Floats and Boats GB 2022, extended to end of 2023
Posted by keavdog on Monday, March 21, 2022 6:01 PM
Calling it done.  Very much like my 12 year old self build  Tongue Tied lot's of issues.  But here she is (first pic for the front page please):
Thanks,
John
    September 2018
Posted by Sergeant on Monday, March 21, 2022 8:29 PM
keavdog
Very nice finish John, it's great that you saved an interesting model that has been sitting around for years.
Harold
    June 2014
Posted by BrandonK on Tuesday, March 22, 2022 9:52 AM
keavdog
Wow, John. That is amazing. I would proudly display that on my shelf. She is stunner for sure. Amazing work!!!
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Tuesday, March 22, 2022 12:39 PM
That looks terrific BK. I like that color. Beer
 GIFMaker.org_jy_Ayj_O
    September 2018
Posted by Sergeant on Friday, March 25, 2022 9:25 PM
Thank you, Brandon, and John, for your comments.
While preparing to primer the hull this morning I ran into a problem. One of the hull windows popped out when I applied the Eduard mask. I had no way to re-glue it except through a hatch that I cut in the bottom of the tail section. Please see photographs below.
I ordered some 0.060" thick Evergreen polystyrene sheet to patch the hole. I will glue strips of polystyrene to the inside of the hull to act as glue tabs and fill the exterior seams of the patch with putty.
Notice how effective the black Dymo label stock worked to protect the hull while cutting the opening. Jack Geratic in Canada gave me that suggestion and it worked perfect. I created a line where I wanted the opening using a Tamiya engraving tool and then cut the 1.5mm thick plastic hull with a Dremel bit. It will be easy to patch and the Evergreen material is slightly thicker, so I can sand it flush to the bottom of the hull.
Harold
    June 2014
Posted by BrandonK on Saturday, March 26, 2022 10:55 AM
Sergeant
Harold
Nice save and great suggestion. I always put those small windows in with Gorilla clear 5 min epoxy. They will never come out after that and it's perfectly clear. Keep it coming along.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    September 2018
Posted by Sergeant on Wednesday, April 6, 2022 2:19 PM
BrandonK
Thank you, Brandon.
I have made some progress over the past couple of weeks. First coat of primer went on this morning and as you can see the transition to the resin tail is good. I will give the primer 24-hours to dry before a light sanding with 3000-grit sanding sponge.
Harold
    June 2014
Posted by BrandonK on Friday, April 8, 2022 9:55 AM
Harold, you have done a marvelous job with that tail. You can't tell any surgery was done.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Thursday, April 14, 2022 7:11 AM
BrandonK
BK
Ditto Awesome surgery results.Yes
    November 2008
Posted by plasticjunkie on Thursday, April 14, 2022 10:10 AM
The decals are on but they neglected to add the white background to the nose art.
Using a 10/0 brush and a VERY steady hand I filled in between the red outlines. I also added a Flory wash.
    June 2014
Posted by BrandonK on Thursday, April 14, 2022 10:13 AM
Man, that is looking really good. I should find one of those and add it to the stash.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Thursday, April 14, 2022 5:14 PM
Thais BK. The weird shape grows on you Huh?
    April 2014
Posted by lostagain on Sunday, April 17, 2022 7:39 AM
Keavdog, super result with the H 19, for what sounded like a bit of work to get on top of.
Helo H34 the Seamaster looks fantastic - a great result especially considering everything I have heard about Mach 2 kits.
PJ, the Seamew scheme looks great, thanks for showing your mottling process. Looking forward to seeing this done.
I have now got into my kit, same company as the Seamew but looks a bit different. The Curtis Racer is the 1925 Schneider Cup winner, but I will be doing it as the Curtis Fighter from the anime Porco Rosso
Not many pieces, but plenty of fit issues to resolve.
    June 2014
Posted by BrandonK on Sunday, April 17, 2022 10:04 AM
lostagain
You can't go wrong with a bi-plane on floats. I think these older simpler kits really put ones skills to the test. Looking forward to watching this.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Sunday, April 17, 2022 3:48 PM
Thanks lost. Hey your entry looks super cool.
Posted by keavdog on Sunday, April 17, 2022 4:13 PM
Hey Brandon - put me down for another.  I'm doing this Rufe, a crossover with Gameras Japanese GB.  Kinda into floaty things lately
Thanks,
John
    June 2014
Posted by BrandonK on Sunday, April 17, 2022 5:24 PM
keavdog
Sure thing. I'll add it to the roster.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    October 2009
Posted by JacknewbIII on Tuesday, April 26, 2022 12:11 AM
After a 2 year hiatus I am almost done setting up the bench in its new spot. This is my favorite subject/GB. Some really nice builds going on here to give me inspiration.. I will dig in the stash let you know what I plan to build shortly. Glad to see Brandon still hosting and some other friendly faces around here!
Jack
Posted by keavdog on Tuesday, April 26, 2022 12:24 AM
Glad to see you back on the forums Jack
Thanks,
John
    June 2014
Posted by BrandonK on Tuesday, April 26, 2022 11:19 AM
Nice to have you back, Jack.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2014
Posted by BrandonK on Tuesday, April 26, 2022 11:27 AM
My disc in my back went out again. It's been a few years since this happened. I'm off the bench for awhile. I can't hardly walk let alone go up and down stairs and sit at my bench. I have some new goodies for the Kingfisher and the two kits on my bench are nearing completion, so getting it rocking as soon as I can move. I'll keep up with the posts as best I can. Keep building.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Tuesday, April 26, 2022 6:06 PM
BrandonK
BK
OUCH! I have two degenerated discs in my lower back and know how that feels like. I know my limitations to avoid bad episodes. Wish you a speedy recovery.
    October 2009
Posted by JacknewbIII on Wednesday, April 27, 2022 1:12 AM
I have two degenerated disc's as well. If you have lower back issues try the Serola belt. I am in no way affiliated with them but their product is the best thing i have found to immediately relieve pain and get me healed quickly naturally. It will get you more bench time I promise.
I will pick a build by this weekend and am excited to get back on the bench! Its sad how much good stuff I have that has been sitting boxed up.
Rest those backs fellas.
Jack
    May 2011
Posted by Real G on Wednesday, April 27, 2022 1:43 AM
Oh man Brandon, that sucks!  I've had mysterious back pains that last a week or two, from time to time, and it makes putting my pants on an ordeal!  OK that was TMI.  Sorry.  But yeah, you really need that backbone system working to go about everyday stuff.
I gotta get back on my ekranoplan...
“Ya ya ya, unicorn papoi!”
    August 2021
Posted by lurch on Wednesday, April 27, 2022 9:00 AM
Keavdog that looks fantastic. You did a great job on it.
    June 2014
Posted by BrandonK on Wednesday, April 27, 2022 10:14 AM
Thanks guys. This has been with me since I had a bad fall on the job about 30 years ago. I know what it's like and I dread when it returns. And yes, the pants are the worst, but socks are a close second. Feeling a tad better today, time for my back brace to come out and wear it a few days. I'll be back to normal in a week.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    April 2020
Posted by Eaglecash867 on Wednesday, April 27, 2022 1:38 PM
Sorry you're having to deal with the gift that keeps on giving, Brandon.  I've had to deal with it from time to time after a plane crash I was in about 25 years ago that broke two vertebra in my lower back.  Not sure if you've tried this or not, but I have gotten relief by laying down on the floor in front of my couch and putting my legs up on the cushions where I would normally sit.  My doctor at the time recommended that.  It usually shortens the recovery time from those bad episodes.  In my case, pants were the second worst, with socks being the worst...can't stand in the middle of your socks and slowly wrestle them up while keeping your back straight like you can with pants.  OUCH!  Boo Hoo
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by keavdog on Wednesday, April 27, 2022 1:50 PM
lurch
Thanks lurch.  That kit was made before I was born Surprise
Thanks,
John
    August 2021
Posted by lurch on Wednesday, April 27, 2022 6:11 PM
When was that the 1990's. HAHAHAHA. Dont answer that think I am older that you.HAHAHA
Posted by keavdog on Wednesday, April 27, 2022 6:27 PM
First released in 1955!
I was released in 64 :)
Thanks,
John
