Just a small update.
Gave the body a few more coats of paint before giving it a coat of gloss:
Did some work on the underside:
and noticed that what I thought were ejector pin marks which I duly filled, turned out to be connecting points for one of the under side cover pieces. Should have read the instructions. Oh well, another learning experience
Next I thought I would have a go at decalling the body while I waited for other parts to dry and this is where my troubles began:
Now, I had left the gloss coat to dry for 48 hours and the paint did not look like it does now. However, I decided to try using Micro Set and Micro Sol (never used them before) and while the decals seemed to go on well, when I got to the number plate everything went awry. The decal kept folding up even though it was in place for a good couple of minutes.
My method was put some Micro Set on the model while the decal was in water, slide of decal, place and then brush a small amount of Micro Set over the decal. Give it a couple of minutes and then apply some Micro Sol. Would that be the correct method or have I misunderstood the instructions?
Also, would Micro Set/Sol have caused some of the paint to come away like this? It didn't look this bad before starting and I figured 48 hours should be plenty of time for the gloss coat to dry enough for taking decals, but maybe I am wrong.
Thanks for any advice you may be able to give me.
Dave
