PACIFIC CARRIER AVIATION GROUP BUILD
    October 2004
Posted by ygmodeler4 on Thursday, June 26, 2014 9:48 PM
this is first thread I found in the "decal" forum.
cs.finescale.com/.../159139.aspx
I'm sure there's many more, unfortunately though I do not personally have an answer
-Josiah
    February 2014
Posted by silentbob33 on Thursday, June 26, 2014 10:02 PM
Thanks Josiah. I just took another look at it and I can see where the panel lines are now, but it still isn't going in. I'll see how it looks tomorrow.
On my bench: Academy 1/35 UH-60L Black Hawk
    October 2004
Posted by ygmodeler4 on Thursday, June 26, 2014 10:15 PM
yeah I just use model masters decal set but its not great. I've heard micro sol is good but I've never tried it....I always just put the decals on and if they aren't perfect I say oh well....but thats cuz something usually goes wrong before the decals or right after ha!
-Josiah
    August 2009
Posted by JOE RIX on Thursday, June 26, 2014 10:36 PM
Bob, What are you using for a setting solution? I use solvaset and it works very well. Although, I just purchased some of Humbrols new setting solution at the advice of the owner of my nearest LHS. The video on it is rather impressive. Another thing you can do is to very very carefully run an xacto blade along the panel lines through the decal, essentially cutting the decal along the lines. Better yet is if you have a round blade that you can roll along the lines. Then apply setting solution. This will aid the decal in conforming to the contours.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    February 2014
Posted by silentbob33 on Friday, June 27, 2014 6:31 AM
I'v'e got a bottle of Model Master's setting solution.  I've thought about running a knife along the panel lines, and that would work except for a circular hatch that's covered by the national insignia on the fuselage.  I'll take a look at it later today to see how it looks.  I'll have to look into some solvaset though.
    August 2009
Posted by JOE RIX on Friday, June 27, 2014 9:00 AM
Hey Bob, and everyone else , check out this video on using Humbrol's new Decal Fix. I will be trying this stuff out for the first time on my Hellcat. Hopefully it works as advertised.
www.youtube.com/watch
Also Bob, should you get some Solvaset, which is awesome by the way, be sure to test it on the decals you will be using as it is very hot stuff and you want to make sure that your decals will react favorably to it.
    February 2014
Posted by silentbob33 on Friday, June 27, 2014 9:57 AM
Good looking out Joe!  If that stuff works as advertised I will have to pick  some up.
    February 2014
Posted by silentbob33 on Sunday, June 29, 2014 9:35 PM
Finished the decals, I never did get the MM setting solution to work.  Looks like I'll be getting some Micro Sol for my next plane with recessed panel lines.  Generally, I'm pretty happy with how it looks.  The flash kind of washes it out, but the preshading looks pretty good, and I'm not sure if I need to do a panel line wash.  I still have some time to make up my mind though.
    May 2013
Posted by hogfanfs on Sunday, June 29, 2014 9:42 PM
Looks really good, SB! The pre-shading turned out very well!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    April 2013
Posted by SchattenSpartan on Monday, June 30, 2014 4:35 AM
She's a real beauty, Bob! Keep up the awesome work!
    August 2009
Posted by JOE RIX on Monday, June 30, 2014 7:46 AM
Your decals and and preshading turned out rather fantastic Bob. I certainly think a wash would enhance your efforts. Although, to me , the tri color scheme presents a challenge. Even though a dark wash would go on the underside white, the upper dark blue is best washed with a light gray. Just seems an odd contrast to me and I struggle with visualizing that. But, I'm certain that I will take that route nonetheless. Great work Bob.
    February 2014
Posted by silentbob33 on Monday, June 30, 2014 3:31 PM
Thanks for the compliments guys!    I agree with you Joe, it's hard for me to visualize how that would look all together with multiple wash shades.  I'm going to try an overall medium gray wash and see how that looks.
    April 2013
Posted by SchattenSpartan on Monday, June 30, 2014 3:52 PM
Yeah, I think an overall gray wash should do the trick...
    January 2011
Posted by Tal Afar Dave on Monday, June 30, 2014 7:18 PM
Hey SilentBob,
That's a killer SBD you got there!!  Awesome job; can't wait to see it finished!!
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    February 2014
Posted by silentbob33 on Tuesday, July 8, 2014 9:13 PM
Well, here she is!  I didn't weather it too heavy because according to the instructions the SBD-5s were pretty new aboard the USS Lexington for the Battle of Tarawa, and neither of the aircraft represented by the provided decal sheet survived the battle as they were written off due to hard landings.  I'm pretty happy about how she turned out.  I'm going to have to keep an eye out for more Accurate Miniatures kits at shows.
    August 2009
Posted by JOE RIX on Wednesday, July 9, 2014 12:50 PM
Yay Buddy! That there is a beauty Bob. Simply excellent work there. I especially like how you considered the history and service length and applied it to the weathering. Very well done. It's kind of difficult for me to tell for sure from your pics but, did you go without applying a wash? Either way Bob, you should be quite proud of your finished Dauntless. I greatly appreciate you taking the time and effort to share your build and skills with us. You know, there is plenty of time left as well as plenty of 1944 subjects for you to stick with us for another round. Just sayin'.
    February 2014
Posted by silentbob33 on Wednesday, July 9, 2014 1:18 PM
Thanks Joe!  I did end up doing a gray wash, but it's hard to see in the pictures.  Probably a combination of bad lighting and my poor photography skills.  I may be back if I can meet all my other commitments.  I do have some other kits in the stash that would work though...Wink
    September 2003
Posted by checkmateking02 on Wednesday, July 9, 2014 6:46 PM
Very impressive, bob.  Great job all around, but particularly impressive are all those little holes in the dive brakes.  Nicely done!
    October 2004
Posted by ygmodeler4 on Wednesday, July 9, 2014 6:47 PM
Bob that looks wonderful!!
-Josiah
    May 2013
Posted by hogfanfs on Wednesday, July 9, 2014 7:20 PM
Bob, the SBD looks outstanding! Excellent job!
Gentleman,
I am going on vacation later this week, I plan to start on my SB2U once I'm back. Kind of have some inspiration now that Bob has completed his SBD!
Thanks,
 Bruce
    February 2014
Posted by silentbob33 on Wednesday, July 9, 2014 7:48 PM
Thanks guys!  I think it's more the kit than my skills though Smile
    April 2013
Posted by SchattenSpartan on Saturday, July 12, 2014 10:58 AM
Your SBD looks fantastic Indeed, Bob! You actually convinced me to get Academy's re-release of the AM kit! What picture do you want to see on the front page?
    February 2014
Posted by silentbob33 on Saturday, July 12, 2014 6:18 PM
Thanks Clemens!  It was a blast to build.  I think this one would be good for the front.
    August 2009
Posted by JOE RIX on Saturday, July 12, 2014 10:34 PM
Hey Bob, I Like It!!!Yes
    January 2011
Posted by Tal Afar Dave on Sunday, July 13, 2014 8:17 AM
Very impressive job there, Bob.  Thanks for sharing the great pictures!
    February 2014
Posted by silentbob33 on Sunday, July 13, 2014 9:41 AM
Thanks guys!
    August 2009
Posted by JOE RIX on Sunday, July 13, 2014 10:01 PM
Hey There Gentlemen. I've actually got some activity to share. Got the wings on complete with Quickboost gun barrels. A cool aspect of this Eduard Hellcat is that had no need to glue the wings on as they slipped into the slots nice and tight.  Also carved off the molded on exhaust pipes with my Dremel and installed Quickboost replacements. In addition I've utilized PE on the tail wheel, oil cooler vent, belly access hatch and the upper fuselage ID lights. I have yet to install the PE lower fuselage light rings. They are going to be a challenge to get lined up properly as there is no molded features to follow. Not to mention they are very tiny. So, here are some pics of my current status. Thanks for having a look. Any obs are welcome.
    October 2004
Posted by ygmodeler4 on Monday, July 14, 2014 12:47 AM
I can only imagine how small that PE is...and those gun barrels! tiny tiny, looking good though!
-Josiah
    February 2014
Posted by silentbob33 on Monday, July 14, 2014 6:52 AM
Agreed, I can't believe it's 1/72!
    August 2009
Posted by JOE RIX on Tuesday, July 15, 2014 7:42 AM
Thank You Very Much Josiah and Bob. It really is appreciated.
