The LAST Revell Futura BATMOBILE Conversion (PICTURE HEAVY)
Posted by gregbale on Wednesday, November 11, 2015 6:29 PM
Okay, so maybe not the LAST, but since the release of the splendid Polar Lights/Round 2 kits of the late George Barris’s iconic ‘66  Batmobile, one has to assume there won’t be too many modelers with a masochism streak big enough to bother.
Frankly, I‘m not one of them, either. I started this project back in 2004, long before Polar Lights was an option. I managed to get the bodywork and paint finished, then had to pack everything away for a change of address, and somehow never managed to get back to it until now. I broke it out and started work again about a month ago.
(Purely coincidentally, Mr. Barris passed away less than a week ago, at the age of 89. As one of the countless fans and enthusiast who have been inspired by his innovative body of work over the years, I can’t help but dedicate this build to his memory. Thanks for the flights of imagination.)
I did the fairly extensive body work before I even owned a camera, so alas I have no “in progress” pics. Modifications included opening up and boxing in the wheel wells, building the fender flares from scratch, and extending the hood “bump” fairing all the way down to the nose. The tail fin fairings had to be “filled in” where they come forward to the cockpit, and of course the scallops had to be added to the trailing edges. Lots of styrene sheet and Testors white putty. And sanding…so much sanding.
Paint was several coats of MM Gloss Black Enamel, sanded and buffed  between. Trim stripes were mainly Micro Scale decal stock, with enamel paint touch-ups. Top gloss coat was multiple applications of Future, heavily buffed.
Here’s the body freshly removed from storage.
It survived in pretty good shape; the only real touch-up needed  was to my home-made “door bat” decals, which had faded to a lovely rose pink. I carefully overpainted them with red enamel, then reapplied a couple coats of Future (the original gloss finish I had used),  and all was good-to-go once more.
For those unfamiliar with the venerable Revell kit (copyright 1956, on the instructions in mine), it has no separate chassis and body pieces as most modern kits do. Instead there’s  a lower body pan, to which everything else, including the multi-part upper body, is attached. With all the body work to be done, there was no way I was going to detail the interior and then build the body around it as the instructions called for. So I measured carefully, then cut a panel out of the bottom that would allow me to insert the finished interior (and fish it into place) after the messy stuff was finished.
INTERIOR
Before I originally started the project, I’d picked up a few aftermarket goodies from an apparently now-defunct website called SID-KIT.com. These included the iconic fire-extinguisher, Bat-phone, rear-deck triple pipes and bat-shaped wheel spinners (all in white metal); the central cockpit pylon and police-style beacon (both in resin); and the little hood-mounted radar antenna (in photoetch). Here’s the “before and after” of the fire extinguisher:
Almost everything else in the interior was scratchbuilt: homing and “Bat-scope” domes, shift and “Emergency Bat-Turn” levers, and assorted buttons and knobs.  Steering wheel is the kit part with the top arc trimmed off to make the yoke style. Home-made “bat-label” decals and some good old-fashioned detail painting add the final touches.
I had some tiny-diameter wire with a neat metallic red color insulation, so I used it as contrast piping in the kit seats.
Here’s the completed cockpit tub, with fabric belts (and Model Car Garage etched buckles), fire extinguisher and Bat-phone in place, and scratchbuilt armrest/door-latch panels added to the cut-out tub sides.
Cockpit tub installed, pylon and canopy sections installed. I did the canopy frames with Bare Metal Foil.
The SID-KIT white metal mortar pipes for the rear deck had profile problems and pretty deep casting seams running down the sides, so I just went ahead and made the pipes from styrene tube stock. Painted with old-school Testors square-bottle silver enamel.
FINAL DETAILS
Wheels and tires were salvaged from Monogram’s old K-Mart “Lake Speed” Nascar kit. I reversed the tires so the molded “Goodyear Eagle” emblems disappeared to the inside. I never got around to picking up the AMT “Fireball 500” kit for the proper Radir wheels, so I cheated and mocked up a set of “close enough” inserts to fit the wheel hubs I had. With the SID-KIT spinners (which are actually a little on the small side) they look okay.
Should have lowered the suspension a bit…but didn’t.
Rear grills cut from the foil cover of a discarded electric razor. Turbine exhaust shroud was made up from strips of styrene stock, super-glued to a band of flexible mylar, then (after painting, of course) wrapped around the exhaust. Drag chutes from the spares box, with added wiring and latches. Rear deck “whip” aerial from stretched sprue. License plate is a home-made decal on pie-plate aluminum.
Here’s the gallery:
Thanks again to Mr. Barris for the neat mods to the original Futura design. For fans of my generation, it will always be the one--and only--BATMOBILE.
Greg
George Lewis:
    August 2007
Posted by DUSTER on Thursday, November 12, 2015 12:00 AM
Great job Greg. You made an icon come alive.
That is real modeling- I can’t do it, but I appreciate it.   Yes
Steve
    August 2008
Posted by tankerbuilder on Thursday, November 12, 2015 10:28 AM
Okay ;
 Since you took the time and effort to do this , I will say it's very well done . Although I cringed at what was done to one of the most beautiful cars ever created , in my mind.
     The fact is I found myself at a loss for words . How do you appreciate a vehicle that was created from another and then  use it to promote oneself ? Yes , Your work is superb . Historically the Barris Brothers created some unique customs .
      Although I harbor no ill will , Mr . Barris ( George ) destroyed my faith in him in a disasterous job interview .  Not only did others find my work beautiful , he passed it off as a fluke and refused further employment . He did set precedent and for that I say may he rest in peace .
 That finally out .You need to do more of this stuff . How about super-detailing an Ala-Kart ?
    January 2007
Posted by the doog on Thursday, November 12, 2015 1:05 PM
I can't say that I've evr seen a finer Batmobile model.
POW! RIght outta the park! Big Smile
Posted by midnightprowler on Thursday, November 12, 2015 6:07 PM
Wow. Hard to tell that from the PL kit, well done.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    June 2010
Posted by OctaneOrange on Friday, November 13, 2015 6:18 PM
it's a nice conversion and really looks the part. I understand why you cut the bottom out, as i did the same, except i cut most of the whole 'chassis' out. hopefully now that we have a barrismobile, some more of the futura kits will be built as futuras!
    June 2003
Posted by allan on Friday, November 13, 2015 11:41 PM
Shes a beauty! You just gotta love that Bat Fire Extinguisher. I wonder where Batman sources that.
No bucks, no Buck Rogers
    April 2014
Posted by Sandbox on Tuesday, November 17, 2015 1:31 PM
Very cool!  I can almost hear Robin saying to Batman, "Atomic batteries to power.  Turbines to speed!" (whatever that meant!)
    March 2012
Posted by mustang1989 on Tuesday, November 17, 2015 9:31 PM
Now that's a good solid build right there! Love the details man!!Yes
 Forum | Modelers Social Club Forum (proboards.com)
    May 2016
Posted by Xena on Saturday, June 11, 2016 8:50 PM
Yes absolutely gorgeous!
    June 2014
Posted by Tanker - Builder on Thursday, July 21, 2016 11:52 AM
Late reply Doog ;
  Yup !
    August 2015
Posted by crown r n7 on Thursday, July 21, 2016 12:57 PM
Awesome job !
 Nick.
fox
    January 2007
Posted by fox on Thursday, July 21, 2016 7:42 PM
Toast Toast Toast
Jim  Captain
 Main WIP:
Posted by gregbale on Thursday, July 21, 2016 11:09 PM
Surprised to see this one still alive. Thanks to all for your comments.
Greg
George Lewis:
