to fillet the aft end of the boom fairing.
    March 2007
Posted by bondoman on Sunday, January 11, 2009 9:47 PM
That was a wild color scheme.
How are the ribs going to be recreated? semi circular scraping? What primer and color do you use for the nmf, which I would assume is Talon? I'd like to see the correct boom arrangement.
Reminds me of the title sequence for "Dr. Strangelove", which is a good source for a close in downward view on a B-52 front end.
    January 2009
Posted by BUFFbuff on Sunday, January 11, 2009 11:40 PM
So, if it's going to be an early A model, are you going to shorten the vertical fin and the horizantal stabs too?  I've done this to several.  It's a lot of work to make it look right, but I find that the wing antennae from the EC-135C, which closely, if not exactly replicate the fin cap on the early A's make a good basis for modifying the bird.  Of course, you have to trim the tall tail, and splce the fin cap after cutting the cap to wing fillet from it.
    August 2006
Posted by HawkeyeHobbies on Monday, January 12, 2009 7:33 AM
Someone wants me to covert it into the prototype version...giving that some thought.
    January 2009
Posted by BUFFbuff on Monday, January 12, 2009 10:08 AM
Oooooo! That's a neat idea - would that be like the 367-80 prototype with short fin, snub nose and what I like to call the 'Hot Dog' paint scheme (you know the yellow and red Boeing scheme), or as 55-3118 with "City of Renton" and photo-shoot markings.  Either way, pretty cool.
    February 2007
Posted by DesertRat on Tuesday, January 13, 2009 11:16 AM
Now that's quite a refurbishing, Hawkeye!
I don't understand why, but part of me is sad to see the wild camo scheme go though
Warmest regards,
Roger
    January 2007
Posted by Pavlvs on Wednesday, January 14, 2009 1:14 AM
Mr. Rat (or may I call you Desert)
My Aardvark kit is the Academy F-111E, Is there a major difference between that and the FB-111? Does the 'E still count for this GB?
Deus in minutiae est. Fr. Pavlvs
On the Bench: 1:200 Titanic; 1:16 CSA Parrott rifle and Limber
On Deck: 1/200 Arizona.
Recently Completed: 1/72 Gato (as USS Silversides)
dmk
    September 2008
Posted by dmk on Wednesday, January 14, 2009 6:56 AM
 I'm not too sure of all the external differences. I do know that the FB has longer wings and a longer fuselage. It is quite a different bird actually.
 The FB-111A is the only F-111 varient to serve with SAC and they didn't even have too many of those.  The other USAF F-111s served with Tactical Air Command (TAC). Australia also had some F-111C and F-111G aircraft. They may still have them.
 Here's some info on the FB-111:
http://home.att.net/~jbaugher1/f111_9.html
And the whole F-111 series:
http://home.att.net/~jbaugher1/f111.html
    March 2007
Posted by bondoman on Wednesday, January 14, 2009 10:47 AM
Thanks much for that good info, dmk. It'll really help me too.
    August 2006
Posted by HawkeyeHobbies on Thursday, January 15, 2009 11:04 AM
I mentioned the SAC GB in my blog post this morning...including a third possible build I might get done for it. ;-) Linky at bottom under signature.
    January 2007
Posted by Pavlvs on Thursday, January 15, 2009 1:04 PM
To remove all confusion, I acquired a 1/48 B-58 Hustler and a cockpit detail set. It is back to plan A with the Hustler. Sorry about all of the bouncing around. I am going to build the F-111 at the same time.
    February 2007
Posted by DesertRat on Thursday, January 15, 2009 9:14 PM
Actually, Roger will do just fineWink [;)]
   He is correct. That particular variant of the F-111 was not used in SAC. It looks like it was used in TAC (and late AMC). But the FB varient was the one used in SAC. After a quick search, it looks like Academy does make that varient in kit form (though I don't know the scale offhand)
Warmest regards,
Roger
    February 2007
Posted by DesertRat on Thursday, January 15, 2009 9:15 PM
Thumbs Up [tup]Cool [8D]
Warmest regards,
Roger
    February 2007
Posted by DesertRat on Thursday, January 15, 2009 9:16 PM
That's awesome! Free publicity is a wonderful thing!Wink [;)]
Warmest regards,
Roger
    September 2008
Posted by WarHammer25 on Friday, January 16, 2009 6:39 AM
Academy's FB-111 is 1/48. According to my research, only the FB-111A/F-111G served with SAC. All other variants were part of TAC. The FB-111A/F-111G was used to replace the B-58 and early B-52. When the B-1 Lancer was introduced, the FB-111A/F-111G became surplus to SAC.
