PACIFIC CARRIER AVIATION GROUP BUILD
    August 2005
Posted by fjs3 on Friday, January 16, 2015 9:48 AM
Here are a couple links to download the Accurate Miniatures instruction sheet for anyone who needs them,
web.archive.org/.../TBM-3D_0121.pdf
web.archive.org/.../TBM_1C_0120.pdf
web.archive.org/.../support.shtml
I know A/M is out of business, but this website is still there.
I hope this helps
Freddie from LI
"I'm gonna build all these models one kit at a time!
    July 2014
Posted by Bakster on Friday, January 16, 2015 1:18 PM
Hey Freddie...thanks for all the great input.  You guys have really boosted my esteem.  When I first started working on this kit I really wondered if my mental faculties were waning some. Since I had been away from modeling for 20+ years, I didn't remember if model instructions were as vague as this or not. I thought maybe it's just me.  These discussions really confirm for me that it's not just me.  Thanks as well for the links.  I have all that data courtesy of Greg, but it's good to have on this forum for other people looking to build this kit.  Nice job with that, Freddie.
    July 2014
Posted by Bakster on Saturday, January 17, 2015 11:27 AM
Greetings folks.  I want to get your opinions. The process of decaling is a short way off for me so I am getting my ducks lined up. As  you probably know by now, this is my first build in a very long time. Having said that, I have to relearn the decal process.   I think I have the basic process in mind when it comes to using Micro Set and Micro Sol.  I have watched videos and read articles.  I am not entirely new to using them either.  I had used them in my past modeling flurry. Still, I built mostly cars at that time and I wasn't dealing with rivets and panel lines.
Here is where the question comes into play.   I have ordered and received a decal sheet that has the markings that I want for this build.  I think they look ok, but I want your opinions on what trouble I might run into.  The markings for this plane are fairly large and they will cover a fair amount of detail.  My concern is about getting the decals to settle into/onto all the panel line/rivet detail without silvering. There seems to be a lot of clear areas between the markings.  You folks are more familiar with this.  Do these seem normal for aircraft decals?  Or am I dealing with something a little out of the norm? The setting solutions "should" handle this correct?
Many years ago I read about how some modelers will trim out all the clear portions of the decals.  I had tried that back then and I found that the process has it's pitfalls.  The worst of them was that any uneven cuts with your knife into the marking area became glaring once the decal was applied to the model. Applying the decals was much more difficult as well.  You really had to play with them in order to get them lined up.  I am sure that with practice a person can make this all work.  I am curious if any of you folks do this.
Lastly... I may even try airbrushing the markings. The markings for this build are one color, and they are fairly simple in shape.  It would seem an ideal project to try it on.   I have just experimented with making masks and with some success. I ran the decal sheet through my computer scanner, scaled the image correctly, then printed it onto paper.  The paper copy is now the underlying layer that I use to work on.  I tried various masking mediums and I have found that Tamiya Masking Tape works the best, and for several reasons. Firstly, the tape is somewhat opaque. I can clearly see the markings through the tape.  This makes it possible to trim the tape accordingly.  Secondly, there is something about Tamiya tape that makes it cut really well. I don't have to press as hard as the other masking mediums I tried and in order to cut through. Thirdly, the tape seems to have the perfect adhesion qualities.  Not too sticky, not too weak.  I was able to pull the tape off the paper without pulling any paper up.  And, the tape still held it's stickiness.  I was able to make some nice clean masks.  The only problem I had though, my tape is not large enough to cover the entire marking.  I did some research and Tamiya sells the tape in sheets, and, you can get them in much wider rolls than I have.  I have ordered both to try.
Sorry for the long read.  Your opinions are appreciated.
Thanks folks.
Steve
    May 2013
Posted by Greg on Saturday, January 17, 2015 12:30 PM
fjs3
I hope this helps
Freddie from LI
Hey Freddie, thanks for those links! I printed those out a couple years back but neglected to save them on my PC and also lost the one about installing the canopy. In the meantime, I couldn't find the liks again Now thanks for you I'm redundantly protected for my future AM TBM second build (kit thanks to a generous friend).
Again, much appreciated. And soon as clear my paper jam, I'll have backup hardcopies of all 3 too!
Sweet work going on here, mates.
    April 2013
Posted by SchattenSpartan on Saturday, January 17, 2015 5:20 PM
Thanks for posting those links, Freddie!
Steve: Now I'm by far no expert on decals, but I'd try cutting out as much of the film as possible. You don't have to cut exactly at the edges of the printed areas, just leave a bit of the clear film on there if you're worried about your cuts not being straight enough...
    July 2014
Posted by Bakster on Sunday, January 18, 2015 8:13 AM
Clemence: thanks for the input. I will consider your thoughts on this.  Very interesting.
    August 2009
Posted by JOE RIX on Sunday, January 18, 2015 9:08 AM
Hey Steve, I regret that I'm a bit late on getting back to you on this. I'll impart what experience I have and maybe you can glean out something that might help.
Yes, It is fairly normal for aircraft decals to have carrier film encompass an area such as yours does. It appears to me that the decal set you have there ( Which set to you have by the way?) is rather nice in that there is very little excess carrier film around the outside edge. Cropped nice and tight, very nice. The best advice I can give you is to select a decal from the sheet that you will not be using, preferably the larger the better, and test it on something that, at the very least, has a similar gloss coat and also has some texture or relief to it. This will certainly give you an idea of how the decal will react to Micro Set/Sol. Also, you will be able to discern if the decal is going to silver on you and if the edges will be readily apparent. I personally use Solvaset for my decals as it tends to be a bit hotter then Micro Set. But, I always test it on a new or unknown set of decals to ensure that the Solvaset will not adversely damage the decals. Thus, I have Micro Set/Sol on hand just for those occasions where Solvaset will not work.
Another tip I offer up is prior to applying the setting solution and after the decal has dried, take a round tipped Xacto blade, like the one you used for your canopy mask, and gently roll it along the panel lines under the decal. This will cut the decal along those lines and allow the decal to more readily conform to recesses and relief.
My hats off to you for your endeavors to create a mask and to paint the insignia. I'll be quite interested to see your results should you pursue that to the end. Glad to see that you are discovering all the advantages that Tamiya tape offers. The stuff is nothing short of pure gold to us modelers.
I hope this helps you out a bit. Good Luck My Friend.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    July 2014
Posted by Bakster on Sunday, January 18, 2015 9:42 AM
Greetings Joe.  Thanks for the opinions and advice.  I will take that all into consideration.
I will update you with regard to the masking method and once I get there.  I really want to give that a serious look.
On a different note.  Yesterday I discovered that two of the tail rudder hinges had broken off during the course of this project.  I had to fabricate a new one out of sprue.  It's glued in and I need to do a little shaping to one end of it. Overall, it came out pretty good.  I plan to glue the tail rudder in place today as well.  If time permits, I may tackle mounting the front engine cowl ring.  Engine cowl Ring may be the wrong name for it but but that's all I got. Maybe someone can educate me on that.  I am fearful of mounting the ring because it will take some patience to get it right.  It does not fit very well and I will have to glue it on in sections to try and get a nice flush join. It is a very visible part of the plane, so I don't want to mess it up.
Speaking of breaking.  I also broke off the antenna. I am debating if I should reattach that now or after painting.  Chances are pretty good that it will get broken again during that process.
Like I said to you, "What doesn't kill us, makes us stronger."
Thank you sir!
Steve
    August 2005
Posted by fjs3 on Sunday, January 18, 2015 10:01 AM
You know Steve, if I don't break off ALL the antenna during a build, then I'm doing something wrong!  LOL!!   I would reattach just before painting, so the paint will match.  It is still possible to break them again during the painting process, but that's what touch ups are for...
I have to head down to the "laboratory" and put some time in on my F4U.  Fuselage is done and I'm working on the wings
Also started the Great Wall TBD, Midway version.  Looks complicated as all heck, but the details are awesome.   Ill post a few pictures.
    August 2005
Posted by fjs3 on Sunday, January 18, 2015 10:05 AM
Hello Schatten,
Are going to do another one of these group builds for the new year?
    July 2014
Posted by Bakster on Sunday, January 18, 2015 11:12 AM
Hey Freddie, Lol.  Well, it's good to know that it's not just me.
Ok then, I will take your advice.  That makes sense. I will wait until I have it all cleaned up, masked, and ready for paint.  Then I will reattach it.
"Laboratory'hey?   I like the sound of that.  I think it would be kind of fun to one day post pictures of our work stations.
The Midway version sounds interesting.
    August 2009
Posted by JOE RIX on Sunday, January 18, 2015 7:21 PM
I GOT IT! I GOT IT! It definitely took some elbow grease and a heavy dose of patience but, I finally got the underside repainted and a nice gloss coat on. Whew, now I can move on to the decals. So, after sanding the extra heavy coat of white down and cleaning out the panel lines I masked around the afflicted areas with Silly Putty and hit it with a coat of Tamiya white primer in order to facilitate solid coverage. I then unmasked and sprayed on a new coat of white. The coverage overall is a little uneven over both wings but, it is acceptable. I then sprayed on a quick light coat of Mr. Super Clear flat. My hopes were that this would eliminate the orange peeling effect of the gloss paint. Then it was time for the moment of truth. After the first couple of light coats of gloss I knew I was in the clear. Thanks for pushing me forward on this gents. I'll let everything cure for a bit before I start on the decals. My next worry will come when I apply a gloss seal coat over the decals. Here's where I'm at now:
    December 2012
Posted by flyerduke on Sunday, January 18, 2015 7:49 PM
Well done Joe!  It's all gravy from here on out.  What squadron decals are you using?
    July 2014
Posted by Bakster on Sunday, January 18, 2015 8:13 PM
Hey Joe....way to go buddy!  You pulled it off man and it looks great! Way to stick with it Joe. It was worth it...
    August 2009
Posted by JOE RIX on Sunday, January 18, 2015 8:53 PM
Thank you flyer d and Steve.
flyer, I am using the markings for "Little Joe" of VF-51 aboard USS San Jacinto (CVL 30)
    February 2014
Posted by silentbob33 on Monday, January 19, 2015 5:51 AM
Great recovery Joe! I've been watching and waiting to see how it would turn out. Way to stick with it
On my bench: Academy 1/35 UH-60L Black Hawk
    August 2005
Posted by fjs3 on Monday, January 19, 2015 7:33 AM
Excellent Job!!  Glad to see you kicked that paint issue right in the a.... I mean butt!!   Can't wait to see her done, because it's all downhill to the finish line from here!!
    August 2009
Posted by JOE RIX on Monday, January 19, 2015 12:28 PM
Hey fjs3 and flyerduke, I have a question for the two of you concerning the decals on your Hellcats. Was the insignia for the upper wing colored gray on your kits? I was a bit taken aback when I went to start cutting my decals and found that the insignia for the upper wing on my sheet was gray rather than white.  So, I'm curious as if this is done so it will appear white when applied over the dark blue? I notice on your kits that your insignia is insignia white as it is suppose to be. I've never encountered this before. Thanks for any help.
    December 2012
Posted by flyerduke on Monday, January 19, 2015 4:02 PM
It sure was.  Like you, I was wondering what was going on.  I slapped it on there and it looks fine.  It looks fine on the dark blue upper wing surface.  Here is a not so good pic of mine?
Craig
JOE RIX
    August 2009
Posted by JOE RIX on Monday, January 19, 2015 6:58 PM
Well now. Ain't that the darndest thing you've ever seen. Whoda thunk it. Thank You very much flyer. You have put my mind at ease
    March 2012
Posted by mustang1989 on Tuesday, January 20, 2015 9:20 PM
Way ta go there Joe!! Givin' er the ol' one-two!
 Forum | Modelers Social Club Forum (proboards.com)
    August 2009
Posted by JOE RIX on Tuesday, January 20, 2015 10:17 PM
Thanks mucho Joe. I'm certainly feeling much better about it now.
    August 2005
Posted by fjs3 on Saturday, January 24, 2015 9:53 AM
Okay Folks,
I'm calling this one DONE!!  Eduard 1:48 scale F6F-5 "Hellcat" is FINI!!
Here are a couple pictures of the finished model.  It's a great build guys and gals, probably the best "Hellcat" model out there, even with it's shortcomings.  Hasegawa is still a great kit too, but I think Eduard's offering just beats it by a nose.
Here are the pictures, and now it's off to hit the F4U!!
Thanks for looking everyone, Have a great day!!
Regards,
Freddie from LI
    August 2005
Posted by fjs3 on Saturday, January 24, 2015 10:09 AM
Well, last night was a busy one on the ole' modeling bench for me.  After finishing the F6F-5, I got right onto the F4U, and made huge progress on her.
I finished off the cockpit, tail planes and got the wings attached.  Even the engine!  I posed the last couple of pics, with her standing on her landing gear, just to see how it all lined up, they're not attached yet.
Anyway, Tamiya makes a great kit of this famous aircraft, and if you have not had the pleasure of attacking one, then by all means pick one up and give her a whirl.  Great kit, great model, excellent build!!
Anyway, that's all for today folks.  Tonight will be cleaning up a few seams and getting her ready for paint and decals, WHICH, hopefully will happen next weekend.  Now it's on to another project, weathering and finishing a 1:32 scale Hobby Boss Stormovik.  (BIIIIIIG Model)
Have a great day everyone.
Regards
Freddie from LI
    December 2012
Posted by flyerduke on Saturday, January 24, 2015 11:43 AM
Wow Freddie, that Hellcat looks great!  You really have that weathering down pat.  Well done!
Nice progress on the Corsair.  You are a modeling building machine.
Craig
    August 2009
Posted by JOE RIX on Saturday, January 24, 2015 6:57 PM
The F6F-5 is fantastic. Your weathering is excellent. You definitely have a nice touch there. Also, very good progress on the Corsair. You've definitely nailed it in your analysis of the Eduard Hellcat and the Tamiya Corsair. Both are without a doubt the class of their respective subjects.
    August 2009
Posted by JOE RIX on Saturday, January 24, 2015 7:05 PM
The decals are on. Without a doubt the easiest decaling effort I've had so far. Reference of my aircraft reveals that there were no stencils on it. At least from what I can observe. I then had to submit a short prayer prior to applying a light gloss coat to seal the decals. YESSS! It went on just fine. Tomorrow will be the oil wash session. Thanks for taking a look guys.
    December 2012
Posted by flyerduke on Saturday, January 24, 2015 7:24 PM
Excellent!  Looks great.
    January 2008
Posted by Rob.H on Sunday, January 25, 2015 8:31 AM
Joe: I am glad to see you recovered from your painting woe's.  That Hellcat is looking very nice, and I keep having to remind myself it is a 1/72!
Freddie: I am again impressed with the way you weather your aircraft, that Hellcat looks well worn.  I cannot wait to see what you do with the Corsair.  At the rate you build that should be a couple of weeks.
Steve/Freddie: Thanks for the info on the Accurate Miniatures instructions and especially the links you posted Freddie.  I have never built one of their kits so I didn't realise the instructions were a weak point, and that the ones in the re-pop were even worse.  Good thing, because in addition to the Avenger I also have the re-release of the SBD-2.  I was able to grab the files for the original kit instructions for that plane as well.
on the bench: Moebius Battlestar Galactica, Tamiya 1/35 M13/40
    July 2014
Posted by Bakster on Sunday, January 25, 2015 9:00 AM
Hey Freddie...I agree with everyone-else here that the weathering you did looks really great. I really like detailing on those guns too.Great job and congratulations!
Joe..looking good sir!  The decals look perfect.  Thank goodness the light coat of clear went ok.  Awesome!
