Guys:
WIP-SU122. I'm just about ready to start painting:
![](http://i156.photobucket.com/albums/t15/sjung_bucket/HPIM0250.jpg)
The assembly was a piece of cake on this kit. The two areas of concern, which I knew were coming because I just built the T34 (SU122 is based on that kit), were the rear deck grill and the gap below the fenders. Instead of spending the $ to buy the PE grill (mistake) I cut out the plastic and fashioned my own:
![](http://i156.photobucket.com/albums/t15/sjung_bucket/HPIM0252.jpg)
I am not real happy with the results, but from past experience I learned it's best to sometimes leave well enough alone and see if an idea comes along as I build to "improve" the situation. I fixed the fender problem by adding styrene strips:
![](http://i156.photobucket.com/albums/t15/sjung_bucket/HPIM0253.jpg)
I'm not worried about small gaps or seam lines because they will get mud and/or snow later. The putty will be sanded and the screw and hole, which adjusts track tension, will get filled later too.
I added a strip of styrene at the front of the lower hull for some relief. The kit had some weld seams molded in the plastic, but again from the experience with the T34, I found these were lost in the all the paint and weathering layers. To accentuate those seams I added a styrene strip where I felt a seam was missing and then used a hot-tipped wood burning tool and burned the "welds" where appropriate:
![](http://i156.photobucket.com/albums/t15/sjung_bucket/HPIM0251.jpg)
Also note how shiny the model is. What I did was take the liquid plastic glue straight from the bottle and cover all the armor, small sections at a time. The glue "burns" some texture on each panel. I used 4-5 layers of glue on the parts that would be sandcast. This technique is a substitute to Mr. Surfacer and sanding.
O.K....time to paint!!!
Question?: Does anybody know if the SU122 ever had the "box" type versus the "drum" type, reserve fuel tanks added to it? I think the back of this beast would look good with this addition. (I'm leaving the drums off either way) I may add the "boxes" anyway...it's a hobby for fun...afterall.
