1/35 Meng Mk. A Whippet British Medium Tank (FINISHED)
    February 2012
Posted by lawdog114 on Tuesday, December 24, 2019 12:26 AM
Hello armor mavens.  Here's my second attempt at something without wings.  WWI Steampunk!  I built a Mk. V tank a few years ago and was quite happy with it. I'm having a go at another Meng tank, this time the Mk. A Whippet.  Research revealed it was fast for a tank of the time, about 8 miles per hour, the equivalent to a man running.  It was apparently meant to replace or supplement calvary.
Going with "Firefly", B Company 6th Battalion in May of 1918.
So I dove right in.  There is no interior on this kit, so it was a matter building it.  I got the body done in a few hours.
I followed the directions and built the sponsons (Not sure if that's what these are called).
Ready for assembly...
Fit was perfect.  Like their Mk. V, the detail is wonderful.
First I covered it with XF-69 NATO Black as primer.  I liked the camo color on the box, a greyish green, so I sought to replicate it.  I didn't want another khaki brown tank, like the MK. V .  I mixed about half XF-13 IJA Green and half XF-19 Sky Grey.
I added some XF-2 White for streaking and fading.  You can see where I was checking the color on the box.  I think I'm close.
I switch to painting the red and white stripes.  I put down AK Interactive worn effects fluid before spraying the white and red.  An old Testors paint brush (dampened) was then used to wear it off.  I was pleased with the effect.
I sprayed it with Alclad Aqua gloss then found that I had pebbling.  I should just stick with the Tamiya clear/Mr.Leveling thinner.  Alot less headaches.  I added all six decals.  I had an issue with the "IX" decals and for some reason the Micro Sol reacted with the Aqua Gloss.  I suspect humidity issues, or lack thereof, in my basement.  I decided to strip the area and paint these in.  I think the red is too dark.  I may do it again but brighter....or I might say good enough. I doubt these were perfect on the real thing.
Time to get going on the tracks, all 86,000 links....
    June 2014
Posted by BrandonK on Tuesday, December 24, 2019 10:51 AM
That looks awesome, Joe. And fast too. Your painting skills are amazing. Can't wait to see this finished.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Tuesday, December 24, 2019 12:56 PM
Thats looking very impressive. Look forward to seing more, not that there seems to be much left to do.
Posted by Gamera on Tuesday, December 24, 2019 2:06 PM
Bringing your aircraft techniques to this worked out great!!! Fantastic job!!
And I wouldn't worry too much about the paint. I don't expect paint back in 1917 was all that great and it was probably applied by some guy with a brush.
    July 2014
Posted by M1GarandFan on Tuesday, December 24, 2019 5:39 PM
Second attempt! Are you kidding me?! It looks fabulous. The paint and weathering look perfect to me.
    February 2016
Posted by German Armour on Tuesday, December 24, 2019 6:49 PM
5Star
2nd attempt? No way looks like you've got it nailed there!
I have the same kit so am watching with interest.
 Never give up, never quit, never stop modelling.Idea
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 12:08 AM
BrandonK
BK
Thanks Brandon
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 12:09 AM
Bish
Thanks Bish
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 12:10 AM
Gamera
Thanks Gamera.  Agreed on the paint.  Probably lead based too!
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 12:12 AM
M1GarandFan
Thanks Garand.  Yep, second attempt at armor.  Won't be my last either.
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 12:13 AM
German Armour
5Star
Thanks GA.  Yep, second one.
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 2:28 AM
The dark red color of "IX" was bugging me, so I went back and re-painted it to match the red on the stripes.  I'm much happier with it now. I also hit the tank with some 600 grit paper to remove the pebbling from the Aqua Gloss then went back with X-22 and Mr. Leveling Thinner.  Smooth like glass now.
Much better, and now the correct thickness as well.  (I eyeballed the last masks).
Almost time for an AK pin wash and streaking.
    April 2015
Posted by Mopar Madness on Wednesday, December 25, 2019 8:21 AM
You definitely matched the color. I can't wait to see year all streaked up.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    February 2012
Posted by lawdog114 on Tuesday, January 7, 2020 1:37 AM
Thanks Mopar....
Done!  Boy this was fun.  I'm starting to enjoy armor and I must say I like these Meng armor kits.  I chose "Firefly" of B Company 6th Battalion in May of 1918, which was one of the kit options. Other than the IX decal hiccup, It was a painless build.  The track links were tedious but went together well, but don't confuse that with staying together.  For some reason some would not stay linked.  My solution was a thin strip of masking tape on the inside (middle)  which held them linked long enough for me to superglue them onto the tank.  I gave them a wash and a drybrush to simulate use, which is the same technique I used on the Mk. V.  I'm happy with them.
On another note, I'm still trying to find the best way to simulate mud. I've watched numerous videos, which involved everything from pastel sludges to white glue mixed with real dirt, but I'm still up in the air on which I want to try.  I have the Tamiya Sherman in the stash which will get some love soon,  I'm going to try mudding that up a bit.
I can't think of anything else.  Here she is.
Posted by Gamera on Tuesday, January 7, 2020 7:49 AM
She looks fantastic!!!
Even with the constant mud on Great War battlefields it'd be a shame to cover up any of your work with it. Personally IMHO she's perfect the way she is... Heart
Posted by keavdog on Tuesday, January 7, 2020 7:54 AM
Wow that turned out great.  Interesting subject as well.
Thanks,
John
    June 2014
Posted by BrandonK on Tuesday, January 7, 2020 9:46 AM
Super nice work, Joe. Just the right amount of grime on her. Realistically these were a mess, but I prefer the look you gave it. It shows your skills superbly.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    July 2014
Posted by M1GarandFan on Tuesday, January 7, 2020 5:24 PM
Ditto with Gamera and BrandonK. Just the right amount of mess without obscuring all the work you put into her. Great result!
    February 2012
Posted by lawdog114 on Wednesday, January 8, 2020 1:03 AM
Gamera
Thanks Gamera.
    February 2012
keavdog
Thanks Keav
    February 2012
Posted by lawdog114 on Wednesday, January 8, 2020 1:04 AM
BrandonK
BK
Thanks Brandon. Indeed they were a mess.
    February 2012
Posted by lawdog114 on Wednesday, January 8, 2020 1:05 AM
M1GarandFan
Thanks M1..
Posted by Bish on Wednesday, January 8, 2020 7:46 AM
Thats a stunning piece of modelling, really well done.
I really like useing pigments mixed in water. Depending on your colour, this works great for dust and mud. If i want a fresh mud look, i use the same mix of celluclay that i use on the base.
But it is tricky getting a realistic look without obscuring a nice paint job. But given the slow speed of these, i imagine the lower portions and running gea4r would be caked in it and not so much higher up.
    March 2012
Posted by mustang1989 on Wednesday, January 8, 2020 7:54 AM
 Forum | Modelers Social Club Forum (proboards.com)
    December 2019
Posted by Niko on Wednesday, January 8, 2020 8:02 AM
That Whippet is a beautiful build, I applaud your work. I'm looking to build that exact kit sometime soon.
"The farther back you look, the farther forward you are likely to see." - Winston Churchill
IN PRODUCTION:
Trumpeter KV-2 1940 1/72
Tamiya Flakpanzer IV Wirbelwind 1/48
    April 2006
Posted by waynec on Wednesday, January 8, 2020 12:18 PM
Very Nice. I have this kit in my Russain Civil War stash of about 15 kits. I have the TAKOM one almost ready to prime. Since i may open the back hatch a but i have to put a quick floor in.  Not sure if this one is gong to be Reds or Whites in the south or British, in the Rostov area in 1919.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    January 2015
Posted by M. Brindos on Wednesday, January 8, 2020 6:39 PM
Beautiful job, Joe. She's a real gem! Love the balance of effects.
- Mike Brindos "Lost Boy"
    February 2012
Posted by lawdog114 on Thursday, January 16, 2020 10:22 PM
Bish
Thanks Bish. I tried that with the spare tracks and didn't like the results. Maybe I had the wrong color. I will continue to experiment.
    February 2012
mustang1989
Thanks Joe..
    February 2012
Posted by lawdog114 on Thursday, January 16, 2020 10:23 PM
Niko
Thanks Niko. You'll love it
