Drybrushing over Panzer Gray?
    June 2010
Posted by DoogsATX on Friday, August 26, 2011 10:22 AM
Figuring someone can point me in the right direction here.
Doing my first Panzer Gray build. Not sure what colors I should use to do some subtle drybrushing.
So far I've used dunkelgrau with allied armor, and I've used dunkelgelb over whitewash to tone it back. Dunkelgrau seems like a decent possibility here, too, but I'm afraid it might be a bit too tan and too light considering how dark the gray is.
So on a full-on, intimidating as all get-out, not-lightened Panzer Gray, what works best for drybrushing?
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    March 2009
Posted by Lundergaard on Friday, August 26, 2011 10:48 AM
on some scrap you could try adding a bit of "neutral gray" to your panzer gray and see how that goes on.  at least the color won't be shifted warm or cold... i think.
andy
    March 2009
Posted by Lundergaard on Friday, August 26, 2011 10:58 AM
and now i see you don't want to lighten your panzer gray.  dang.  sorry.  well... that's what i would try anyway.  Wink
Posted by Bish on Friday, August 26, 2011 2:32 PM
I always thought the idea of dry brushing was to add lighter tones of the base colour. I just use the colour i painted the kit in then add a touch of white oil paint.  Short of that, i would have no idea.
    June 2010
Posted by DoogsATX on Friday, August 26, 2011 2:49 PM
Well, I picked up a bottle of MM Panzer Schwarzgrau at the LHS today. It's a somewhat lighter shade than the Lifecolor, so I'm hopeful that'll work.
Bish
Well, on my allied armor, I use dunkelgrau, and it plays very well with OD.
Just not sure how to handle this really dark gray. Still have the white and markings to go before I reach that stage, though...
Posted by Bish on Friday, August 26, 2011 2:50 PM
I will be keen to hear what suggestions you get. Dry brushing used to be all the weathering i did, but never thought about useing other colours. I got my methods from a Tony Greenland article in a very old FSM, so maybe time to learn something new.
Dre
    June 2007
Posted by Dre on Friday, August 26, 2011 2:52 PM
You could try a primer red in certain wear areas to get a different look....
    June 2010
Posted by DoogsATX on Friday, August 26, 2011 2:58 PM
Bish - I picked up the dunkelgrau tip from an FSM article that ran last fall.
Dre - From what I've gathered of the particular Panzer I'm building, they arrived "fresh off the train" near Leningrad in October or November 1941. After a heavily-weathered Pz.IV, I'm doing this one more pristine. Not much wear or fading. Only drybrushing to add a bit of depth and slight amount of wear.
    September 2008
Posted by maxfax on Friday, August 26, 2011 3:51 PM
Hey Doogs, I don't think you can really go wrong with a whitened base colour or lighter shade of a different gray. The amount of paint is minimal anyways, and just highlights edges/ pronounced details, which would vary under differing light conditions. I have used gray on Russian armour green on my su-100 build and a yellowy-green on Russian armour green for my kv-1 build with, what I thought were good results. You are good at experimenting!
On the bench:  Revell 1/72 HCMS Snowberry
    January 2007
Posted by the doog on Friday, August 26, 2011 4:44 PM
Bish
Don't use white oil--it will leach out of the paint and disappear after a while. White oil paint does that for some reason. When I used to paint my figures' faces highlights, I would notice that in about 6 months' time they would all look sunburned or wizened-brown. It was because the white oil that I used with other colors would absorb into the base color. I don't know why it does this, but it's a measurable phenomenon.
Use tan over Dark Gray. A good light dirt color can work too. Lightening anything "gray" always tended to look either too blue, too light, too unrealistic for my taste. However, a tan drybrushing gives you a nice light-weathering look that looks appropriate for these gray panzers which spent a lt of time in the dusty summer months of either France or the East.
Posted by Bish on Friday, August 26, 2011 6:53 PM
I do mix the white oil with enamel paint, and so far haven't found it a problem. But my next armour build is a Pz Grey 251. I was planning on giving it some heavy dusting, so i may try that suggestion when dry brushing.
    June 2010
Posted by DoogsATX on Friday, August 26, 2011 7:06 PM
Karl - excellent! Thanks much!
I think for starters I may try a mix of Pz. Schwarzgrau and Dunkelgrau, then adjust if it's too stark or too subtle.
Posted by Bish on Friday, August 26, 2011 7:11 PM
Be sure to share your results. I for one will be keen to see how it comes out. I haven't done a Pz Grey scheme for years and certainly not since i started weathering seriously.
    June 2010
Posted by DoogsATX on Sunday, August 28, 2011 2:16 AM
And the winner is...DUNKELGRAU!
Thanks Karl for chiming in about the tan. I was hoping it'd work since I was really happy with the results I've gotten on allied armor, and it definitely adds in some warm tones to counteract the bluish cast coming off the straight paint job (especially now that the white blotches are in place).
