Eaglemoss 1/8 BTTF Delorean
fox
    January 2007
Posted by fox on Monday, March 26, 2018 4:20 PM
I think I'm really going to like watching this come together.
Jim  Captain
 Main WIP:
    February 2015
Posted by Modelerinthemitten on Tuesday, April 3, 2018 1:21 PM
Thanks! It's been a very fun build so far. Making me rethink this "part works" method of model building. Seems to offer some distinct advantages over traditional model kits (no smelly glue or paint!)
    June 2014
Posted by Tanker - Builder on Tuesday, April 10, 2018 3:29 PM
Hi;
 I am glad you are enjoying this . I have a problem with this though .You cannot find , except at ridiculously high prices A Stock De Lorean or Lincoln Futura . Except Revell's old re-release of the Futura .
 I haven't seen a De-Lorean since after the real ones started showing up . Then it was only a Fair representation in Die - Cast .
    February 2015
Posted by Modelerinthemitten on Friday, May 4, 2018 6:45 PM
I have seen this problem with the Delorean for many years. Most models of Deloreans are of the Back to the Future Delorean and it is hard to make the models look like a stock Delorean.
I have seen stock Delorean diecasts in 1/18 scale from AutoArt but they are more expensive than the BTTF version made from the same parts.
There does seem to be more "new tool" model kits being made so there is hope these will one day be available. I had never heard of "part-work" subscription model kits until I found this one so maybe there will be a futura someday.
I also have a small update: I skipped an issue that's early in the run because I wanted to get the chassis going but here's a look at the reactor parts in issue 3
The original plutonium reactor is made up of 3 parts that screw together underneath. On the real time machine this assembly was made from an old Plymouth hubcap and a turbine ring from a military jet engine. The hatch for the plutonium rod was a custom made part as far as I know.
Mr. Fusion is made up of several parts and builds up to a nice looking fusion reactor made from a coffee grinder - from one side atleast. It does have the little red latch but I haven't attached it yet because it's spring loaded and I need tweezers to put that assembly together.
Opens up so you can throw 1/8 scale garbage into it to generate the 1.21 jigawatts of electricity you'll need. The black base is a 1/8 scale mainframe computer harddrive enclosure circa pre1980.
This is the biggest drawback of the screw-only assembly method. 3 big screws on one side hold the coffee grinder halves together. It definitely ruins the ability to display the final cars passenger side. There is a builder that makes stickers to cover them; but honestly if it's really an issue one could easily superglue the parts together without the screws and fill them in. I haven't seen aftermarket Mr. Fusion decals for this *yet* but it'd be fairly easy to fix the screw holes with putty and paint.
For me it wasn't a big deal since I'm going for Delorean time machine v.1. Since the final issue includes a mini plutonium case I'd like to have the original reactor on there. I'll keep Mr. Fusion sitting nearby with a 1/8 can of beer and banana peel since it's still a cool looking bit.
Tags: Delorean
    February 2015
Posted by Modelerinthemitten on Saturday, May 5, 2018 12:22 PM
I've also finished the rear suspension componets which are now assembled to the frame. It's really starting to come together!
    July 2014
Posted by Bakster on Saturday, May 5, 2018 5:14 PM
I didn't know they made a large version of this. Very cool. I will be watching.
Posted by keavdog on Saturday, May 5, 2018 5:22 PM
How fun!  Looks like a really nice kit.  Coming along nicely.
Thanks,
John
    February 2015
Posted by Modelerinthemitten on Monday, May 14, 2018 7:44 PM
Bakster
keavdog
Thanks guys! Yeah, it's pretty big and the detail is right up there as well. Neat example of what diecast injection and 3d laser scanning can produce.
    June 2014
Posted by Tanker - Builder on Sunday, June 3, 2018 5:41 AM
I wondered about this .There were some subscription model kits in the past .many years ago in fact . I don't know how they fared but the one I got was the Constitution . It took a year and a half . But , Historically it was dead on accurate . I gave it away as a gift to a very dear friend .
    February 2015
Posted by Modelerinthemitten on Saturday, June 9, 2018 5:45 PM
That is one lucky friend! I've seen that these companies offer wooden boat kits similar to what you described. I'm not surprised it was very accurate - the big appeal of this style of building is that it spreads the cost and assembly time of a very complex model kit into smaller more manageable amounts.
One thing I like about doing a few subassemblies a month is that when I decided that the engine looked a little too new and clean I could spend a little time with some oil paints I had and add some dirt and grime.
Also gave a coat of color to a few small parts. Anyone who's seen an engine up close knows all the individual components are different colors. A good example of how a little bit of paint can make this kit really start to shine. The hose on the engine parts is actually a rubber tube! I'm interested in seeing how much more detail there will be once the engine assembly is complete.
    February 2015
Posted by Modelerinthemitten on Saturday, June 30, 2018 5:33 PM
I got some Tamiya weathering chalks and added a bit more weathering on the engine and some on the frame.
Definitely helps the suspension areas stand out better. Looks like a little weathering helps this kit really shine!
    May 2016
Posted by CyberGolem on Friday, July 6, 2018 1:45 PM
ANSWER:: It appears this subscription is roughly 130 issues and 2 1/2 years to complete. That'll be around £1,168 or $1542.53 as of July 11th 2018.
What bothers me isn't the price or the time commitment, but the fact that the company doesn't disclose this anywhere. Feels a bit dodgy and with the price something I'll simply pass on. I don't get a sense they're trustworthy and will probably duck outta town the moment something goes south for them leaving their customers hanging with partially finished kits.
Fortunately this build is happening here, so I'll simply live vicariously through it. Too bad too, the scale is absolutely perfect... OMG and the detail!
~~~~~~~~~~~~~~~~~~~~~Original message~~~~~~~~~~~~~~~~~~~~~
This looks fantastic. The weathering you're adding is perfect.
Btw, do you know how long the subscription is for? I can't find any info on when it ends, only that 4 issues are sent per month in perpetuity. This equates to $51.40 plus applicable taxes. Which could get quite painful if this goes on for very long.
Anyway, thanks for posting and I look forward to future updates.
Happy modelling.
    February 2015
Posted by Modelerinthemitten on Saturday, July 21, 2018 3:58 PM
CyberGolem
Happy modelling.
Thank you! It is 130 weeks with monthly deliveries of 4 issues per month. A bit of a commitment and yeah it's not cheap but it is a massive scale, has many metal well painted parts, and they let you pay in installments so you're not putting $1600 on a credit card so for me it's not a bad deal.
I've started making some demo videos showing how I'm adding weathering to this kit. Useful info for any model though.
    February 2015
Posted by Modelerinthemitten on Monday, August 27, 2018 11:22 AM
Sorry it's been so long for an update everyone. The last 30 days have been very stressful but I have been working on the kit a little bit to keep my mind off all the stress.
radiators attached!
The radiator has nicely molded detail and a coat of a lighter colored paint really helps the detail pop-out from the all black parts.
Also threw together another video demonstrating how I added weathering to the new engine parts. Have a look!
    March 2012
Posted by mustang1989 on Tuesday, August 28, 2018 10:25 AM
This is a good lookin' build right here. Will be watching.....
 Forum | Modelers Social Club Forum (proboards.com)
    May 2013
Posted by Greg on Tuesday, August 28, 2018 12:05 PM
I may become a part time apartment/condo dweller, and painting isn't going to be happening.
A die cast kit such as this, subcription or no, might be a great option to keep me sane for one season.
Thanks for the idea!!!! (and for sharing this WIP, is looking very good)
I think you are the first person I've seen weather one of these high dollar, high detail die cast kit engines. Good for you.
    February 2015
Posted by Modelerinthemitten on Tuesday, October 2, 2018 3:21 PM
Greg
It's definitely a new - albeit familar - experience. I do like that I don't have to use glues or paints (I've added some weathering but that's just been brush applied washes so far.) I have a feeling there'll be more weathered engines in the future, EM is gearing up to release a 1/8 Ecto-1 from Ghostbusters. Now that's going to be a HUGH kit!
I worked on editing the time-lapse footage I took of the frame and suspension going together since I'm waiting on the next few batches of parts. Gives you an idea of how big it is and how it goes together:
Full video here:
    July 2014
Posted by Bakster on Tuesday, October 2, 2018 5:10 PM
I love the video. It's a hoot! Very clever and nicely done. I smiled all the way through it.
    March 2012
Posted by mustang1989 on Wednesday, October 3, 2018 11:31 AM
Great progress so far and I liked the video as well. Neat stuff.
    May 2013
Posted by Greg on Wednesday, October 3, 2018 12:52 PM
I agree with Bakster and Joe, neat video!
    July 2014
Posted by Bakster on Wednesday, October 3, 2018 5:32 PM
Greg
I particularly like the part when he flips the wheel assembly up with his finger. That is pure showmanship. I laughed at the simplicty of the video, and the fun of it. Pure joy.
    July 2014
Posted by Bakster on Sunday, November 4, 2018 8:29 PM
Just yesterday I was looking at the website for this model and I found a few videos on it. It is mind boggling the amount of accuracy and detail that they put into this. Things like the taillight lens even has the Deloren stamp molded into it. This model blows me away. It goes to show what manufacturers can do if they invest in them. I'd just be happy to get a well fitting model, which I have yet to run across. Of course, I tend to build older kits from older molds. None the less...for the money that we pay, even for those reruns, we should get better.
Okay, off my soapbox now.
What I am curious about with this kit is what they are using to light up the molding on the sides of the car when the time circuits are engaged. Whatever they are using seems pretty convincing. Amazing engineering went into this. Amazing that they went as far as to create soft seats. Wow!
Thanks for posting your updates, I am following.
    July 2014
Posted by modelcrazy on Sunday, November 4, 2018 8:47 PM
Is this the kit that one purchases a little at a time? If so I saw the advert the other day and made me think Hmm. It looks to be a very detailed kit and alot of fun.
Steve
    July 2014
Posted by Bakster on Sunday, November 4, 2018 8:54 PM
modelcrazy
Steve, yes it is. By the end of the subscription your spend approaches $1800, I think. The OP can confirm. But man, it would be sheer joy to build this. The detail in this is stunning. What fun.
    February 2015
Posted by Modelerinthemitten on Monday, November 5, 2018 4:46 PM
Yup this is the subscription kit. Its a labor of love for diehards but they do good work and it seems less expsenive paying issue by issue Stick out tongue
    February 2015
Posted by Modelerinthemitten on Monday, November 5, 2018 4:50 PM
Injection molding has come a long way in the last few years (or decades.) I'd say about 80% of the parts are diecast injection molded and the parts turn out looking sharp. I've seen a few guys repainting some parts and adding more detail - it is a detailers dream in many ways - but I've been content adding some simple weathering here and there to make the paintjob look a bit more realistic.
And I believe the final model will weigh north of 20 lbs!
