s.W.s & 3.7cm Flak 43
    November 2004
Posted by spacepacker on Friday, March 13, 2009 7:38 PM
I should have posted these pics two weeks ago but I mislaid my camera, however here goes;
About the kit; it's a Revell 1:35 kit.
The most frustrating build I have ever done,
1) the tracks are made up of fixed length and individuals, try as I might I could not get the 'sag' to be as I wanted; give me 'Indys' any day.
The numbering of the component parts is dreadful,ie:you would expect No 42 to be next to No 43 but NO it was the other side of the runner.
2)Some of the parts are designed to be put together as moving links and I went to all that trouble, only to find that when placed into the main Assembly they were 'locked'.  Even the gun elevation is locked, however this not a difficult mod' to do  which I will do and fit the gun sights.
3) I had to drill the holes in the muzzle brake.
However the plastic is good quality, the fit of all parts is good, the instructions are good, quite a few pin marks to clean up.
Built OOB, I did give a shout for some help on this, and of course several of you did help.
Thank you very much...Kenny
    January 2005
Posted by biffa on Friday, March 13, 2009 7:41 PM
Its a beauty Kenny and definatly on my "to do" list the weathering is very nicely done, great job.
Ron g.
    January 2007
Posted by the doog on Friday, March 13, 2009 7:46 PM
WOW, Kenny, despite all that, you did a magnificent job!
I have this kit with a whole bunch of PE and aftermarket tracks for it, so I hope that it isn't as frustrating a build as you say it is--I really have always liked the look of this kit!
Great job, snicerely! Nice paint and weathering!
Posted by tigerman on Friday, March 13, 2009 9:25 PM
Looks really good considering your struggles with the kit.
 Eric
    March 2007
Posted by frangkly on Friday, March 13, 2009 10:39 PM
she looks great, I think I have to start with my own after I finish my KT.
    May 2005
Posted by terry35 on Saturday, March 14, 2009 11:05 AM
Congrats there Kenny on a real gem. Looks brilliant, I'm amazed to see what you and the other guys are doing with these older Italeri kits.
Terry.
    July 2004
Posted by wbill76 on Saturday, March 14, 2009 12:30 PM
Some good work here Kenny despite the problems you encountered. I would never have guessed you drilled out the muzzle yourself, very nice work there in particular. Thumbs Up [tup]
    October 2007
Posted by panzerguy on Saturday, March 14, 2009 6:17 PM
    Revell 0 - Kenny 1
  Great job and a very cool subject.
"Happiness is a belt fed weapon"
    November 2004
Posted by spacepacker on Sunday, March 15, 2009 2:14 PM
Thank you all for your very kind remarks.
I have to say that the result is most definitely due to all of the hints and tips given out on this forum.
Thanks to you all...Kenny
    November 2008
Posted by Satori on Tuesday, March 17, 2009 1:37 PM
Please check your private message for some info on the gun carrier.
    March 2004
Posted by Mikeym_us on Tuesday, March 17, 2009 9:18 PM
I have this kit in the stash actually it just arrived yesterday and am going to accurise it to some degree or another.
ok here is some critiques
1) Build looks pretty good but your rubber rims on the road wheels look like the paint was stripped off? What you should do is use acrylic powders or real mud to weather tires.
2) 37mm Flak ammo is color coded for HE incindiary and AP incindiary don't quite know the colors offhand but I think they are red and yellow.
3) good job on the flash supressor but the brake for the muzzle doesn't exist but there is a section behind the flash supressor that is also supposed to be opened as well.
Oh and before I forget Road wheels are supposed to show lots of abuse so well abuse them just not to heavily. A gouge here and there will work just fine.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    August 2011
Posted by THEFED on Monday, August 29, 2011 1:08 AM
I have a question,what did you use for the shell ejection netting?
Thanks,
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Monday, August 29, 2011 1:37 AM
http://t2.gstatic.com/images?q=tbn:ANd9GcSvenJJUCvNwpIvsH3lvBY6EbmgjgGG8NpULWlEt6gRGf1D4rdmKJgNvAMaybe a bit less "shiny" black showing on the wheels.
  Other than the frustration with the tracks it looks to have turned out really quite well.
                             http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
    December 2008
Posted by psstoff995's lbro on Monday, August 29, 2011 12:45 PM
Nice work there! Looks great. Yes
-Will young modeler Test fit master
    August 2006
Posted by K-dawg on Monday, August 29, 2011 2:10 PM
Kenny, Very nice build for sure!! I only have one suggestion. The mud on the road wheels (which i assume is pigments) could use a bit of massaging to take away the stark black rubber vs solid mud. You can take a small round or flat brush and gently move the pigments around a bit to blend the edges and use some of the pigment to dull down the stark black. There is no need to re-wet them. Reworking them a little dry will make a world of difference. This includes the chassis and body panels that have pigments on them as well.. Won't take but a few minutes.
One thing I consistently see is that often times modelers don't work with the pigments enough once they're applied. Wetting them and smearing them on is only the beginning. As I said, you've done a great job, but I really think you could ramp the weathering up a notch with a little more time spend spreading the dry pigments around.
Kenneth Childres, Central Arkansas Scale Modelers
    July 2004
Posted by wbill76 on Monday, August 29, 2011 2:15 PM
Guys, check the date on the original post...3-13-2009...this one rose from the dead after 2.5 years...and Kenny's abilities have improved in that time span as well. Wink
    March 2004
Posted by Mikeym_us on Monday, August 29, 2011 2:53 PM
Nice thing about this kit is that if you want to change out the kit barrel with a LionRoar or Griffon Turned brass barrel the reciever already has the hole to install the barrel.
List of items you can use to make a diamond out of this kit
Eduard PE set for the S.W.S which includes parts for both the S.W.S and the Flak43
Griffon Models 3.7cm clips for the Flak43 (10 clips are in the set)
Griffon Models 3.7cm ammo
LionRoar or Griffon Models 3.7cm Flak43 barrel
Friulmodel tracks for the S.W.S which include the drive sprocket and are what I call "Ambidextrus" tracks
    November 2004
Posted by spacepacker on Monday, August 29, 2011 4:37 PM
Hi, I did'nt expect to see this turn up again.
THETFED, I bought the mesh from an Auto repair shop; its what is used for body repairs. Its not to scale but not a long way off.
Thanks once again for all of your comments...cheers....Kenny
