Protar Paris-Dakar BMW 1000GS 1/9 scale FINISHED (PICS)
    August 2006
Posted by FoxbaT73 on Tuesday, November 24, 2009 4:22 PM
Hi,
after my last project (Harley Davidson WLA, /forums/894344/ShowPost.aspx ), i finally started on my next motorcycle; the BMW 1000GS wich won the Paris Dakar rally in 1985.
I won this rare kit from Protar on Ebay, it has a metal frame and some other metal parts.
The first thing i did was re-spoke the front wheel with thin brass wire because the original plastic spokes were to thick. I still need to remove some glue residue and it needs to be painted but the wheel is almost finished.
Meanwhile i started on the engine
The parts for one cilinder....
One cilinder mounted on the engine case
Test fit of the engine in the frame
The engine spraypainted
I damaged and scratced the engine guard a little bit
The next thing was to glue the two frame halfs together, sand al the seams and sprayed the frame gloss white.
The frame is highly detailed, even the welds are made
Next thing was to make a VIN code plate, i found a picture of the real VIN code plate from the original Dakar BMW, so i used that to print a decal from 6mm wide.
This is how far i am now, till next update...
Greetzz,
Karel
    May 2009
Posted by Brizio on Tuesday, November 24, 2009 10:09 PM
Looks great!!! Protar made a lot of nice motorbike... ANd their customer service was great!
I build some of theirs Harley.
    August 2006
Posted by FoxbaT73 on Wednesday, November 25, 2009 9:58 AM
I mounted the engine in the frame
    August 2006
Posted by FoxbaT73 on Saturday, November 28, 2009 4:21 AM
Small update; the frame and engine are weathered, now i can continue with building up the bike.
Karel
    April 2007
Posted by JTRACING on Saturday, November 28, 2009 5:48 AM
thats some great looking work!
    May 2006
Posted by Dr. Faust on Sunday, November 29, 2009 2:03 AM
Your work on this bike is top shelf! Protar kits are sweet aren't they?
I did the relacing deal on some dirt bike rims, I used styrene rod. I like your use of brass rod better.
Keep us posted on your progress, will ya'
Thanks.
Just build it (and post pics when youre done)
    August 2006
Posted by FoxbaT73 on Thursday, December 3, 2009 3:46 PM
The carburetors are finished.
Because i have pictures from the original carbs, i could add some extra details.
Greetz,
Karel
    August 2006
Posted by FoxbaT73 on Saturday, December 5, 2009 6:11 AM
Carburator intake manifolds, i put some extra detail in them.
Karel
    May 2009
Posted by Brizio on Saturday, December 5, 2009 9:45 AM
Nice job on the mainfold!
    August 2006
Posted by FoxbaT73 on Sunday, December 6, 2009 6:44 AM
All carburetor parts including the fuel lines and filters are ready.
I scratched the fuel filters, because the filters in the kit were from solid plasic.
Karel
    August 2006
Posted by FoxbaT73 on Sunday, December 6, 2009 2:11 PM
Carbs installed...
Karel
    August 2006
Posted by FoxbaT73 on Tuesday, December 8, 2009 1:35 PM
The oil cooler and lines are ready.
Karel
    October 2003
Posted by modelmaniac1967 on Tuesday, December 8, 2009 2:10 PM
Karel,
 I love the bike and the build you are doing a fantastic job on it. I love the weathering as most people just paint it out of the box and never weather them unless its military, for the weathering did you use just pastels or model pigments?
Darren
Life is an illusion, if you can master the art of illusion you have it made.[View:http://sdfusioninc.blogspot.com/]
    October 2003
Posted by modelmaniac1967 on Tuesday, December 8, 2009 2:39 PM
Karel,
 Actually was looking at all your detail work on this beauty and man you are good!!! Love the work and will be following this one till its finished!!!
    May 2009
Posted by Brizio on Tuesday, December 8, 2009 11:37 PM
Impressive work!!!
    August 2006
Posted by FoxbaT73 on Wednesday, December 9, 2009 4:46 AM
Thanks Darren and Brizio,
this is a rally bike so it MUST be dirty...Big Smile
I use a combination of Tamiya and MIG pastels, and enamels and sometimes a little bit oil paint.
Karel
    August 2006
Posted by FoxbaT73 on Tuesday, December 15, 2009 3:01 PM
Small update; the exhaust and some other parts are finished and mounted.
Karel
    May 2009
Posted by Brizio on Tuesday, December 15, 2009 5:34 PM
Cool job again!!! Do you think to make a diorama with it?
    August 2006
Posted by FoxbaT73 on Friday, December 18, 2009 8:20 AM
Things might change, but for now thats not the plan.
    August 2006
Posted by FoxbaT73 on Friday, December 18, 2009 8:22 AM
Lower legs from the frontfork are ready
Brake caliper
And the legs
Karel
    August 2006
Posted by FoxbaT73 on Thursday, December 24, 2009 7:07 AM
The shocks are ready, i replaced the plastic piston rods with steel rods.
The parts....
And everything assembled.
Karel
    May 2006
Posted by Dr. Faust on Friday, December 25, 2009 10:02 PM
Looking Good Karel!
    August 2006
Posted by FoxbaT73 on Saturday, December 26, 2009 2:51 PM
The swingarm and rear shocks are mounted to the frame
Karel
    January 2008
Posted by Phatsamurai on Wednesday, December 30, 2009 10:21 AM
man what a great build,
what did u use for the dirt, just paint?
I will build anything!
    August 2006
Posted by FoxbaT73 on Wednesday, December 30, 2009 12:59 PM
Thanks, i use mostly mixed pastels from MIG and Tamiya, and sometimes oil paint and enamels.
Karel
    August 2006
Posted by FoxbaT73 on Wednesday, December 30, 2009 1:03 PM
The front end  and the wheels are mounted, and i made the leather toolbag that is mounted on the subframe.
Brake disc
The bike on its wheels
And the leather toolbag
Karel
    August 2006
Posted by FoxbaT73 on Wednesday, January 6, 2010 8:35 AM
Just finished the fuel tank
Karel
    January 2007
Posted by the doog on Saturday, January 9, 2010 11:35 AM
Karel,
As a dedicated offraod rider and racer myself, let me compliment you on the absolute realism of your modeling here. It looks like you're doing a real rebuild on an actual 1:1 bike! AMAZING!!!
The leather seat bag is just outstanding! You are a master of finishing, and I can't compliment ypou highly enough on this tremendous, realistic-looking build!
It's--how do you say it?---"Lekker!:" lol!
    August 2006
Posted by FoxbaT73 on Saturday, January 9, 2010 7:13 PM
Haha thanks Doog for your kind words, Lekker means nice in Dutch Wink
I am a biker too, i own three Suzuki`s, one of them is a DRZ400, the picture below is me playing with my DRZ.
Here are some pics from the saddle.
It was a hard job to glue the foam rubber on the plastic underground, because of al the curves, but with lots of superglue it worked out.
I painted the foam with a couple of layers matt black and carefully sanded it afterwards because the structure of the foam rubber was too rough for the scale.
Karel
Posted by joelster on Sunday, January 10, 2010 8:27 AM
Can I ride it when you are done?
Seriously, that thing looks like it is 1:1 scale. I used to race motocross for a while and the way you have the sand stuck in all of the nooks and crannies on the frame is just perfect.
