DML Pzkpfw III Ausf G Afrika Korp Blog COMPLETE 01-11-2010
    January 2009
Posted by Schnobs on Wednesday, December 23, 2009 12:07 PM
Merry Christmas Billiam!
I have been remiss on responding to your posts as of late.  i read them of course like a good newspaper column but then I get too busy to post a reply.  THIS ENDS NOW!
Your Jerry can rack is sublime and your PE is deviine!
Love PZ.III's  at this stage they look like beetles without their road wheels
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance. That principle is contempt prior to investigation." Herbert Spencer
Posted by tigerman on Wednesday, December 23, 2009 12:10 PM
Looking smart Bill. Lucky you get a little play time. I'm out of commission until after New Years.
 Eric
    July 2004
Posted by wbill76 on Wednesday, December 23, 2009 1:06 PM
Merry Christmas to you too Edmund! Glad to hear you've been following along, I've been enjoying your LRDG build as well...'tis the season for desert builds I guess! Wink
Eric, sorry to hear you are out of commission but hope you will get some build time in after the New Year! Thanks for the comments and for following along. Yes
    August 2008
Posted by Pvt Mutt on Wednesday, December 23, 2009 1:08 PM
Now that is what I call boo coo progress Bill.Cool
Bill I want to wish you and the family a Very Merry Christmas. Thanks for the informative builds you've given us this year.
More importantly, Thanks for the helping hand you given me all through the year my friend.Toast
Tony and Catherine
Shoot Low Boys They're Ridin Ponys
    July 2004
Posted by wbill76 on Wednesday, December 23, 2009 3:11 PM
My pleasure Tony and a very Merry Christmas to you and Catherine! I've enjoyed your contributions to the forum as well, may 2010 be a prosperous modelling New Year!
Bill
    July 2004
Posted by wbill76 on Wednesday, December 23, 2009 8:32 PM
Today was another productive day with all major construction completed. Picking up right where I left off, I added the wiring conduit from the siren/indicator light down to the main headlight with 0.5mm diameter solder. This was carefully bent to shape and then glued in place with liquid glue. Once that had dried, I added small retaining brackets using the flexible bits on the Eduard frets that are the connection points for regular PE parts that were bent to a curved shape around a piece of solder with tweezers then glued into place with CA gel.
The remaining element from Step 14 was also dealt with by installing the mount for the antenna swivel arm to the hull side. The kit doesn't provide an antenna, so I clipped off the stub that was molded onto the swivel arm and drilled out a hole with a #72 finger drill and installed a Lion Marc 2m brass antenna with CA gel. To protect the antenna, this was only dry fit for the shot to be sure I had the alignment correct for the mount and will be permanently installed later.
The remaining steps deal with the turret and Step 15 assembles the top and bottom halves along with the hatch hinges and interior frames and turret front plate.
Step 16 adds the interior portion of the gun mount and hinge pin covers and can remain movable after installation if you don't apply glue to the hinge parts E30 and E31 where they mate up with the assembled E25 and E26. I also skipped ahead a bit to Step 20 since I am replacing the gun and mantlet entirely with the Armorscale barrel and resin mantlet. Adding it now is much easier than after all the details were installed and some small surgery was needed on the Armorscale resin mantlet to get it to fit. The back of the resin mantlet has mount points and guides that are designed to work with the newer DML Smart Kit and these all had to be cut down and sanded smooth to allow a proper fit to this older kit's mount parts. The mantlet was glued in place with CA gel and there's sufficient stiffness in the pins to support the weight of the gun so for now I haven't glued it down but will after painting to pose the gun at the desired angle.
Steps 16-18 deal with various details including the turret stowage bin. The bin assembles easily enough but the base is hollow so this needed to be blanked off using sheet styrene  to avoid it being visible once mounted. Some putty work was also needed at the top portions to create the right seamless look.
The rest of the turret details were added as called for in the instructions and everything was going great right up until it came time to add the side hatches. The kit provides some nicely detailed doors and hinges and the doors fit very tightly together. While I was test fitting one side, the smaller half of the hatch pinged off into oblivion...I spent a full hour carefully searching the work bench, shelves, and floor but to no avail. This required a "Plan B" solution which involved removing the hinge points and using the one-piece hatches provided on sprue F and marked as not for use instead. The detail isn't as good but at least I still have hatches!
The turret lifting eyes were the only parts that required some modifications in these steps...the kit parts aren't really hooks as they are molded as solid knobs. I opened them up by drilling a hole in their centers with a #76 finger drill and the carefully creating the "hook" by cutting into the hole with the tips of my sprue cutters and then carefully removing the base to create the hook.
A test fit to the hull showed everything is playing nice together and the turret fits well into the ring opening provided. I had originally planned to fit a small canvas dust cover to the gun barrel but have decided against that as I don't want to cover up the nice detail provided by the Armorscale barrel. That means this one's ready for paint as the only other thing remaining is the track assembly and I can do that while the paint is curing.
    January 2009
Posted by Schnobs on Wednesday, December 23, 2009 11:11 PM
Bill your man crush on PZ.III's shows through everytime you build one.
I would dare to say it's your favorite vehicle.  Your details look great and Merry Christma Eve Eve!!
    July 2004
Posted by wbill76 on Thursday, December 24, 2009 11:03 AM
Thanks Wayne! I'm looking forward to the paint stage as well as this will be the first time I apply a '41 Tropen scheme so I'm breaking some new ground in the process. Wink
Edmund, the Pz III is definitely one of my favorites, 2nd only to the Pz 38t family in fact. The workhorse of the Wehrmacht from 1940 through 1942 until the long-gun Pz IV took over the MBT role, it is often not thought of in those terms and is left in the shadows a bit. Since the older kits require some work anyhow, I always try to individulize them a bit where possible, especially since the Pz IIIs were widely photographed and there's plenty of room for improv!
    August 2008
Posted by Pvt Mutt on Thursday, December 24, 2009 11:21 AM
Nice build Bill but i'm waiting on the paint job.
Your town was just on the news I think and the snow was flying.Zip it!
Tony Lee
    July 2004
Posted by wbill76 on Thursday, December 24, 2009 11:24 AM
Not us Tony, no snow today! It was cold and rainy yesterday and is just cold today (all relative of course...) but no snow. Must be somewhere else in Texas!
The weather looks like it's going to be good enough to allow for paintwork today so keep your fingers crossed!
    July 2004
Posted by wbill76 on Thursday, December 24, 2009 9:10 PM
While we were spared the really severe weather here in El Paso that the rest of the plains/rockies got yesterday, it was still relatively cold here in the desert with the temps in the mid-to-high 40s. The wind wasn't very strong though, so that meant I was able to get some paint work done in the garage without freezing in the process.
I started in by applying a primer coat of Model Master enamel Italian Dark Brown. This allowed me to check all the putty work I'd done previously and also provides a nice underlying coat over the kit plastic to make sure I don't leave any bare spots along the way.
This was followed by the base coat of MM enamel Afrika Grunbraun '41, Testors' version of RAL 8000 as called for in the Tropen scheme authorized for the N. Afrika theater. I applied this in multiple mist coats to build it up over the primer coat.
Next came the camo pattern of 1/3 disruptive RAL 7008 in the form of MM enamel Afrika Khakibraun '41. This was applied as the light was fading and I can see there are a couple of thin spots that I need to work on, I'll take care of that tomorrow but the pattern is at least on.
I also worked on the road wheels, including the spares that will mount on the fender and at the "cow catcher" front with the spare track run to be added later. These were primed with the Italian Dark Brown then had the rubber rims air brushed with MM enamel Gunmetal. The inner hubs were air brushed with a custom-mix for the Red Oxide primer using a circle template while the outer hubs were air brushed with the RAL 8000 base coat color to match the hull, also via circle template.
    October 2007
Posted by panzerguy on Thursday, December 24, 2009 9:51 PM
  Bill even though the site has changed the quality of your wips remain the same; OutstandingYes!
  I also checked out your Tiger(P) and that thing is super cool. And thanks for doing the side by side. I really thought that the P hull was much longer than the E's. Must be that since the turret is so far foward that it looks longer than it isWink.
"Happiness is a belt fed weapon"
    July 2004
Posted by wbill76 on Thursday, December 24, 2009 10:39 PM
Thanks Steve and Merry Christmas to you!
Glad you liked the Tiger P, you're right about the size dimensions...it's all in the perspective of the hull vs. the turret that makes it look bigger than it really is.
    April 2005
Posted by wing_nut on Friday, December 25, 2009 6:39 AM
I nearly forgot about this one.  Looks real nice too.  The fender mods will makes one stand out from the crowd.
Marc
    July 2004
Posted by wbill76 on Friday, December 25, 2009 12:14 PM
Thanks Marc, glad you've caught up to this one. Appreciate the comments! Yes
    September 2005
Posted by treadwell on Friday, December 25, 2009 5:18 PM
Merry  Christmas , BillBig Smile
I just finished reading your build to date. It was like getting an extra present under the tree.Toast
treadCool
    July 2004
Posted by wbill76 on Friday, December 25, 2009 8:11 PM
Thanks Brother Tread and a very Merry Christmas to you too! Beer
    May 2005
Posted by hughes2682 on Saturday, December 26, 2009 8:51 AM
Bill,
A merry belated christmas to you!  I am catching up on recent builds here at FSM.  I've been out of the loop for a bit.
I am really liking your latest posting.  The Jerry cans are a nice touch.  And as always the attention to the wee details. I've got this one marked so I can keep up on it.
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    July 2004
Posted by wbill76 on Saturday, December 26, 2009 10:35 AM
Thanks Dave, appreciate the comments and the interest! Hope you had a Merry Christmas as well!
    November 2006
Posted by dupes on Saturday, December 26, 2009 12:02 PM
wbill76
After much thought and deliberation, I've decided to use the reference photo below found in Trojca's Sdkfz 141 Pzkpfw III and will attempt to recreate some of the key features shown. Specifically, I will be modifying the fender to remove the forward section and rearranging the gear on the fenders as well.
http://www.bpmodels.net/Model/Pz3G/Ref1.jpg
Interestingly enough, the MK track set box has a photo of a build of this same vehicle replicating everything including the stowage and figures that will also provide some valuable insight. Work is getting ready to start on the upper hull and fenders so this was the right point to make a decision one way or the other!
Bill - don't know if you have access to "Armor" magazine (the Spanish one reprinted by Squadron) but there's a buildup in one of the back issues of that exact vehicle, including sculpting of figures in the poses shown in that shot you have there! I could certainly dig it out if you're interested.
Looking good so far as usual. WinkYes
    July 2004
Posted by wbill76 on Saturday, December 26, 2009 12:09 PM
Marc,
Appreciate the offer. Will shoot you a PM. Wink
    February 2009
Posted by scratchmod on Sunday, December 27, 2009 9:22 AM
Sorry for not posting anything lately Bill, but I have been admiring this build on the sidelines. What can I say, it's another awesome model built to your high standard. This is looking VERY nice so far Bill, but you know the painting stage is what I enjoy the most so get'er done and start that painting.
Rob
    July 2004
Posted by wbill76 on Sunday, December 27, 2009 10:55 AM
Thanks Rob, but, uh, the painting stage is done <nudge nudge> and the camo applied. The weathering stage however is still on the horizon but fast approaching! Wink Propeller
    February 2009
Posted by scratchmod on Sunday, December 27, 2009 11:02 AM
You know Bill, I was looking at the camo too. Musta had a brain fart again. I've gotten used to your painting sequence that it's a norm. The camo is what I like the most, it's accurate, reminds me of the Pz IV F2, some thing about the two colors I like. I would like to use those colors but not in enamels, you know me. OK what I want to see is the weathering, must have been what I was thinking when I wrote the first post.
Anyhow, this baby looks great Bill.
Rob
    July 2004
Posted by wbill76 on Sunday, December 27, 2009 12:45 PM
No worries Rob, I had a feeling it was the weathering stage you were looking forward to! Big Smile
Wayne, channeling the inner Homer...priceless! Wink
    July 2004
Posted by wbill76 on Sunday, December 27, 2009 3:50 PM
With the inevitable break in bench time that Christmas involves, I was able to get in some more progress today. The day's not over but the next round of work involves assembling the MK tracks so I figured I should go ahead and post what has been done and buckle down and get the tracks built!
First order of business was joining up the road wheel halves and then installing them to the hull. This was done using regular glue to allow for some adjustments where needed to get the wheels to sit level. The return rollers were also added. The hull was set off to the side and allowed to set up for a while to avoid disturbing the wheels.
I stayed busy by working on the fender gear details while the wheels set up. The pioneer tools had their metal portions painted with MM Metalizer non-buffing Gunmetal and lightly dry brushed with Steel while the wood portions were painted with a special "wood" mix that's a light tan color followed by a light wash of thinned Leather. Once the wash was dry, I added some additional color variation using artist pastel Burnt Umber applied with a square tip brush. The Bakelite handles on the wire cutters were painted with Italian Dark Brown and the rubber end caps with enamel Gunmetal. The tools were secured in place with the Griffon clamps and a small amount of liquid glue added to insure they didn't shift around any in the future. I added a clamp handle courtesy of the Griffon clamp set to the shovel clamp for a little more detail as well.
The extra road wheel on the left fender was also added and positioned carefully so as not to interfere with the turret rotation overhang. I also detailed and installed the jerry cans for the right fender. These were first airbrushed with Panzer Gray and the spouts were detailed the same was as the metal portions of the pioneer tools. I added the water can cross markings by hand to simulate the same way the crews did it with Light Gray and also added some scuffing and wear by lightly brushing some Steel along the edges and bases of the cans.
I also secured the gun elevation in a fixed position at this stage by applying some liquid glue on the inside of the turret to the hinge points. I held the barrel and mantlet in position until the glue "grabbed" enough to hold the weight and then let it set up.
The rear hull details also got some attention. I picked out the rear Notek lenses with Tamiya Clear Green and the brake light lenses with Clear Red. The mufflers were also detailed with a basecoat of non-buffing Metalizer Gunmetal followed by a wash of Rust and some dry brushed Burnt Umber. The smoke candle chains were detailed with the same Metalizer Gunmetal to round things out in this department.
Now it's off to watch some football and begin assembling the MK tracks!
    January 2009
Posted by Schnobs on Sunday, December 27, 2009 3:58 PM
Hi Bill,
I love the subtle cammo and the jerry can rack is great and I will be copying that for sure.
Enjoy watching other men excercise er I mean Football!  Big Smile
    July 2004
Posted by wbill76 on Sunday, December 27, 2009 4:16 PM
Thanks Edmund, glad you like the rack! My local TV stations aren't cooperating much in terms of available games...but it's really just background noise to help with the repetitive nature of the track assembly more than anything else. Doesn't really matter who's playing! Wink
    July 2006
Posted by redleg12 on Sunday, December 27, 2009 6:02 PM
Holy Excrement Bill....
I was just thinking I have not seen a Bill WIP in a while....with all the bovine scatology of the new and disproved FSM forums...I missed it. Now after going through the whole build to date......very nice as usual. Very nice details. I love the paint scheme.
Now.....this new fangled forum must have a Bill tickler somewhere.....I can't go this long without a Bill build.....well thank god I found it....who knows, if I missed the whole thing next cats and dogs would start living together!!
As always, it is a pleasure to see your work.
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    August 2008
Posted by Pvt Mutt on Sunday, December 27, 2009 6:31 PM
Yep I definitely see another paint color scheme i've just got to do now Bill.Bow Down
Thanks        Tony Lee
