Spocks Brain Imorg remote
    March 2010
Posted by mach71 on Tuesday, April 28, 2020 7:11 PM
This is a simple 3D printed kit that I've had for about 6 months.
I ended up using just the wrist band and the controler base. The kit suplied parts were flat with no detail.
The rectangle is plastruct filled with aves. The red/yellow buttons are trimed down night light lenses, and the 2 gold domes are 12mm googly eyes.
It was filled using XCT-3D epoxy, primed and painted metalic black, then a light coat of gold was applied. I then buffed with steelwoll.
The Googly eyes are just tacked on, I might replace them and I'm looking for some cloth to line the band. I have some velcro somewhere and I think the "soft" side would work well.
    October 2004
Posted by ikar01 on Wednesday, April 29, 2020 4:02 AM
Good job on this little known prop, it's not one that I would have thought of. How long did it take to put together?
"Brain and brain, what is brain?"
Posted by gregbale on Wednesday, April 29, 2020 6:54 AM
Beautiful work, impressive project.
And something of a very timely tribute...since the lovely Marj Dusay just passed in January of this year, aet. 83.
Greg
George Lewis:
    July 2014
Posted by modelcrazy on Wednesday, April 29, 2020 7:20 AM
You always come up with the most intresting Star Trek TOS props Mach. I love it.
Steve
    March 2010
Posted by mach71 on Wednesday, April 29, 2020 10:05 AM
ikar01
"Brain and barin, what is brain?"
Thanks! I worked on it on and off for a few months. The print resolution was really bad on this. I tried sanding, no luck. Then filling with heavy duty scratch filling auto primer, No luck. Finally I resorted to XTC-3D epoxy. That works well.
Once I got a smooth finish I put down Tamiya primer then a coat of metalic black. I covered that with a light coat of gold then I buffed with Steelwool.
It sat like that until I figured out the buttons. A member on a trek board clued me in on the light lenses.
Once I figured stuff out it went quick. Maybe 3 days.
    March 2010
Posted by mach71 on Wednesday, April 29, 2020 10:06 AM
gregbale
I saw that, It kind of motivated me to start up again.
    March 2010
Posted by mach71 on Wednesday, April 29, 2020 10:08 AM
modelcrazy
Wow! Thanks! When I find something TOS and think it would look nice in my prop collection I build it.
    May 2013
Posted by Greg on Wednesday, April 29, 2020 11:19 AM
You read my mind. I was wishing to see some in process pics, scrolled down and voila.
Cool project, well done. Yes
    March 2010
Posted by mach71 on Wednesday, April 29, 2020 11:27 AM
Thanks!
This is a screencap of the prop in the show.
I was unsure if the blackish highlights were from the video compression of the actual prop
so I kind of middle of the roaded it.
    July 2014
Posted by Bakster on Wednesday, April 29, 2020 11:30 AM
Nice work sir.
Posted by Gamera on Wednesday, April 29, 2020 11:38 AM
Oh wow, very cool Mach71! The metallic look is perfect!
Now I hope that Mrs. Mach71 doesn't decide to use it on you!
    March 2010
Posted by mach71 on Wednesday, April 29, 2020 12:42 PM
Thanks guys!
Gamera, imorg are the givers of pain anf delight!
    March 2010
Posted by mach71 on Thursday, April 30, 2020 4:40 PM
It was pointed out on another forum that the bottom button should be smaller and silver.
Fixed it!
Posted by CapnMac82 on Thursday, April 30, 2020 7:57 PM
Reading the title of this one, I was actuall expecting a repurpose of one of the V'ger kits into th econtrol box for Spock's brain (aproximating what they did on the show).
With strip LED in clear tubing, naturally.
    March 2010
Posted by mach71 on Thursday, April 30, 2020 8:16 PM
CapnMac82
An interesting idea.....
    March 2010
Posted by mach71 on Tuesday, May 5, 2020 2:38 PM
Just a quick update:
I stuck some soft velcro on the inside of the band as padding.
Ok, this is done now!
    January 2005
Posted by Watchmann on Tuesday, May 5, 2020 6:22 PM
Looks great!
I like your Comlock, too.
    January 2015
Posted by PFJN on Tuesday, May 5, 2020 6:55 PM
CoolHave you tested it out to see if it actually works Stick out tongue
1st Group BuildSP
Posted by Gamera on Thursday, May 7, 2020 8:41 AM
That looks fantastic!!!
    March 2010
Posted by mach71 on Thursday, May 7, 2020 2:06 PM
Thanks everyone!
The Commlock is an old resin kit. It took a lot of work but looks good now.
I have a Century Castings Commlock/Stungun set with metal parts and A Century Castings The Invaders season 2 vaporizor gun. His kits are very high quality and I expect a nicer build.
