Urbanlamb wrote: |
I've been hearing a bit about wet sanding...why do wet instead of dry, and how do you do a wet sanding?? |
Wet sanding is simply sanding, using water as a lubricant. You can't do this with all sandpapers - some, typically the yellow/buff coloured type, will disintegrate when wet. You need to use the dark grey waterproof type.
When you wet sand, the water acts as a lubricant, preventing the abrasive surface from clogging with sanding dust. This gives a smoother finish, as the waste material doesn't accumulate into large lumps (potentially causing gouges).
