Official Harrier GB
Posted by VanceCrozier on Wednesday, September 7, 2011 7:27 AM
OK, with all that detail work he does, I'm starting to think bsyamato is actually working in 1/48 and has abnormally large fingers!!! Wink Looking good again buddy. I made some progress over the weekend, mixed & sprayed my first coat of overall gray on the Harrier. (I had some RLM grau-violett already mixed, I started with that as a base. If I don't like the final look of the colour I'll have to do a tint-wash afterwards to dirty it up some.)  Pics later,
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2008
Posted by bsyamato on Wednesday, September 7, 2011 1:23 PM
Ops!! you uncovered my secret Propeller my height is about 2,50 mt
Posted by VanceCrozier on Wednesday, September 7, 2011 1:46 PM
I knew it!!!! Wink
    October 2010
Posted by Casper the Chihuahua on Thursday, September 8, 2011 11:51 PM
I got my Flightpath Sea Harrier FRS1 upgrade set in the post today. Very nice!
5 sheets of beautifully detailed brass PE, some lovely resin wheels and AIM Sidewinder missiles, film for the IP and 3 bags of cast white metal. A lot of the ejector seat and landing gear is to replaced with this.
This drool-worthy stuff! Yes
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    October 2009
Posted by jetmodeler on Friday, September 9, 2011 6:04 AM
http://i1093.photobucket.com/albums/i438/smcintyre11/Harrier%20FRS1/d00a20a3.jpg
Cheers
WOW! Your going at this one full force. lolStick out tongue
Posted by VanceCrozier on Friday, September 9, 2011 6:54 AM
Cheers
That is indeed a nice pile of goodies. That should look spectacular in 1/24!! Yes
    August 2009
Posted by TREYZX10R on Friday, September 9, 2011 9:54 PM
Casper that is going to be a serious build for sure, ca'nt wait to see it start coming together!
Posted by VanceCrozier on Monday, September 12, 2011 7:15 AM
Ahhhh - this is where my brain cramps up from lack of modern jets. (That's my excuse anyway!!) I'm using Tamiya acrylics in the airbrush, wanted to have some parts in place before spraying to avoid tricky touchups. I mounted the outboard weapons pylons & then sprayed.... then last night realized that the pylons sit over top of the underside roundels!! Bang Head I guess I'll have to do some decal slicing!
    October 2008
Posted by bsyamato on Monday, September 12, 2011 6:25 PM
... and after use the chainsaw to cut some wood for the winter Whistling
Posted by VanceCrozier on Tuesday, September 13, 2011 7:27 AM
That's never a bad idea around here! Yes
    October 2009
Posted by jetmodeler on Tuesday, October 11, 2011 6:18 AM
Casper I just realized I forgot to add you to the front page, but your add now.
    October 2008
Posted by bsyamato on Tuesday, October 11, 2011 5:23 PM
LOL Big Smile
effectively an 1/24 harrier is so hard to see Toast
Posted by VanceCrozier on Thursday, October 13, 2011 7:27 AM
NOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!
In the home stretch on the Sea Harrier. Landing gear getting painted up, decided to add some of the blade antennas last night. Added glue to one of the ones behind the cockpit, started to move it into place & dropped it on the painted surface. No problem, I grab it quickly with fingers, put it back into the tweezers, pick up the plane & carry on.
Then I realize that...
  • I had a little smudge of glue on my thumb
  • my thumb happened to fall exactly where the RN decided the roundel should be placed
  • perhaps my flat coat wasn't thick enough
  • Airfix decals MELT when touched by Tamiya liquid cement
  • my red + blue smudgy thumbprint looks nothing like a RN roundel
With no spare roundels that match up (small, red+blue only), I'm thinking of gently sanding out the worst of the smudge, then just overpainting the base-colour gray. Thoughts?
    October 2008
Posted by bsyamato on Thursday, October 13, 2011 10:38 AM
Smile at least you're at good point to finish, i am again on the cockpit, just the ejection seat was primed in black Yes
    October 2009
Posted by jetmodeler on Friday, October 14, 2011 6:30 AM
VanceCrozier
Thats probably what I would do. For the roundel you could mask and paint the colors for it.
Just an idea.Idea
Posted by VanceCrozier on Friday, October 14, 2011 7:21 AM
Mine was more of a "rushing to do something before I had to leave the house" accident, but it still means a mess to clean up!
Pics!
Port side before the glue issue, it looks so happy!! Also before the "mist coat" I applied to dull down the decals which looked too bright for the Falklands planes.
The underside decals, after I sliced & applied the roundels in halves...
The rest are "after the mist coat" . I think I like the effect, maybe took it a little far in places. Note the brass rod replacing the kit pitot tube.
Blade antennas in place...
And the screwed-up port-side roundel - what a mess! Dead
BUT, I think I found the solution sitting in the same box, combining roundel decals from the two other options seems to measure out at the right sizes. I'll try it on a blank piece of styrene first just to make sure, but this is the plan:
Posted by VanceCrozier on Tuesday, October 18, 2011 10:41 AM
Alright, my replacement "decal sandwich" seems to have worked. I applied the white + blue roundel two nights ago, let it sit & applied the smaller blue & red roundel over it last night. I'm sure you could see it close-up, but after I give it a quick spray of the gray filter, only I will ever know. (Well, and you guys too I suppose!) Pics with next update.
    September 2003
Posted by Helo H-34 on Thursday, October 20, 2011 7:42 PM
Hi everyone ;
I've been watching from the side lines all the great work you guy's are doing with your Harrier builds ,
Awesome stuff...Toast
I dropped out of a lot of Group Builds earlier in the year because of time and family issues , however it's really tempting to want to join in with everyone else .
I have a few 1/72 Harrier's in the stash and I've built two about three years ago , so perhaps it's time for another . Here's a pic of the stash ;
The easiest way would be to build one straight out of the box , however I alway's seem to want to do things the hard way and after looking through Squadrons Harrier in action book , I saw this pic of an YAV-8C ...
According to the caption it appears to be a AV-8A Harrier with what looks to be some additional strakes under the gun pods ?
So I was thinking of using one of my Esci AV-8A kits as they have the correct shaped horizontal stabilizers ;
Anyway , I kindly ask if I may join in with everyone else , if my first idea doesn't work out , I can always just build one OOB .
                          John .
    August 2009
Posted by TREYZX10R on Thursday, October 20, 2011 8:21 PM
Vance I hope the fix works out that is a great looking build. Pitot tube looks great as well
John Wow now thats a stash!!!
Posted by VanceCrozier on Friday, October 21, 2011 7:48 AM
TREYZX10R
HAH - the pitot tube! That was a "necessity is the mother of invention: moments. The shape on the kit-suuplied part looked fine, but I snapped the bloody thing as I was trying to sand off a pour-stub attachment point. A scrap of plastic, brass rod & CA to the rescue!
Took off the mangled decal by sanding and "flaking" it off with a sharp exacto blade. The portions that made their way inside the intakes were left alone, I just figured I was asking for trouble if I played with thhat area too much. Added a brush-coat of Future & left to dry a few days.
A Harrier with blue+white roundel... interesting look!
And the smaller red+blue roundel fit inside the white area perfectly, just a little touch of overlap.
A little MicroSol and slicing helped it settle into place, again. I'll give it a light overspray this weekend. The exhaust nozzles have since been painted a burnt-metal.
    October 2008
Posted by bsyamato on Friday, October 21, 2011 10:29 AM
Magnific harrier stash Helo Yes what's the best 1/72 shaped kit between this stash by your opinion?
The av-8 prototype is really intresting as subject
Vance nice progress and saves there. Why you don't glued the windscreen before the pitot?
Posted by VanceCrozier on Friday, October 21, 2011 10:35 AM
Windscreen - I'm not really sure to be honest! I was thinking I should keep it off until after the last mist-coat over the new decal... but I really should mask the cockpit (or the windscreen) before doing that anyway... I should have this wrapped up on the weekend though.
Then, on to the Pucara!
    October 2008
Posted by bsyamato on Friday, October 21, 2011 10:44 AM
pucara sounds good Stick out tongue
the danger about to put the windscreen after to finish all is a possible differences between the frames and aircraft surfaces.
Posted by VanceCrozier on Friday, October 21, 2011 10:47 AM
I airbrushed the windscreen frames at the same time as the airframe, they just need to be attached. I should be alright. (But I usually do attach glass first, paint after.)
    October 2008
Posted by bsyamato on Sunday, November 6, 2011 11:38 AM
here some progress on the gr3
... the ip with macro seems a christmas tree Tongue Tied
aargh! the super etendard cockpit and ip was better, it's time to get some magnifief to paint these parts.
the cockpit
hope the weathering/washes will resolve the christmas aspect, that's all for today
    October 2008
Posted by bsyamato on Friday, November 11, 2011 9:10 AM
Updates from the gr3
i washed the cockpit.
On the ip tried something differents , i read here (don't remember the post) someone used gloss coat as glue for little pices, then searchin a good way to simulate instruments glass i proceded so:
after scratched the ip details on the black background i painted it with clear gloss and put on the upper part of ip Propeller
Also added and drybrushed the rudder pedals (scratched too)
Also added the ejection handle on the seat (a metal wire)
then i drilled the lateral camera "eye", and put from the inner side a piece of heated clear sprue ,removed the IR sensor on the nose to put something after .
and painted the inner nose with flat black .
then all main parts are glued!
the fit is not perfect here Sad
that's all for now Headphones
    October 2008
Posted by bsyamato on Sunday, November 13, 2011 5:40 AM
GR3 updates.
Consulting some reference on internet, the italeri kit miss some piece from the falkland operative harriers,
mainly a sensor cover on the nose with an antenna, and chaffs dispenser rear the airbrake, both resolved, but the front fuselage really have a baaaad fitting, lots of putty needed to resolve and also a plastic piece to resolve a step under the cockpit between the two semi-fuselage pieces. And another inaccuracy (not only from falkland units) . The front gear have a too large little well door, when the gear is out the space opened is just the middle than on the kit . Iresolved with a plastic piece on the back of the gear and reduced the rear hole.
the pictures
the step and the gear correction
after sanding and added the nose sensor cover
lots of putty
the chaff dispensers
also started to engrave more the panel lines, they are perfect for the airbrush but with brushes i risk to cover all the lines Sad
a last shot before to paint it with 144 that will go even as primer
that's all folks (Whistling) !
Today i'm feeling better withouth the B clown Whistling
Posted by traveller on Wednesday, November 16, 2011 1:04 AM
Just in the middle of a TSR-2 Airfix group build, and doing an MQ-9 Reaper for fun. 1/48 Tamiya Sea Harrier, with my own spin on it is my next project in conjuction with an IDF F-16C. Should be funSmile
    October 2009
Posted by jetmodeler on Wednesday, November 16, 2011 6:14 AM
Wow, I've been gone for a while. Great work so far everyone.
Helo~ You've been add to the group build.
Traveller~ Sounds great. Did you want to add both kits to the GB?
Posted by Anonymous on Wednesday, November 16, 2011 7:12 AM
VanceCrozier
Pics!
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1375.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1374.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1377.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1379.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1426sm.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1429sm.jpg
Blade antennas in place...http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1424sm.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1428sm.jpg
http://i1012.photobucket.com/albums/af250/VanceCrozier/Falkland%20Islands%202012%20Group%20Build/IMG_1430sm.jpg
Hey, is that one of those new-tool Airfix Harriers?  I just bought two and they look cherry in the box...
