The Lt. wrote: |
...Would you suggest just sanding it? Would that work? I have a TON of 600? |
I would definitely not recommend sanding Lt...that will undoubtedly result in "softening" of the lines of the hood and you'll end up with a noticeably reworked panel (I'm speaking from experience). Doog was putting you on the right path IMHO, with the use of a (paint) stripper.
There are numerous different products you can use depending on whether you painted with acrylics or enamels; when I'm stripping acrylic I use a "floor stripper" designed to strip off acrylic floor polish. When I'm stripping enamel I use Easy-Off oven cleaner (toxic: use with appropriate ventilation and rubber gloves).
Just coat your hood with the stripper and let it sit...go back an hour or so later and scrub the piece with an old toothbrush (or similar soft bristled [i.e. non-damaging] abrasive item) and you should have a "fresh-start" sitting in your hands (or you may have to repeat a second time, especially with enamels). By the time you rinse it off, you've also done a thorough cleaning to ensure your previous contaminent has been removed. Good luck.![Smile [:)]](/emoticons/icon_smile.gif)
Cheers
