Bronco Pzkpfw I Ausf. F VK 18.01
    July 2004
Posted by wbill76 on Sunday, March 23, 2014 4:44 PM
It's been a while since I've built an armor project, kept getting side-tracked by different things but have finally gotten back to it with a project I've been wanting to do for a while, Bronco's Pzkpfw I Ausf. F (VK 18.01).  Got things off and rolling on this build by doing things a little differently. Bronco includes a lot of detail for the fighting compartment interior and also constructs the hull out of multiple panels vs. providing a single 'tub'. Ordinarily I wouldn't be that big of a fan of this approach but with all the interior detail and how tiny this vehicle is, this is actually a plus on this particular build as it lets you work with each panel separately. So, the first order of business was to prep all the major hull panels and the compartment floor and do a mock-up using masking tape to hold things together to ensure there weren't going to be any surprises along the way.  No major issues to report but it will be fun installing all the suspension torsion bars and getting all these elements together permanently once the detailing and paint work is finished, but we'll cross that bridge much later on! Because many of the interior components are made up of multiple parts, some tiny, some that require fit with other small parts, etc., I bounced around between various steps while glue set up to try to make the most of my available time. Taking advantage of the hull mock-up situation, I assembled the various transmission and drive-shaft components and also connected the firewall to the large transmission cover housing since those are initially separate pieces. The alignment here is key as it drives (no pun intended!) not only how the firewall sits but also where the commander's seat lines up and how everything interacts at the front of the hull. No real margin for error here either given how tightly packed everything is on the inside.  Once the glue had set on the transmission and firewall combo, I undid the mock-up and restored everything back to its panel parts for easier handling. The tiny driver's pedals were added and the driver's and commander's seats assembled. The commander's seat is a multi-part and very delicate 'free standing' assembly...so lots of care needed here to get it all together and aligned correctly. I left the headrest and main seat cushion separate for now to make it easier to paint them and will add them later.  One of the really nice features of the kit IMHO is the inclusion of workable crew side escape hatches. Yes, that's right, fully workable...but you do have to be very careful with the assembly and where you put the glue, but in the end if you do it right, they will work just like on the actual vehicle. Only downside is that they tend to want to swing open all the time, so once the glue had set on the hinge arms, I'm using small blobs of blue-tack poster putty on the inside surfaces to keep them 'closed' while work continues.   Next up will be devoting some attention to the rest of the gear details that go in this area like the radios, numerous ammo sacks for the turret MGs, crew equipment, etc.
Posted by Bish on Sunday, March 23, 2014 5:20 PM
Nice, I will be watching this. I would like to get this version of the Pz I and this looks like a nice kit so far.
    July 2004
Posted by wbill76 on Sunday, March 23, 2014 7:49 PM
Thanks Bish! I'm very impressed with the quality that Bronco provides in the details and molding. The workable tracks included are another nice feature as well as they are quite sturdy/durable design and have the hollow guide horns molded on the links vs. separate parts, always a plus in terms of speeding the assembly process. Beer
    July 2006
Posted by bufflehead on Sunday, March 23, 2014 9:48 PM
Nice to see you back here Bill!  I really like your kit choice....been eyeing several recent Bronco releases myself!  Nice work with the hull mock-up, makes it easier to get a good fit!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
Posted by Bish on Monday, March 24, 2014 3:37 AM
Sounds good. There's a few of there kits I rather like the look of, they have some interesting subjects, and I don't recall reading of many problems with their kits. I rather fancy the Pz I Bridgelayer and Pz II D myself.
    December 2008
Posted by New Hampshire on Monday, March 24, 2014 6:29 AM
Very cool, Bill!  I may take some good natured ribbing for saying it, but the Panzers I, II, II and IV series are by far more my favorites than the big V's and up.  This should be fun!  I assume you are doing it in the box shown tri-color?  That should look very nifty on this wee guy.
Brian
    July 2004
Posted by wbill76 on Monday, March 24, 2014 12:49 PM
Thanks Ernest! The hull mock-up made life easier especially as two hands could only take me so far! Big Smile
Bish, I also built their Marder II D last year and enjoyed it, so don't think you would have any issues with the standard II D or bridgelayer that they offer.
Brian, like you I'm partial to the 'workhose' models vs. the flashier 'big cats' and have been wanting to do this one for a while. I'm leaning towards a two-tone scheme since I've learned that one of the markings provided was for a unit originally planned for use in Crete and so had a 'Tropen' scheme...and some other modifications as well that could add some extra flavor to the build...have to see about that though as things unfold. Wink
    July 2004
Posted by wbill76 on Sunday, April 6, 2014 5:17 PM
Managed to get in some time on the interior bits and details on this pocket-Tiger. Bronco follows their usual penchant for tiny parts and there's a lot going on inside this little guy. First up were the 22 'standard' Gurtsack ammunition bags plus 2 'in use' bags for the twin MGs in the turret. These had 2 or 3 sprue contact points each that had to be cleaned up so was a case of '22 Gurtsacks on the sprue, 22 Gurtsacks on the sprue...cut one free and clean it up, 21 Gurtascks on the sprue!' type of effort. ;) Worth it though as they have very nice molded details and will be painted with the AB when the time comes to avoid smothering some of the finer details.  Next up were all the other different interior gear items that need to be painted/detailed separately before installation. The FE, the spare barrels case, the First Aid kit, crew mess kits and canteens (and also the gas mask containers, which I noticed I forgot while taking this pic!), the MP40 ammo case, the flare pistol and flare round holder, and the 'Gedore' tool box that goes on the compartment floor.  Little guy needs its comms gear as well, so the radio receiver and transmitter were assembled (special note, the back is hollow so if you plan to show the right side escape hatch open, this will need to be blanked off), and some holes drilled out with a #76 finger drill to take some wiring later on. Power transformer boxes and intercom box for the driver were also assembled and drilled out where appropriate.  Also took care of some other small details like the small box on the left side below the escape hatch and I assembled the driver's front hull plate. The gauge panel mounts underneath it but I'm keeping it separate for now to make it easier to detail/paint and also to be sure it's lined up properly since it has to fit just so between the transmission housing and the hull glacis plate. The hull roof plate was also prepped for paint although most of it won't be seen of course once installed in position.  Next up was the turret. Due to the size of the fully-detailed MGs, you have to install the base of the mantlet into the turret front and then install the MGs from behind through the base and into the mantlet. That's going to be real fun I can tell, but will deal with that later. Mounts and mantlet base were installed so that the guns can elevate. The fit is kind of loose so I suspect that I will be gluing that in place later on once the weight of the guns is added and the external mantlet installed. External mantlet portion was prepped for paint on its inner surface since some of it will still be visible through the open commander's hatch and I don't want bare plastic peeking in around the edges inside. Last but not least, the turret base was prepped for paint as well to round things out.  So that means next up is flinging some paint on the interior! :)
Posted by Tojo72 on Sunday, April 6, 2014 5:51 PM
Wow,thats small Bill,looking forward to that interior.What kind of tracks with the kit,or are you using MK ?
    July 2004
Posted by wbill76 on Sunday, April 6, 2014 5:54 PM
Tojo72
Thanks Anthony! It's a small little guy for sure. The kit comes with workable tracks that are quite nice, so no need for replacements IMHO. I've been working on them in little bits and pieces here and there as well when I have a few minutes to spare. This is what they look like:
    January 2013
Posted by jibber on Sunday, April 6, 2014 9:22 PM
Hardly see many Bronco Kits, and never this one. It looks like really nice detail. Nice choice Bill.
    August 2006
Posted by Gun Tech on Sunday, April 6, 2014 9:47 PM
Hi Bill! Nice going so far!
I will be following this one really closely, it's a favorite of mine.  Smile
Jean-Michel    "Arte et Marte"
Posted by Bish on Monday, April 7, 2014 3:34 AM
Nice work bill, some nicely detailed items there, are some of those resin.
    July 2004
Posted by wbill76 on Monday, April 7, 2014 10:18 AM
Thanks guys, glad to have you along for the ride!
Bish
, all styrene. One of the pics is a little darker than the others for some reason but it's all molded in the same tan styrene. Beer
Posted by Bish on Monday, April 7, 2014 10:28 AM
Really, some of those parts, especially the pic with the radio, do look like resin. And not just the colour, but the detail as well. Looks really nice.
    February 2011
Posted by Raualduke on Monday, April 7, 2014 10:29 AM
Yeah,I thought resin too. Any way looks very well appointed
    January 2013
Posted by jibber on Monday, April 7, 2014 11:36 AM
I can see a couple Bronco kits on my shelf very soon, thats nice detail.
    April 2005
Posted by JohanT on Monday, April 7, 2014 1:57 PM
Hi Bill,
What an amazing little kit, looking forward to see more of this :)
Very Best Regards
Johan
    July 2004
Posted by wbill76 on Monday, April 7, 2014 2:11 PM
I'm very impressed with the level of molded-on detail that Bronco has provided on this kit. The radios in particular. Glad to have you along for the ride Johan and jibber!
    February 2010
Posted by Stage_Left on Tuesday, April 8, 2014 3:01 PM
Hi Bill- I usually pop in on your WIPs but I need to get better at leaving a comment Embarrassed
Anyway, your treatment looks good as usual. I don't have any Bronco offerings in the stash and this'll provide me with a close look. Looking forward to more Yes
Dave
    July 2004
Posted by wbill76 on Wednesday, April 9, 2014 3:50 PM
Thanks Dave! Glad to have you stop by. Happy to provide you a sneak-peek into the wonders of Bronco kits. ;)
    July 2004
Posted by wbill76 on Sunday, April 13, 2014 5:43 PM
While the last update dealt with the interior parts, today's efforts focused on the workable tracks. Bronco provides an excellent set of workable tracks in the kit, so no need to resort to my usual trusty MK replacement strategy. The kit calls for 66 links per side but until I get the hull built and suspension in place, I only worked on 60 links to be safe. The pins for the links are molded a little funny...to save on total sprue space I guess, some of the pins are separate along the sides of the sprue while the middle run has pins in a double set. The tracks are handed, so it's important to keep track of which pins are which. Using the kit-provided jig, I assembled the runs one link at a time, cutting the pins free of the sprues and using the nub as a 'handle' to insert the pins then cutting it away after the glue had started to set on the head of the pin.  120 links later, we have two nice workable runs to play with in the future.  May not look like much, but this is a major step in the construction 95% complete until the suspension is available to test the number needed for the right sag/tension arrangement.
Posted by Bish on Sunday, April 13, 2014 6:34 PM
Nice work Bill. So I guess these go together in the same was as Fruils with the pins instead of wire. Does that little jig come with the kit.
    July 2004
Posted by wbill76 on Sunday, April 13, 2014 6:57 PM
Thanks Bish! The pins are two per link (one per side) and yes, the jig is kit-supplied, definitely makes things go together smoothly. Wink
    August 2006
Posted by Gun Tech on Sunday, April 13, 2014 7:16 PM
Those tracks are kit supplied?
NICE!!!
Bronco is fast becoming one of my favorite manufacturer!
    July 2004
Posted by wbill76 on Monday, April 14, 2014 3:25 PM
Yes indeed J-M! I was very impressed by this as it saved me another $30 or so that I would normally spend on workables. Wink
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, April 15, 2014 12:33 AM
 Finally managed to drag myself online......   http://www.animateit.net/data/media/smiley712/desertsmile.gif                             http://img.photobucket.com/albums/v481/ladyelle/Most%20used%20emots/shame.gif
       (been busy with problems in life).
Now, that's the most sensible and efficient appearing jig I've yet to see.
 It's gonna look great Bill!
http://www.bpmodels.net/Model/PzIF/Tracks.JPG
 https://i.imgur.com/LjRRaV1.png
    July 2004
Posted by wbill76 on Tuesday, April 15, 2014 1:09 PM
Thanks Steve! It definitely makes it easier to assemble the tracks for sure! Beer
    July 2006
Posted by bufflehead on Tuesday, April 15, 2014 11:01 PM
Sweeeeet tracks Bill!   Better watch out MK....Bronco's got your number!
Ernest
    July 2004
Posted by wbill76 on Sunday, April 20, 2014 5:12 PM
Ernest, your last comment slipped by me, apologies for that! I hear you about the quality of those tracks, very impressive. Beer Here's the latest: Spent the day working on the bulk interior painting to get things ready to move into the detail and assembly stage for that area. First up was an airbrush treatment of Model Master enamel Panzer Interior Buff to all the applicable hull areas and units. Because I hate to scrape paint, I used a combination of masking tape and poster blue-tack putty to mask off the hull floor and side joins to make life a little easier when the hull comes together down the road.  Ordinarily it's not worth the trouble to airbrush small detail parts but since the interior has so many, I decided this time around that the airbrush would be the better method vs. hand painting. The compartment floor was airbrushed with a custom mix of 'primer red' that I keep around but don't quite remember the exact mix ratio on...I do know it contains Insignia Red, Flat Black, and a touch of Light Gray...and a little bit goes a long way! Radio received some Gunship Gray, the seat mounts and other odd bits of gear were airbrushed with Khaki. The Gurtsacks and crew canteens are largely made of cloth or have cloth covers so I used a different shade for them, trying out some Faded Olive Drab as their base color, and have to say I was happy with the shade tone that produces.  This will all get the chance to cure before the next round of detail painting and the weathering process begins on the interior. Hope everyone had a Happy Easter!
