This where I stopped on the Monogram VF-11 build. I think the best way to reproduce the look of clear or colored lenes is with clear or colored styrene. I've never seen paint really produce the right look for lights to my satisfaction, so I added clear red styrene to both anti-smash lights on the tails. Next, I'll mask off the red area for the fin flash, & paint the tail gull grey, & do a little touch up paint where the white is showing around the light.
I added some styrene tubing to spread out the fuselage for a better fit, & less sanding.
You can also see more of the colored styrene I added for the upper nav lights. I figured it was easier to just ad a small rectangular piece, & then mask off the shape of the light than it was to try & sand & file the styrene to small triangular shape of the light itself. I think I might have to try paint next time... Here is another shot showing the lights.
You see the white lines behind the RIO's seat? Well, that was another idea gone bad. This was well before I bought the DACO book. I was wanting to dress up that particular area (I don't remember why now), & I took a look at both the BB & Aries pits. Well, the Aries pit has what looks like structural beams there, where the BB pit is flat, with just rivet heads for the most part . I thought, cool, those beams can be made with styrene strips. Fast forward to getting the DACO book, which has pics of that area, & guess (Aries) which pit (Aries) got it WRONG (Aries!). So I go looking around the web for pics of that area to see if it was an early A model that Aries based their pit of off. Nope. I found better pics of that area in the walk around section of ARC. Shiznit. I just sanded the strips down flush with the rest of the deck.
Here's the MLG leg that I reinforced with the paper clip. I've built several of the Monogram kit since the early 80's, & that little freaking plastic locater pin at the top of the gear leg can very easily get broken off if you aren"t careful. Ask me how I know. I drilled a small hole in the fuselage for new metal pin go through. I just need to cut some more of it off. Don't think it will break now.
Moving on to the Hasegawa VF-101 build, this is as far as I have gotten besides the cockpit.
AD 160 was not carrying any flares in any of the pics I've seen of the underside after it was painted in the retro scheme, so I'm filing the area out, & will blank it off with styrene sheet. The thin area of the MLG bay where the strut part goes needs another coat of white paint. The fwd part of the well I've already weathered a bit with a sharp pencil. Here's the other view.
I'm not going to be able to hit the bench till Monday (killer work schedule), so I hope to have some more pics in about two weeks. I'll still be checking the boards every day though.
Scratchbuilt, I replied to you PM.
Ish
Native New Yorker, like the F-14
