tamiya honda rc211v 2005 movistarcomplete lots of pictures
    June 2015
Posted by jezz on Tuesday, April 8, 2008 11:45 AM
This will be my next build
I have started asembling the main parts and i will sort out the bodywork first i will get some picture up asap also i have stripped the frame of its crome with oven cleaner foam this is the fist time i have done this hope it dont mess up and i will paint it with aluminium paint and clear coat with a semi-gloss finish
i have made up most of the parts here all ready for undercoat once that has been done there is a base coat of silver to lay down the the blue and i will put a light coat of clear over it ready for decals frame has now been stripped of the crome and sprayed up aluminium
here are the decals finished all ready for a clear coat these decals are very tough the had lots of microsol spread over them to set them right but they turned out nice in the end
    May 2006
Posted by Dr. Faust on Tuesday, April 8, 2008 3:04 PM
Nice build jezz! I like how you organize your assembly process. I gotta try that. Thanks for sharing!
Just build it (and post pics when youre done)
    June 2015
Posted by jezz on Thursday, April 10, 2008 7:15 PM
i have finished the c/f effect i have given them a coat of tamiya smoke the i used future(havent used this before)lots of layers the effect has turned out nice
    June 2015
Posted by jezz on Saturday, April 12, 2008 6:30 AM
here are the pictures so far
    December 2006
Posted by marioc on Monday, April 14, 2008 6:54 PM
Oustanding!!!
Mario Covalski Editor http://www.modelersite.com
    June 2015
Posted by jezz on Sunday, April 20, 2008 8:37 AM
These are the final shots of it with faring of and on before i box it up and send to the customer
hope you liked this build as much as i did sorry for all the pictures only as i am sending this of for a customer i want lots of photos to keep any comments are welcomed on this one good or bad
well its of to the too do pile and decide what to start next
    January 2007
Posted by the doog on Sunday, April 20, 2008 9:19 AM
WOw, man--that's beautiful!---looks just like the photo! Thumbs Up [tup]Make a Toast [#toast]
    February 2007
Posted by kans0002 on Sunday, April 20, 2008 5:07 PM
Hey Jezz - any chance you could describe the method used to paint the chain?Whistling [:-^]  It looks great, and I can not get mine to ever look that good.
Thanks.
    June 2015
Posted by jezz on Sunday, April 20, 2008 6:00 PM
Thanks.
it is done very simple first prime the whole thing then paint both sprokets in this case gun metal then paint the chain matt black
once dry i then drybrush a little with flat aluminium or silver then give the whole thing a wash with a mix of burnt umber and black water paint. then when dry use a damp soft cloth to wipe off the paint leaving the water paint in the recessed details then with a steady hand and a fine brush paint the gold links
hope this helps you
    February 2007
Posted by kans0002 on Sunday, April 20, 2008 9:49 PM
thanks!
