Thanks Lew. This is easily a 48 hour project. Too bad I did not have 48 hours...
So last nite before bed I was looking thru my laptop's photo library, and low and behold the "missing" photos had loaded into the main portion, rather than into a sub folder as they had been doing... so I edited them, uploaded them to PB, and went to sleep....
the final cockpit photos before I closed it up
wings and tailplane glued on
bomb shackle attachment lug (taken off of a Panzer III roadwheel arm). I also drilled away the kit front sight post for replacement with some styrene rod
canopy masked and glued in place
styrene shim for gap filling, sanded to match the sourrounding area
new front sight post added
rocket motor nozzles, and control surface balance horns (not bad small details for a 50+ year old kit)
base paint coat on, Tamiya IJN Gray Green
and after this I did the Future coat and decals that were in the photos in the post before this... The Cherry Blossom decal is from the kit, but the ID numbers shattered, so I took some IJN tail code decals and cut off the 1st prefix letter and last suffix number to make a replacement set...
so the post above is how the kit looks this morning.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
