Japanese Group Build Part III
    January 2004
Posted by congo79 on Thursday, May 29, 2014 12:34 PM
Hi guys,
I'm slowly going forward with my builds. The Dinah is on hold for now as i'm short on supplies and, as it turned out, i have to refresh my soldering abbilities which at the moment are crap. However th Val is going ok and already has paint on it. Even though it is a Hasegawa mould it was fighting me all the time throughout the build. Nasty seams appeared here and there and on top of that they were hard to fill and sand. After priming and painting the model i realised that i forgot to put the pitot tubein the wing so, as you will see in the pics, i had to glue the base in the painted wing, fiil, sand and drill and than repaint. With my luck the paint /Tamiya acrillic/ reacted strangely - instead of flat finish it turned out glossy and didn't want to dry for more than a day.
As for the paint itself, i did a lot of head scratching and finally desided to paint the Val IJN grey. I'm not sure for the supoosed "caramel" colour and were not ready to experiment after all the fight that the model was giving me in construction. I primed the model with Alclad grey primer which was slightly polished before puting the paint on. I've preshaded the Val with Tamiya black and then put on two light coats of IJN grey. Then i started postshading. On the upper surfaces i mixed IJN grey with a bit of japanese cockpit green as i wanted not to lighten the paint but alter the shade. I was satisfied with the result. On the downside surfaces i went with lightening the grey with white. the whole idea is to represent an used and abused Val somwhere in the spring of 1942. But enough writing, it's time for pics, just don't expect much from a crappy photographer Wink .
i880.photobucket.com/.../P5270762.jpg
i880.photobucket.com/.../P5270763.jpg
i880.photobucket.com/.../P5270764.jpg
i880.photobucket.com/.../P5270766.jpg
i880.photobucket.com/.../P5270768.jpg
i880.photobucket.com/.../P5270769.jpg
i880.photobucket.com/.../P5270770.jpg
i880.photobucket.com/.../P5270771.jpg
i880.photobucket.com/.../P5270777.jpg
i880.photobucket.com/.../P5270779.jpg
i880.photobucket.com/.../P5270782.jpg
i880.photobucket.com/.../P5270783.jpg
I forgot to mention that the blue black on the cowl is Agama enamel which in my oppinion is the best enamel paint i have ever encountered.
Posted by Gamera on Thursday, May 29, 2014 1:55 PM
Congo: very nice job pre-shading there! The engine doesn't look half bad either!
    April 2006
Posted by jgeratic on Thursday, May 29, 2014 11:45 PM
Hey guys, great updates there. Yes
I think the current accepted shade for the IJN of WWII is close to the Luftwaffe's RLM 02 - or is at least used as a starting point?
Johnsan - thanks for the approval on the trainer I had recently completed.
regards,
Jack
    February 2007
Posted by Lodni Kranazon on Thursday, May 29, 2014 11:56 PM
Very nice Val there, Congo!
[Admiring Starbuck's space fighter] Cassiopeia: It's a perfect machine! Born to dance amongst the stars! Starbuck: Yeah, it's bumping into them that has me worried.
    October 2008
Posted by bsyamato on Friday, May 30, 2014 6:03 AM
Great work on the Val Congo Yes
Please use the "direct link" from photobucket and paste in the image button option during the posting to show pictures in the thread :)
    January 2013
Posted by jibber on Monday, June 2, 2014 12:59 PM
    February 2014
Posted by silentbob33 on Monday, June 2, 2014 3:01 PM
Looking good Jibber, can't wait to see more
On my bench: Academy 1/35 UH-60L Black Hawk
    February 2007
Posted by Lodni Kranazon on Tuesday, June 3, 2014 12:09 AM
Very cool, Jibber!
A slight update - still working fit issues on the tail section but will finish that up tonight so I can start making some semblance of a cockpit. Put the bang seat together so that I know how much room I have to work with. I will be pretty much copying the Hasegawa cockpit with sheet styrene and have good Intrument Panel & Console decals to use.Cool
    October 2004
Posted by ygmodeler4 on Tuesday, June 3, 2014 12:17 AM
Looking great guys...won't be too long and I'll finally be able to get my zero on the bench for more than a couple minutes.
-Josiah
Posted by Gamera on Tuesday, June 3, 2014 7:29 AM
Terry: Looking forward to seeing her all painted up.
WW: Looking forward to seeing what you're coming up with too. Never really modified a kit much myself. Added some PE here and there but that's about it.
Posted by Gamera on Tuesday, June 3, 2014 6:21 PM
Nice! Even if the pre-shading doesn't show though a wash should pick out all that detail!
    January 2013
Posted by jibber on Tuesday, June 3, 2014 7:33 PM
I was going to try again with some dark on the panel lines then a light coat to tie it together?
    February 2007
Posted by Lodni Kranazon on Tuesday, June 3, 2014 7:44 PM
Terry, that tank is really coming along!
I will not be doing anything fancy in the Starfighter cockpit - pretty much just putting something in there to support the IP & console decals and have a floorboard! Stick out tongue
Posted by Gamera on Wednesday, June 4, 2014 7:29 AM
WW: Ah, sorry I thought you meant you were adding a little more- my mistake!
    July 2004
Posted by stikpusher on Thursday, June 5, 2014 11:59 AM
Wow.... some fabulous work in here all around! I had not checked in on daily progress for awhile. So I just went back and scrolled thru the whole GB up until now. Stunning work all around! I obviously need to keep up to date daily in here...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Gamera on Thursday, June 5, 2014 12:07 PM
Yeah, the guys have been kicking tail and taking names- reminds me that I really need to get my stuff done!
    October 2008
Posted by bsyamato on Saturday, June 7, 2014 1:07 PM
A poor update :( just a layer of thinned 147 as primer and 147+78 humbrol  on the bottom.. not easy to see the differencies from pictures with flash Huh?
At the next!
    July 2004
Posted by stikpusher on Sunday, June 8, 2014 1:37 AM
Gamera
get it done? I still need to get started....Embarrassed
       - Plankton
LSM
    February 2007
Posted by Lodni Kranazon on Monday, June 16, 2014 12:37 AM
 Very nice work guys! Not too much of an update. Did finally get SOMETHING of a cockpit into the Starfighter and some primer paint on it. Initially, there was NOTHING but a poorly-molded fetal-position guy in the area that the cockpit was to occupy! The Super Sabre & Mig-21 are two other on-line separate builds. LOL Cool
    March 2006
Posted by simpilot34 on Monday, June 16, 2014 3:57 AM
Hey guys, hope I can join in. It's been a great while since I have actually had any bench time but getting back into it. I started a 1/72 Hasegawa E7K1 'Alf' floater a couple years ago. Got fuse and bottom wing plus tail but still lots to do. Will send some pics of where I am atm for you to decide soon. Cheers!
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
Posted by Gamera on Monday, June 16, 2014 11:19 AM
WW: Ohhh nice work on all of them! And good idea on using wooden sticks to hold the ejection seats while painting.
Simpilot: That should be fine, this is a fun GB and I've never been very strict on the rules. You're more than welcome to hop in if you'd like!
    March 2006
Posted by simpilot34 on Monday, June 16, 2014 4:41 PM
Cheers, will hop in and hopefully get her done. Thanks heaps!
    March 2006
Posted by simpilot34 on Tuesday, June 17, 2014 6:18 PM
That looks great man! I've always been a lil timid trying that wash technique for some reason, the results I keep seeing makes me want to take the plunge and give it a go.
    March 2006
Posted by simpilot34 on Tuesday, June 17, 2014 6:34 PM
Well here are a couple pics of the 'Alf", and the box. this is basically how it sits now just with a primer coat, will of course post more pics when there is visual progress. By the way, does anybody have a good technique to add ribbed fabric look back, sanded a bit off when filling the join on a part for the fuse, Was think thin sprue with a mr. surfacer filler maybe?
i300.photobucket.com/.../002-42.jpg
i300.photobucket.com/.../002-43.jpg
i300.photobucket.com/.../001-39.jpg
    April 2006
Posted by jgeratic on Tuesday, June 17, 2014 11:16 PM
Guys, great updates Yes
simpilot34 - plastic strips would be the way to go to replace the area below the rear cockpit, looks like it might be even corrugated metal?  The rest of the fuselage is less angular, so a good brushing of surfacer on some more plastic strips and light sanding should do it.
regards,
Jack
    March 2006
Posted by simpilot34 on Wednesday, June 18, 2014 12:20 AM
Cheers Jack! Yeah that's what I was thinking. No not corrugated there. More like a bread box sliding cover for the rearmost cockpit. Definitely fabric over frame aft and below them.
Posted by Gamera on Wednesday, June 18, 2014 7:34 AM
Terry: That looks fantastic! I've looked over mine a few times but had no idea how to get the thing to look right, I really like how yours is shaping up.
Simpilot: Looks like the typical quality Hasegawa kit there. Looking forward to seeing how she comes out. Sounds like some good advice there from Jack on replacing the detailing.
