Supermarine/Vickers GB
    September 2018
Posted by Sergeant on Saturday, November 27, 2021 1:07 AM
Jack, I can tell by the uniform of the American officer, on the right in your photograph it is 20 June 1941 or later. His shoulder patch (badge) is that of the newly formed US Army Air Force. Prior to June 1941 the US Army Air Corps (predecessor of USAAF) patch had a white star on a black field with a red circle in the middle of the star.
The aircraft I am modeling is serial number P7966 flown by Douglas Bader, Commanding Officer of the Tangmere Wing from 18 March 1941 until he crashed on 9 August 1941. There were three Squadron in the Tangmere Wing while Douglas Bader was in command. I think they were 131, 602 and 616 Squadrons.
https://www.tangmere-museum.org.uk/artefact-month/douglas-baders-fateful-day-9-august-1941
Jack, you have the mind of a detective. Thank you for solid historical investigation.
Harold
    April 2006
Posted by jgeratic on Saturday, November 27, 2021 9:49 AM
Harold, nice spot on the shoulder patch to date the photo.  Thanks for the compliment, but am not that much of a detective, just that I have visited these 'rabbit holes' before and know/remember where to look.  Big Smile
Here's a shot of a 616 Sqn mount during winter of 1941.  One thing seems to be is the forward fuselage where the engine is located tends to always have a hard edge, literally right along the panel line (mind you it could be field maintenance repaint):
As an aside, it's quite likely wing leading edges would receive touch ups to paint over chipping from the prop throwing up debris.
regards,
Jack
    September 2018
Posted by Sergeant on Saturday, November 27, 2021 12:29 PM
I agree with you Jack. I did not find any closeup original photographs of Squadron 131, 602, or 616; however, I did find clear evidence of both sharp demarcation lines, soft camouflage lines, minimal overspray and heavy operational paint wear. I think my choice will be to sharpen the demarcation lines a little on the wings and continue with softer camouflage lines between the Dark Earth Brown and Dark Green colours.
In photograph No. 1 of an early version Spitfire that was force down by the Germans it clearly shows hard (sharp) edges along demarcation lines on the wings and engine panel. In photograph No. 2 some lines are hard and others along the wings appear to be softer. In No. 3 there is a little overspray on the engine panel, and the wings appear to be soft edges. In No. 4 the paint is worn very badly an indication of many operational hours with little time for repainting.
Photo No. 1
Photo No. 2
Photo No. 3
Photo No. 4
    April 2006
Posted by jgeratic on Saturday, November 27, 2021 12:52 PM
Photo no.4 depending on the date, may have had the b/w invasion stripes applied in the field by brush.  This was hastily applied the night before D-Day, but yes, operational use would further create the worn look.  Also, later on in the European campaign, the top portions of the stripes were removed by painting over them.
regards,
Jack
    September 2018
Posted by Sergeant on Saturday, November 27, 2021 1:50 PM
jgeratic
regards,
Jack
Jack, I have always assumed the D-Day stripes were for identification, so the Allies did not shoot down their own airplanes. Is my understanding correct?
How were British airplanes repainted while in operational squadrons? Did the RAF have maintenance centers with paint spraying equipment, or was it all done in open fields by the squadron ground crew with paint brushes?
Harold
    April 2006
Posted by jgeratic on Saturday, November 27, 2021 2:34 PM
That is correct about the invasion stripes.  The Allies had pretty much air superiority from the start, so it was more important to reveal their identity quickly to avoid friendly fire.
As I understand it, maintenance units would have the spray guns, and they would be responsible for a number of squadrons in the area.
At squadron level, they too would have paints, but am not sure if the erks were trained for spraying paint, just hand brush?  Paints here were likely  just for touch ups on minor repairs, as well as applying new codes on replacement aircraft, either direct from the factory or from a different squadron.
regards,
Jack
Posted by Gamera on Saturday, November 27, 2021 6:15 PM
Looks great Harold!
I'd only heard about the matts being used to mask off the camo with a hard edge. This is interesting, I don't know about the rest.
    September 2018
Posted by Sergeant on Sunday, November 28, 2021 1:58 PM
Gamera
Looks great Harold!
Thank you, Jack and Cliff. I am ready to start camouflage painting today. But first I tested the masking system and my ability to mix the same colour of Dark Green that matched my colour chips from Iliad Design. Everything checks out correct as far as I can tell. The masking putty I'm using is AK Camouflage Elastic Putty for airbrushing and the liquid mask is VMS Easily Removed Liquid Fluid that is water soluble.
I pushed the limits a bit to see what would happen. The liquid mask is supposed to have 30-minutes to cure, but I only gave it 15-minutes. I intentionally airbrushed a single heavy coat of paint to see if it created unsightly edges and it didn't, but I will use two light coats of Dark Green instead of one heavy coat. The Dark Green is a mix of 8-parts Vallejo #71.325 IJN Dk. Black Green, 1-part 71.324 BS Dark Green with 4-parts 71.323 BS Dark Earth.
Harold
    September 2018
Posted by Sergeant on Monday, November 29, 2021 3:38 PM
Not quite what I had expected... I wanted a 50% - 50% coverage of Dark Earth Brown and Dark Green, but it's more like 70%-30% because I miscalculated the thickness of the masking putty.
Before I do any more with this model I have decided to build the second spitfire that came in my kit. It will have the same camouflage paint colours but the exterior has a few different features, most noticeably the two cannons on the wing. This will give me a chance to adjust the camouflage pattern to approach 50% - 50% Dark Earth Brown and Dark Green.
The decals I plan to use are for a Mk. IIb, Serial No. P8385 flow by F/O Miroslaw Feric, No. 303 (Polish) Squadron, RAF Northolt, Great Britain, May - June 1941. The cockpit is already to go, so I can concentrate on the exterior assembly and painting.
Harold
Posted by Gamera on Monday, November 29, 2021 10:31 PM
Harold: It shouldn't be too hard to remask and spray on some more dark green. If it'd went the other way and you'd gotten too much green it'd been harder to spray more brown on over the darker green.
    April 2006
Posted by jgeratic on Monday, November 29, 2021 11:59 PM
One of the members here has a web page where you can download spitfire masks:
http://www.yolo.net/~jeaton/mymodels/spitfire/templates/SpitTemp.html
Maybe print them out on paper, cut out the required shapes, and then apply the rolled putty masks along the edges?
regards,
Jack
    September 2018
Posted by Sergeant on Tuesday, November 30, 2021 12:59 AM
jgeratic
regards,
Jack
Cliff and Jack I agree, it's worth a try and if it fails then I still have another Spitfire in my kit.
Thank you for your encouragement.
Harold
    September 2018
Posted by Sergeant on Thursday, December 2, 2021 9:08 PM
Well Cliff and Jack I made some progress. I was able to lightly sand with 1,000 grit sandpaper along the dark green edges to feather them into the dark brown. It was a good thing I had only two lights coats of paint on the model.
Then I gave the entire model two light coats of grey surface primer, so I could see if the dark green lines were going to show. It needed a little more sanding and then I gave it three light coats of dark earth brown.
The camouflage preparation step is where I need a little help. I understand how the paper camouflage masks I downloaded are to be used, but I'm not clear on whether I place the masking putty along the edges of the paper masks and then add liquid masking on top of the paper masks or just use the paper masks without liquid masking to protect the dark brown?
I need to give the new brown paint job at least 24 hours before I start the camouflage work, so I will wait to hear from you guys before I start masking.
Harold
    April 2006
Posted by jgeratic on Friday, December 3, 2021 12:26 AM
Hello Harold, I would use rolls of putty on the undersides of the paper mask edges - assuming it is sticky enough?
Now, because the putty spreads when pressed on the model surface, that is something that requires looking at.  Either use really thin 'worms' of rolled putty, or you may have to trim back the edges of the paper mask beforehand to make up for this.
Another detail to look at is the camouflage patttern itself.  Eduard seems to have gone with a 'B' pattern, with some alterations.  I'm seeing 'A' pattern, which would be the mirror image of those paper masks.  Only a few period photos I can find of Bader's P7966.  Note how the rudder pattern does not match up at all with either pattern - possibly a repaint from repairs??
regards,
Jack
    September 2018
Posted by Sergeant on Friday, December 3, 2021 12:45 AM
jgeratic
regards,
Jack
Jack it is great that you found actual photographs of P7966. Regarding the paper masking instruction: A - patten was normally used on even serial numbers while B - pattern was used on odd serial numbers. 7966 can be divided by 2 (3983) equally so Bader's plane should be pattern A, but as you said the rudder dose not match either A or B, but does look like a lighter colour, similar to the B - pattern. However the masking instructions also mention that "photographs sometimes show the reverse", so perhaps his P7966 was one of those reversed and repainted? Regardless of how it happened I will go with your photographs and use the B - pattern.
Regarding how to apply the masking putty I have learned that 1/8" diameter rolls (worms) work pretty good. 1/4" is what I used the first time and it takes up to much space. 1/16" is good, but hard to control. So if I use 1/8" I can cut the paper mask back an 1/8" on all sides except the leading edge of the wing and I should be close to the original size of the paper mask. I will test my theory before I do anymore painting on the model.
I also learned a very interesting fact about masking putty. If I press the masking putty down just enough to make it stick to the painted surface and hold my air brush at right angles to the surface I am painting I get a 'soft line' between the green and brown. On the other hand if I hold the air brush so I can get paint under the curve, or radius of the rolled masking putty the line is usually much sharper. In most of the Spitfire photographs I have seen the line between green and brown camouflage patterns is soft. I will need to experiment to see how right angle air bushing compares with the size and shape of the masks.
Harold
    April 2006
Posted by jgeratic on Friday, December 3, 2021 8:03 AM
Harold, sounds like you are good to go.  Yes, airbrush angle combined with masking height will determine the overspray width.
regards,
Jack
Posted by Gamera on Friday, December 3, 2021 8:45 AM
Harold: I think Jack already covered everything so I'll just say DITTO here...
Only thing I'd add is I'd never spray toward a mask on purpose. You're better off spraying away from it or at a 90 degree angle. I sometimes end up spraying into a mask by accident- and then I get paint being driven under the mask by the air pressure.
    September 2018
Posted by Sergeant on Friday, December 3, 2021 12:24 PM
Gamera
Posted by Bish on Friday, December 3, 2021 1:28 PM
Sorry i haven't commented guys but there's not really anything i can add to this. Some great info shareing here about schemes which i think often get overlooked.
Posted by jeaton01 on Friday, December 3, 2021 8:25 PM
I've come to the conclusion that A or B patterns  matching odd or even serial is a minefield, and I recall reading that that was the initial plan but it soon became random, and the A pattern was more prevalent.  Just have to go with the photos, as usual.
John
    September 2018
Posted by Sergeant on Saturday, December 4, 2021 11:35 AM
jeaton01
Thank you, John, I agree with you about photographs. As you have probably read, I messed up my first attempt at camouflage on this Spitfire, but there is a good side to my mistake. After re-primer I masked off the lower section and gave the model a good coat of dark brown. When the camouflage work is completed, I can mask off the top side and apply the sky colour to the bottom side like you suggested.
Harold
    September 2018
Posted by Sergeant on Saturday, December 4, 2021 6:53 PM
jgeratic
regards,
Jack
Jack and Cliff, I completed my experiment with paper makes and masking putty. Below is an example of what I found works well for me. I cut the paper mask and dry fit it to the model to make sure each paper mask fits the way I intended using the rectangular cutouts with masking tape to hold them in place. Then I remove the paper masks and masking tape to apply a 1/8" diameter roll of masking putty around the top surface edges and over the rectangular cutouts in the middle of the mask. The cutouts allow putty to protrude through the paper mask and stick to the surface of the model like masking tape.
Next, I turn the mask over, so the paper is facing up and use a flat putty knife to press down slightly on the paper mask. Putty pushes out around the edges of the paper mask and through the rectangular cutouts. The putty at this point is only slightly thinner than 1/8". Then with a new #11 hobby knife blade I carefully trim the excess putty as close as I can without cutting the paper mask.
The paper mask with putty is ready to apply paper side down to the model. The paper acts like a carrier holding the shape of the putty, so when I am applying it to the surface of the model only the edges and cutouts stick to the surface. I use a wooden stick to reshape any putty that gets out of line. If I need too, I can remove the paper mask and start over without damaging the painted surface or the paper mask.
As you can see below, I was able to hold my dimensions and create a reasonably soft line between the blue and white colours. Of course, using this method successfully on the model will determining the merits of my procedure.
Harold
    April 2006
Posted by jgeratic on Saturday, December 4, 2021 9:56 PM
Looks good.  I like the idea of trimming the putty while on the paper masks.  Wonder if scissors could cut the putty, or too tacky?
regards,
Jack
    September 2018
Posted by Sergeant on Sunday, December 5, 2021 7:56 AM
jgeratic
regards,
Jack
Jack, I think it depends on the putty and temperature. I use small scissors with a serated edge and they cut the putty just fine. I keep the studio room temperature at around 70 degrees F. mainly to prevent paint and other materials from getting too cold.
The masking putty I like to use is AK Camouflage Plastic Putty for Airbrushing. I leave it in a sealed zip-lock bag over night and it shelf-levels to pancake shape about 1/4" to 3/8" thick as you can see in my little 3-minute demonstration video.
https://www.flickr.com/photos/164748493@N04/51725195317/in/datetaken/
Posted by Bish on Sunday, December 5, 2021 8:55 AM
Just a remonder, the GB has just under 4 weeks to run. But as always, as lng as your entry is on the front page, please feel free to continue to post your builds after the 31st Dec. I don't want anyone to rush to meet a dealine.
Posted by Gamera on Sunday, December 5, 2021 6:21 PM
Harold: That sounds good!
I painted the prop this evening. And got the canopy masked. I'm hoping to be done by the end of the year.
    April 2020
Posted by JBRaider on Sunday, December 5, 2021 9:38 PM
Harold it looks like you have recovered nicely after your first try and seem to making good progress. My usual method is a combination of tape and blue tack but I have been tempted to pick up some of the AK putty so I am really interested to see how this works out.
I find camouflage masking the most frustrating part of a build, but it is so rewarding to see the final result.
    September 2018
Posted by Sergeant on Monday, December 6, 2021 9:37 AM
JBRaider
Thank you, Cliff, and JB. I think it's starting to come together finally. When Jack Geratic suggested using a paper mask the light went on for me. The paper mask gave me a way to see the camouflage design on the model without using any paint. This allowed me to adjust the pattern until everything fit together the way I wanted it look.
This morning I made a change in the process that seems to work better. Instead of applying the putty to the paper mask, I apply the paper mask to the putty. In other words, I create a flattened bed of putty about an 1/8 of an inch thick, then lay the paper mask on the putty gently press it down and trim off the excess using the paper mask as my template. Please see the last photograph below.
The paper mask in this location was too small for a masking tape cutout, so I created a small flat piece of putty and laid the paper mask on top. It was much easier to fit it to the wing and I could use a stick to touch up around the edges. I don't plan to remove the paper from the putty after painting I will just discard the mask and putty together. In my mind it does not matter if the putty is not exactly the shape or size of the paper mask as long as it looks right and covers the area I am trying to protect.
Harold
    April 2005
Posted by taxtp on Monday, December 6, 2021 5:47 PM
Harold, that looks very precise. I've done something similar in the past and I think that'll be good.
Here's an update to my late entry, the Airfix Spitfire 1a. I've also just ordered some decals to do an Australian squadron, perhaps with Ocean grey/Dark green upper surfaces for something a bit different.
Cheers
Tony
I'm just taking it one GB at a time.
    April 2020
Posted by JBRaider on Monday, December 6, 2021 7:28 PM
Primed and ready for some paint. This was my first time using the Mr Surfacer and I really liked it.
I added white to the centers of the panels and sprayed the underside a light grey, but I lost those pictures.
I then sprayed the top with Vallejo Yellow Ochre and highlited the centers with a little light grey added in.
I then masked off the camo and shot it with a dark blue, highlighted with a little white mixed in as well. The highlights on the blue don't show up well in the picutres but they are there.
I don't know how acurate the colors are but they are spot on compared to the Eduard instruction sheet.
