starting on this one, using an 2003 revell chevy with JWTBM decals.to make this Pontiac of Jerry Nadeau
thought I'd include the driver in my next nascar .I replaced the kit helmet with a lego one. I thinned the visor and just blacked it out since theres no face detail therenot to worried about the lack of detail on him in the car not much is visible
amazing work bro. will be watching this...
still trying to get a hold of you to discuss your paint process for engines....
On the Bench: 1:25 1969 Z/28 Camaro RS, 1/48 Hasegawa F6F-3 Hellcat
what did you wanna know?
Great job so far!
WOW, James!
"Lack of detail" on the driver?!
Not when you get done with him! Sheesh! That looks outstanding!
How much of those are decals and how much of it did you paint on?
blue and black are paint, rest is decal lol shoelace is stretched sprue
some body work, for the grill i dremeled out a bit from the bottom part then used some stretched sprue to clean up the edges. Not to worried if its perfect looking because the grill decal will give the exact look after.I also thinned down all the edges of the body (wheel openings, side skirts, the intake on the cowl and the spoiler) . i just sprayed on some flat blue to check for any sanding marks and stuff and to get "blue color" in the panel lines
added those spacer things from an '01 monte carlo to the front window.
Great job so far! I'm sure when it is done it would be a great car!
roll cage glued up and painted grey.Body is painted. the paint came out fairly smooth from the airbrush, it still needs to be polished out. I don't plan on using any clear coats on it.
polished up the paint. no clearcoat
I see my bandwidth was exceeded those pics should come back in a day or to. anyway i'll use my other account for now
painted the padding and other stuff that should be blackand added BMF to the crush panels
test fit with the chassis and rollbars and those window brace things fit in perfect the first time!
Looks mighty nice! I shot ya a pm by the way...
Well I trieed but it seems I cant start a convo with you...
DA6righthand Looks mighty nice! I shot ya a pm by the way... Well I trieed but it seems I cant start a convo with you...
sorry I checked in my profile I guess it was turned off by default . it should work now if you send one
painted up the front shocks and fire bottle also stuck on the rear view mirror, I used some mirror sticker on it
seat painted up
