Tamiya Cromwell WIP **FINISHED**
    November 2008
Posted by iraqiwildman on Saturday, October 30, 2010 5:44 PM
Hello all. This is my first build log, so here it goes.
I am using the Tamiya 1/35 Cromwell IV with the Tamiya photo-etched screens and Verlinden update kit #1413. This Cromwell kit was recommend by many on this forum last summer.
I got this resin update kit on ebay for under $10. It has a great trio of figures, storage boxes for the turret and an extra rear fuel tank. A few of the parts were missing and the PE screens are very sloppy. The Tamiya PE are great though.
I have never worked with resin before and limited experience with PE, so this will be a challenge. I also build a photo box to get some decent photos.
Thanks,
Tim Wilding
Tim Wilding
    December 2006
Posted by Jester75 on Saturday, October 30, 2010 5:56 PM
Cool, looking forward to seeing your work. I always buy my Verlinden stuff on eBay from the seller 3dverlinden. Not sure but I think its direct from them.
Eric
    November 2008
Posted by iraqiwildman on Saturday, October 30, 2010 6:08 PM
The hull is coming together well. This kit has very good fit. The rear fenders are a little tricky to get lined up. I added the Verlinden back deck and external fuel tank. The PE strap gave me a fit, they keep wanting to pop off when bending them down. I waited over an hour for the super glue to set and they worked fine then.
The handle on the fuel tank also did not make sense they way Verlinden had them. They were not marked on how to bend and broke when I tried to bend them how I though they should go. I ended up drilling holes and treating them like tie down handles.
I added the resin engine detail, but might cover this up with the engine hatch. The details are good, but it is only about 1/4 deep.
The front hull is per instructions. I drilled out the machine gun and only open the driver's viewing slit. There is no interior deatil, so I also closed the gunners hatch. I will use one of the Verlinden figures as the driver.
I look forward to all comments and suggestions. This is my third armor kit and am wanting to try some new techniques.
Tim
Tim Wilding
    November 2008
I am working on the turret now and will hopefully post more later, but my wife is setting up for our halloween party tomorrow.  I wanted to dress up like Manny, but she said "No Way"
Tim Wilding
Posted by tigerman on Saturday, October 30, 2010 9:06 PM
Off to a great start. This was a fun one to build up.
 Eric
    September 2009
Posted by Hinksy on Sunday, October 31, 2010 6:24 AM
Good choice!
This was one of my very first builds and it was a superb kit!
OOB it built up very quickly due to low parts and it all being pretty straightforward but you should have some fun with it with your extras.
I'd love to have another go at this kit with the PE and an AM barrel / tracks now that I've learnt a bit.
I seem to recall two things to watch out for - the joint seam where the barrel halves join and the plastic 'rim' which fits over the mesh at the rear - mine wasn't wide enough and I had to slice it in half to make it fit then fill the gaps - it was only too small by about 1mm. Perhaps it was just me at the time!
Best of luck,
ATVB
Ben Yes
On the Bench - Dragon Pz. IV Ausf. G (L.A.H.) Yes
Your image is loading...
    November 2004
Posted by Bronto on Sunday, October 31, 2010 8:07 AM
Great start on the Cromwell.  Watch the turret bins in the Verlinden set though, they weren't used with the hull type that Tamiya has included
    November 2008
Posted by iraqiwildman on Sunday, October 31, 2010 9:55 AM
Thanks for the comments, guys.
Bronto - I was wondering about these bins. I found pictures of real Centaurs with them, but only other Cromwell models with them. I also like the turret shape as is, so these bins might go into the spare parts bin. I never found any photos of the extra fuel tank, but I have seen them on other British tanks, i.e. the Matilia on this forum header.
Ben -  I was going to see how these barrel went together before getting an AM one. I just got a $1000 root canal, so money is a little tight this month. Did I mess up the screen on the back? I was not sure if this mount went on top of the PE part or under. I did it under, but am not sure now.
Tigerman and Jester, good to have you two along for my first build log.
Tim Wilding
    January 2007
Posted by the doog on Sunday, October 31, 2010 10:28 AM
Nice work so far on this kit--you have to watch with Verlinden stuff though. Do your research and don't necessarily trust Verlinden's accuracy on everything. Some of their stuff is pure guess work, or taken from maybe prototypes or inaccurate museum pieces. Their interiors are especially suspect.
Make sure you always use a face mask when sanding resin, too. That stuff will slice up your lungs if you breathe it in.
    July 2004
Posted by wbill76 on Sunday, October 31, 2010 12:49 PM
Looks like you're off to a roaring start with this one. I don't blame your wife for saying no to you dressing up like Manny...that sort of costume could scar small children for life. Big Smile
    September 2009
Posted by Hinksy on Sunday, October 31, 2010 1:49 PM
Hey Wildman,
The barrel will clean up ok if you use the kit barrel but a replacement one should be pretty cheap, literally a few Dollars.
I seem to remember that when I built mine there was a suplied black plastic 'mesh' that ou trimmed to size and placed over the big air intake at the rear. When in place you either used the plastic rectangular frame or the 'Normandy Cowling' (the arched funnel) to sit over the top. I remember that during my research I came across an involved website all about the Cromwell and the Cowling was mentioned. The site said that it was designed but there was a very good chance that it never saw service - I might be totally wrong but either way I had no intention of using it. I cut my mesh screen down to size and found that the rectangular mesh cover was a tad too small and needed doctoring to make it fit.
If I remember correctly the mesh should sit under the cover, the cover held the mesh in place. Have a quick look at your instructions and see what it says as I'd like to know now! It was a good year ago that I built my Cromwell so I'm a bit hazy on how it all went together now!
I hope this helps,
ATVB
Ben Toast
    July 2004
Posted by stikpusher on Sunday, October 31, 2010 2:01 PM
This kit is one of my favorite builds! It is an excellent choice! Just what one needs after too many frustrating kits... Yours is coming along very nicely! My only recommendation is to replace the kit tracks with some AM ones. Hobbyboss makes some very affordable ones. The kit tracks on both my Cromwell and Centaur eventually broke...Angry
BTW, yes the Normandy cowl was used operationally. Look at this pic of Guards Armoured Division Cromwells crossing Nijmegen bridge.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November 2008
Posted by iraqiwildman on Monday, November 1, 2010 3:43 PM
Doog - I am finding out what you mean about Verlinden. This photo from Stikpusher is the first I have seen with these storage boxes, but it's from late in the war. At least I think that is a storage box on the back of the turret. Interestingly, it still has the "Normandy Cowling" 9 months after D-Day, but I have read this actually helped with airflow. Also, I will remember to get that mask on.
Stikpusher - thanks for the photo and info on this cowling. It has me looking at XXX Corp Cromwells later in the war for more photos.
Ben - I still have not looked at this screen. I had to take my workbench / folding table down for use  at a halloween party and I will be reconstruction my work area tonight.
Bill - Thanks for the encouragement.
Thanks all,
Tim
Tim Wilding
    March 2010
Posted by Hercmech on Monday, November 1, 2010 3:48 PM
At the risk of being brand a heritic I think the Cromwell is my favorite Allied tank of the period. Your off to a good start. cant wait to see it finished.
One question off model topic...what material are you using for the diffusers on the light box?
13151015
    July 2004
Posted by stikpusher on Monday, November 1, 2010 3:49 PM
That pic is from Sept 1944... Not too long after Normandy, and still over 7 months left of campaigning in the war.
       - Plankton
LSM
    November 2008
Posted by iraqiwildman on Monday, November 1, 2010 5:05 PM
stikpusher
Sorry, I was think Remagen in March 45.
Tim Wilding
    November 2008
Posted by iraqiwildman on Monday, November 1, 2010 5:07 PM
Hercmech
Just plain legal size copier paper. I need to get some tissue paper and replace it. I think this would help with the brightness.
Tim Wilding
    April 2009
Posted by deafpanzer on Monday, November 1, 2010 6:55 PM
Looking great Tim! Yes I am not into British armor but if somebody had a gun against my head, I think I will go for this Tamiya kit so I will be following your work.   Did you buy it at Hobby Lobby?  I was wondering because one I shop at don't stock this kit.
Andy
    November 2008
Posted by iraqiwildman on Tuesday, November 2, 2010 8:59 AM
I got this kit at My Atomic on the internet, before they went out of business and took me for $35 - I ordered a Tamiya JS-2 Stalin a few days before they closed shop.
Tim Wilding
    November 2008
Posted by iraqiwildman on Monday, December 13, 2010 9:18 PM
I have most of the construction done without any major problems. I decided against adding the Verlinden storage boxes. I could only find these on the howitzer version, the Centaur. I tried out replacing the tie down with brass wire. This is new to me and lots of trial and error.
I also covered up the resin engine from Verlinden. It had good detail, but was too shallow.
I think this will be the storage layout
Primer will come next and some pre-shading.
Tim Wilding
Posted by tigerman on Tuesday, December 14, 2010 12:06 AM
I love that fule tank.
 Eric
    November 2008
Posted by iraqiwildman on Tuesday, December 14, 2010 8:37 AM
I wonder if there should be a fuel line running from the extra fuel tank into the engine compartment? Or was this just a storage tank and then pumped into the tank's regular fuel tank?
I quess I should have dusted the resin dust off the engine deck before taking the photos, sorry.
Tim Wilding
    August 2003
Posted by Nachtflieger on Tuesday, December 14, 2010 3:33 PM
Great job on the extra detailing, it's coming out excellent.Yes
Nate
    November 2008
Posted by iraqiwildman on Monday, January 31, 2011 7:40 PM
After a little holiday break, I started back on this project. I have been working on the figure and them priming these cromwell nad figure with Model Master grey primer thinned with Testor's airbrush cleaner. This cleaner seems to give MM paint a good flow through the airbrush.
I preshaded with Tamiya flat black. I also sprayed the road wheels all black and use a circle templete to paint the hubs.
My 8 year daughter liked the tank like this and did not want me to paint it OD green, but  this is a little historical inaccurate.
Tim Wilding
Posted by tigerman on Monday, January 31, 2011 10:08 PM
Glad to see that your back to work on this. I noticed the extra detailing around the spotlight. Nice touch.
 Eric
    April 2009
Posted by deafpanzer on Monday, January 31, 2011 10:27 PM
Bet you had a nice holiday break because it shows that you are doing very well to your Cromwell.  I have been doing pre-shading for my last three builds and it can be very tricky.  First attempts the base coat just covered most of my pre-shading work! Bang Head  It works better if you can thin the paint as much as you can.  I used 50/50 and make few quick spraying runs until I am satisfied.  It is very easy to go overboard! Stick out tongue
Looking forward to your next update! Yes
Andy
    November 2008
Posted by iraqiwildman on Tuesday, February 1, 2011 7:57 PM
We are having the first ever blizzard in Central Missouri, so it is a good day to stay home from work and do some airbrushing. 40mph winds and 15 inches of snow so far.
Painting was done with all Tamiya paints, Olive Drab with some Buff and a little White mixed in. I really tried to lay on light coats as not to cover the pre-shading. I then added more white and faded the center of the panels. This is my first try at this and I very happy with the look this gives.
It looks like more snow tonight and high winds tomorrow, so another day off. I hope to get a caot of Future on and the decals. But I will probably be too wipped from shoveling the driveway.
Tim
Tim Wilding
    July 2004
Posted by wbill76 on Wednesday, February 2, 2011 2:11 PM
Coming along nicely, paint job looks like it's a good foundation to work off of. Enjoy your extra bench time due to the snow!
    April 2009
Posted by deafpanzer on Wednesday, February 2, 2011 5:07 PM
I agree with Bill!  I love the pre-shades... it really works if you do it right and you did! Yes
Andy
    October 2009
Posted by PANZERWAFFE on Friday, February 4, 2011 11:20 PM
Nice work on the extra details and the pre shading looks great.  Really good work, waiting for more.
Rob
