Hello everybody! Update time!
Like I wrote before, I went on to paint the lower hull red clay dust color - Humbrol 113:
To give it a little variation and simulate some moisture, I shaded it with Gunze H47, which is a gloss paint. I like how it came out:
I also painted the wheels with Huimbrol 113:
To show the OD paint showing through, I painted the centres of the wheel with Humbrol 66:
Then I took that brown Gunze paint, H47 and made a wash out of it, that I applied to the wheels once they were throughly dry. Finally I painted the running surfaces of the wheels with Humbrol 32 to simulate rubber. Here is a photo of the wheels glued to the hull:
The spots on the wheels were sanded off to prepare for glueing on the tracks:
First I have painted the track with Humbrol 113. Then the rubber pads were painted with Humbrol 32. Finally the metal surfaces that should be worn were picked up with Humbrol 53 - Gun metal. I will paint the outside surface of the track once the complete runs are glued in place.
I also painted the worn metal surfaces on the sprockets:
Next I'm going to keep on working on the track and also on the bulldozer blade by Academy. I hope you liked it, thanks for reading and have a nice day
Paweł
