Rob, looking forward to the paint on the Tiffie. Not too often I see pre-shading with solid blocks filled in like that, but should be great.
Thanks Bish, Joe, Check and Rob.
I understand now (or maybe I had forgotten), the woes of knocking PE bits off a ship model. Not much room to hold while adding the finishing touches. So about half the bench time put in today was re-affixing both rails on port side, a couple AA mounts, and a crew figure.
Should of done more research on the Kriegsmarine flag. Copying the dimensions provided in the kit results in one way too large. I endeded up shrinking the artwork down 50% after reading this forum thread:
http://www.wehrmacht-awards.com/forums/showthread.php?t=267846&highlight=large+rkf
Based on ship tonnage, flag size as follows:
#3 (50x85cm), and #5 (80x135cm), both used on vessels up to 500 tons, such U/E-boats.
#6 (100x170cm), and #7 (150x250cm), used on ships between 500 to 1500 tons.
#8 (200x335cm), and #10 (300x500cm), for ships over 1500 tons, like the cruiser Leipzig (8,380 tons).
#11 (400x670cm), and #12 (450x750cm), used on ships over 10,000 tons, like the battleships Graf Spea (12K-16K tons), and the Bismarck (50,405 tons).
Anyhow, here is the original one I put together (600 dpi) if anyone wants to save for a future project. The size is likely good for a destroyer size vessel at 1/700 scale.
regards,
Jack
