Larry Wolf Memorial Close Air Support Group Build 2021 Needs YOU!
Posted by jeaton01 on Friday, June 18, 2021 6:42 PM
Very nice, Piers.
John
Posted by keavdog on Saturday, June 19, 2021 12:16 AM
Well done!  I'd never seen this airplane before.  Curious about the wing design.
Thanks,
John
    July 2014
Posted by modelcrazy on Saturday, June 19, 2021 11:21 AM
keavdog
I think they put the outer wings on upside down and thought it was too much trouble to correct them. Wink
Another beauty build Piers Yes
Steve
    April 2014
Posted by lostagain on Sunday, June 20, 2021 7:55 AM
modelcrazy
Big Smile
Like that Steve!
Thanks for the kind words everyone.
Yep, there was a range of opinions of the Vengeance, and they only were in active service for under a year.
Funnily enough, the RAAF Vengeance squadrons were next given the B24 Liberator - a bit of a change up!
Posted by jeaton01 on Sunday, June 20, 2021 2:09 PM
Vultee seemed to like that wing planform and used a very similar layout on this experimental to the same contract as the XP-55 and XP-56 pusher fighters.  The forward swept trailing edge does have some positives as it tends to improve stall characteristics.
John
    June 2017
Posted by fotofrank on Thursday, June 24, 2021 4:59 PM
I have Aero Mask stencils coming for the A-37. I decided to go ahead with the Vietman U.S.A.F. camouflage for the airplane.
OK. In the stash: Way too much to build in one lifetime...
Posted by keavdog on Thursday, June 24, 2021 6:02 PM
That will look sharp Frank.  I've never used those sentcils - how are they?
Thanks,
John
    June 2017
Posted by fotofrank on Thursday, June 24, 2021 8:30 PM
keavdog
The stencils are really good. They make a complex camouflage much easier to paint than trying to do the paint freehand. So far I've used Aero Mask stencils on a Hasegawa Bell P-400, an Airfix P-40B Flying Tiger, and a Hasegawa Spitfire Mk VIII. Excellent results every time. As complex as the Vietnam camo is, these stencils are the only way to go for me.
    May 2020
Posted by Hutch6390 on Monday, June 28, 2021 2:22 PM
I didn't get as much bench time as I had expected (the resident Domestic Engineer had a few tasks lined upSmile), but I did get the engines assembled.  These were temporarily pushed onto their locating plugs for a coat of primer from a rattle can -
The primer has revealed a few bits of tidying up for me to do, then I can touch-up the primer & apply some colour (hopefully. this weekend!)
Vell, Zaphod's just zis guy, you know?
TakkaTakkaTakkaTakkaTakkaTakka
    July 2014
Posted by modelcrazy on Tuesday, June 29, 2021 12:47 PM
I like the Beaufighter Hutch.
It's time I tossed mt hat in.
Started on the MiG 27. Doing it OOB, nothing fancy. A typycal early Hase kit, nice fit but very little detail. I'll add the detail with the air brush. Quick build except for the seam filling, but it's almost done. Then on to the fiddly parts and paint. I had to go the the store and get some of that Russian interior turquoise, but you probaly won't see it anyway.
I remembered to add some weight to the nosecone.
Steve
    July 2008
Posted by castelnuovo on Saturday, July 3, 2021 1:07 AM
We,,. lets call this one finished
    April 2014
Posted by lostagain on Saturday, July 3, 2021 7:40 AM
That looks really good castelnuovo, great finish. I like the dive brakes and actuators, they look really fine are they PE?
    May 2020
Posted by Hutch6390 on Saturday, July 3, 2021 8:33 AM
Nice job, very smart indeed!
    July 2008
Posted by castelnuovo on Saturday, July 3, 2021 6:24 PM
lostagain
Thank you gentlemen. The actuators are plastic. The only PE part with this set were the seatbelts but they were too small to handle so I used the decal belts.
Posted by keavdog on Saturday, July 3, 2021 6:56 PM
Turned out great.  I added to the complete page - let me know if you want a different pic.
Thanks,
John
    June 2018
Posted by DRUMS01 on Saturday, July 3, 2021 8:46 PM
With your permission... I would like to add my just completed RAH-66 Comanche to the Close Air Support GB, even though I already have the gunship already completed. The build string is located under the Helicopters tab.
Here is my 1/48 Italeri RAH-66 Comanche stealth helicopter. This was an aircraft that was developed and tested right up to production but then cancelled at the last minute.
Added items include Quinta 3d Studios cockpit items modified to fit this kit; pilot and RSO figures as the kit did not have any. They were also highly modified to for the cockpit confines and to handle the controls; Eduard resin and PE Hellfire Missiles, scratch built entire cockpit including fire extinguisher and first aide kit; scratch built many items in ammo storage bays; scratch built items on weapons pylons and the control boxes for the Stinger missiles; highly modified mask set for a Su-25 digital camouflage that was change and applied to the Comanche; purchased stand that was modified to fit the model and the plate description is a modified lapel pin glued to identify the aircraft. The decals are made by Caracal for the AH-65 Apache but modified for the Comanche.
A mixture of model Master, Vallejo, and Tamiya paints were used along with markers and pastel washes.
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
Posted by keavdog on Saturday, July 3, 2021 10:15 PM
I don't see why not.  I followed your build and love the digital camo. Added to the front page.
Thanks,
John
    June 2017
Posted by fotofrank on Sunday, July 4, 2021 11:20 AM
DRUMS01, your Commanche Stealth Hellicopter is terrific. Is part of the camouglage actually pink/magenta? Very well done.
My motivation has been lacking here lately, but I did start work on a Pro Modeler 1/48 F-84G the other day. So far the cockpit is done and some weights added to the nose so it stands on its gear. I'll close up the fuselage sometime today.
The A-37 that has been on the bench for a while has been sitting for a week or so but it's ready for primer. We've had a lot of rain recently so I havent been able to get out on the patio to paint, and now I'll have to wait for Elsa to pass before I can get some airbrushing done.
Anyway, here are a couple of pictures of the progress on the F-84:
There aren't any seat belts because I will be putting a pilot in the cockpit.
    April 2020
Posted by Eaglecash867 on Wednesday, July 7, 2021 4:30 PM
Nice builds, fellas!
Finally got all the detailing done inside the gear wells, so I'm working on closing them up inside the engine nacelles.  Figured it would be better to attach the inboard halves of the nacelles to the fuselage to try to ensure a more solid bond.  Seems like a pretty critical stress point on the model that I want to be as strong as possible.  I'll probably drill some holes through the contact points on the fuselage so I can get Tamiya Extra Thin to disperse over a wider area after being dropped into those holes.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    April 2019
Posted by Tomcat on Tuesday, July 13, 2021 8:53 PM
It's been a while since my last post. This Invader has been kicking my butt. Howver progress is being made. Here the props, wheels, landing gear have been primed and the hubs have been painted...
The interior has been fashioned and added and the front landing gear bay filled in...
meanwhile, the airframe with all its gaps and sink holes have been filled, filed and sanded waiting primer for a final check...
As for the canopy, I did manage to secure a replacement. However before screwing up this one,Ii decided to try and create a vacuum formed one. Many years ago I made a home made vacuform machine but never managed to test it. Well, no time like the present, so I'm going to try it out.
Here is the replacement canopy and the block of wood I will use to create the canopy form...
I will get out my coping saw and files and start hacking at it. What I would give for a scroll saw.
After all of the cutting, carving, filing and sanding, here is the canopy blank mounted inside of my homemade vacu-form machine...
I have a few more things to clear up before trying out the machine, so wish me luck.
Mark aka Tomcat
On the workbench: Monogram 1/24 '69 Pontiac GTO and a Monogram 1/67 (box scale) B-26 Invader
Posted by keavdog on Tuesday, July 13, 2021 9:39 PM
Wow Mark - what a putty monster!  Coming along nicely.  I tried smash forming a long time ago with mild success.  I wonder if there's a 3d clear print capability...?
Thanks,
John
    April 2019
Posted by Tomcat on Wednesday, July 14, 2021 7:38 AM
keavdog
With todays technology, that would be the way to go.  But I'm too old-fashioned....too cheap to invest in a 3D printer. Yeah, I could have it made for me but where's the fun it that? The whole point of this model is to challenge me some, to overcome some obstacles and maybe learn something new all the while having fun, if you can call this fun Big Smile
Mark aka Tomcat
    May 2011
Posted by Real G on Wednesday, July 14, 2021 12:25 PM
Hey Tomcat,
Great minds think alike!
The first one is my "mini", the second is the larger one my friend made for me 30 years ago.  Vac-formers might be considered passe', but they can make diffcult parts easy!  Besides, 3D printed crystal clear parts are not economically available at the moment.  Maybe a couple of years down the road.
“Ya ya ya, unicorn papoi!”
    November 2003
Posted by bobbaily on Wednesday, July 14, 2021 5:57 PM
Nice builds all-sorry I've not been posting but I have been following.
Finally got started on the Hasegawa 1/48 bf109E4/7 'Jabo' kit-it's the older JT series but still looks like a 109 and is a bit cheaper at model shows....
Anyway, I still need to so some cleanup and address the wing root that really didn't look as bad as it does in the pics...Embarrassed...but I hope to get some primer on it tomorrow or Friday.
Question for the resident experts in the group-anyone seen pics of a Romanian 109E carrying a bomb?  I've read several accounts of the Romanian Air Force providing ground support with 109E's but can't find any supporting pics?  If not, I've got several other paint schemes to choose from.
Cheers
Bob
    April 2020
Posted by Eaglecash867 on Saturday, July 17, 2021 12:09 PM
Final test fit to make sure everything comes together the way I was planning it, and to give me a mockup to study so I can determine the best sequence to put things together as I close up the fuselage.  CG is currently far enough forward of where the main gear will be, so I think this one will manage to not be a tail-sitter without any extra weight up front.  Still might add a few tungsten weights just behind the cockpit though, since closing up the fuselage is a one-way street...not gonna hurt having a little too much weight up front.  The gaps that are visible in the pics all come together with light pressure, so the fit is actually going to be pretty good.
    November 2003
Posted by bobbaily on Monday, July 19, 2021 6:34 PM
Nice work Eaglecash-it's coming together-looking forward to more progress pics.
I worked on the wing/fuselage fit-looks better (I hope)-used Tamiya spray can grey primer.
Picked a camo scheme so I sprayed the Vallejo yellow-will be interesting to see if it holds once I tape it off for the rest of the paint.  Also got the canopy masked-took the easy route and used Eduard masks-well worth the price.
Bob
    April 2020
Posted by Eaglecash867 on Monday, July 19, 2021 6:45 PM
Thanks Bob!  The 109 is looking good.  That's a really cool idea using Legos as a jig.
    November 2003
Posted by bobbaily on Monday, July 19, 2021 6:53 PM
Thank you Eaglecash.  Been using the Legos (actually our son's Legos) for quite a few years-he has since married and moved on, leaving a 20 gal. container of Legos collected over the years....so I 'borrowed them' for a bit....Wink
Bob
    July 2014
Posted by modelcrazy on Friday, July 23, 2021 9:49 AM
I's been a little bit since I posted my MiG 27 but I finally received my Akan paints from Russia. I finished it's three tone camo and it's ready for the underside, a little touch up and then the gear and weapons.
Steve
    June 2017
Posted by fotofrank on Monday, July 26, 2021 4:20 PM
I don't know how they do it, but Eduard masks are spot on. Thirty minutes after I retrieved to package from the mailbox, the canopy on the Pro Modeler F-84G was masked. Ready to move on to the next step. Oh yeah, I moved the windscreen mask to the correct position.
