68 Corvette 427
    July 2017
68 Corvette 427
Posted by DeanFrees on Monday, January 15, 2018 1:25 PM
I am tring to get the spark plug order and firing order on the distributor cap so I can do the wires onthe model I have anyone have an idea.
    March 2012
Posted by mustang1989 on Monday, January 15, 2018 1:39 PM
Firing order is 1-8-4-3-6-5-7-2 on the distributor. in a clockwise fashion with the #1 cylinder being at the drivers front cylinder there Dean.
 Forum | Modelers Social Club Forum (proboards.com)
    July 2017
Posted by DeanFrees on Friday, January 19, 2018 1:04 PM
Okay so I put on the exhaust manifolds and there is very little space to put the plug wiring in between them gonna be difficult.
    March 2012
Posted by mustang1989 on Friday, January 19, 2018 1:58 PM
Ya got a picture Dean?
    July 2017
Posted by DeanFrees on Friday, January 19, 2018 2:24 PM
I will have to take one get I get home.
    July 2017
Posted by DeanFrees on Friday, January 19, 2018 5:08 PM
mustang1989
Here it is engineengine 2
    June 2008
Posted by lewbud on Saturday, January 20, 2018 1:21 AM
Dean,
There's not a lot of room on the real car either. Are you doing this as a L-88 or a lesser 427?  The reason I ask is that there are noticeable differences between the them. Most notably on the L-88 there was no distributor or spark plug wire shielding as the L-88 was a radio delete car. If you're building the L-88, the spark plug wires should be brown.  If you're building a lesser 427 (lesser meaning less hp), there would be a chrome plated box around the distrubutor and ignition coil. The spark plug wires would have a braided metal sheath around them.  This was to prevent interference from the ignition bleeding over to the radio.  The engine block should be Chevy Orange and the transmission was simply cast aluminum. I don't remember if the kit has a radio and speakers or not.  If you're building the L-88, you'll have to fashion a radio delete plate and remove the antenna.  If you're not, the cowl induction system will have to be deleted, and a different intake, carb and air cleaner set up used.  I look forward to your build.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    July 2017
Posted by DeanFrees on Saturday, January 20, 2018 10:52 AM
It's the 427 I am doing. I did it red instead of orange. Should I try and drill small holes between the exhaust manifold and run the to the distributor?
    July 2017
Posted by DeanFrees on Sunday, January 21, 2018 11:19 AM
Decided against doing the plug wiring On the engine with the blower and stuff it makes it really difficult.
    June 2008
Posted by lewbud on Monday, January 22, 2018 11:42 AM
Sorry for not responding sooner.  If you're going to display the model with the hood off or open, I would go ahead and wire it up (unless you're entering a box stock category).  Model Car Garage makes some excellent photoetch wire looms that would work perfectly and help keep everything neat and tidy. They also make photoetch linkages and machined aluminum AN fittings, and braided stainless steel line should you decide to go all in and detail the heck out of the engine. As for installing the wires, just drill holes in between the manifold tubes and you'll be fine.  However, since you said you'd decided not to wire it up, just file this away for future reference. As a contest judge, if this is going to contest, make sure all the ejector pin marks sanded off or filled, especially if the hood is displayed open or off the car. I've bounced many good builds in the first round of judging for failure to do this basic step.  I look forward to your build.
    July 2017
Posted by DeanFrees on Monday, January 22, 2018 1:34 PM
It's just for me. I am not entering a contest or anything. I will wire it up on the next model or something lol.
    July 2017
Posted by DeanFrees on Monday, January 22, 2018 6:16 PM
Okay I decided to do the wiring here is a foto of the start of it. engineengine
    July 2017
Posted by DeanFrees on Thursday, January 25, 2018 10:47 AM
Here is the engine so far.
Wiring
 wiringwiring
    June 2008
Posted by lewbud on Friday, January 26, 2018 5:19 AM
Looking good!
