Since I started playing war thunder tanks, I've wanted a stug3g of my own. Being as I dont have anywhere to put a full scale one, I resigned myself to making a model of one. So I grabbed the 1/72 version from my local hobby shop. I know its tiny but I wanted an easy back into modeling.
Anyone here have any experience with the 1/72 italeri stug3g?
Pictures tonight.
Haha, late night so heres the pictures.
DonantonWhats a good source for 1/72 tracks for a stug 3G or Pzkpfw 3 as they share the same chasis? Thanks
Ooh. I'm gonna check out the eduard photo etched tracks. I always enjoy getting impaled on razor sharp tiny metal model parts.
Great detail in this tiny kit.
This is a 40 year old kit, many of the more current kits have detail that surpass this. For example, the Revell of Germany StuG III has awesome detail and Part of Poland makes a very comprehensive photo etched set for kit.
Here is the rebuilt gun tube for the ex-Esci Italeri M1 Abrams. I replaced the gun tube with styrene tubing. I added Grandt Line bolts to the side of the mantlet as well as drilled out the GAS and replaced the solid coax port with a piece of dried out styrene rod.
When working with PE tracks, you are basically folding a piece of photo etch about the size of the tiny bandage (the little one that won't wrap around your pinkie) lengthwise.
Here are some more of my 1/72 scale projects.
Monogram (Revell of Germany) StuG IV
Heller VAB
Fujimi Type 90
Hasegawa Jagdpanzer
Revell M998 HMMWV
Airfix LCM and Fujimi M4A1
That's some nice work on the braille. I do think the return-rollers on the StuG are oversized, but solid work on your part. I have no idea how you do PE on stuff that small.
Eric
Progress!
-Josiah
I'm thinking something like this. It's the "Lines" skin from war thunder for the stug3g. That pattern but with lighter colors. This will be to fit in with the simulated wheat field i want to have it driving through on it's base.
That paint scheme should look amazing in a wheat field. I look forward to seeing it on your model! :D
- Mike Brindos "Lost Boy"
Small update AND a question
-armor plates
-rear plate thing
Now my question. I am supposed to put this part, circled in red,
here (see image)
but here's the side of the stug.
Any Suggestions?
---Of course, after this point theres no further views of the left side.
Yes, it is a pair of wire cutters with the mount straps molded on, but you can leave it off.
I'm having a crazy idea here. What if I made this kit with the pieces it comes with, then make another one from a better manufacture and using photo etched parts? I figure I could put then next to each other on the same base as if they wear advancing together. A small pin attached to the bottom would assure theyre placed in the exact place every tme
A quick supergluing of a magnet in the hull and they can be removable to look at the details.
This article breaks down the kit you own (referred to as the Esci kit) along with the excellent Revell of Germany kit and the Dragon kit is very good as well.
http://www.onthewaymodels.com/articles/SBrezinski_Stug3_Revell_Dragon.htm
That little part had that block that the end of the cutters are stuck through. It's a crude attempt at a clip that held it on, or a socket they stuck into. You can cut the handles and the jaws off of the sides of it and glue it on alone, or a scrap of plastic about the same size. Gives the model a little bit of a "lived in" quality.
I know, its micro small.
Use pieces of stretched sprue to fill the gaps/holes and drip a lot of Yamiya extra thin over it. It will melt the bit of sprue into the hole and once it cures overnight you can then sand the piece as you would any other piece of plastic. Just be careful with the tiny parts! :)
rails and stuff
It just too small for my Shrek fingers....but yes, that cammo should look great.
Great job so far! I like that camo pattern you have picked out for it.
UPDATES!!
Mostly more little bits and bobs.
