OK i'll confess to doing a little extra on this kit.
There are two suggested fixes that Terry Ashley passed along in his review at PMMS.com
The first I did was add 4mm to the front axle,2mm to each side. Using the kit sprue since it's the same size as the axle I cut the axle near the spindles and added a 2mm slice of sprue to each side. You also need to add 4mm to the cross over tie rod too,I used Evergreen rod for this.
Second was raise the frame.
The ammo area of the storage bin needed some eye candy next:
I cut one of the compartments open and added a partition panel:
I bought the Bronco Russian 7.62cm ammo kit and loaded it with eight rounds. The Diana carried 32 shells.
The simulated canvas cover flaps are pretty non-convincing so I used the foil liner from a cigarette pack to make new ones and rolled one up so the shells would show.
I'm going to leave the rear door open so that gap had to be closed with a strip of plastic yard sale sign:
The shop reopens in the morning and I don't know what i'll do next,maybe some wiring and plumbing.??????
Hope you approve of my efforts
Tony lee
