Tamiya Big-E - USS Enterprise 1/350
    September 2010
Posted by A.M.Jorge on Friday, January 6, 2012 7:49 PM
Hi guys. No news yet. On vocation with family.
See you after january 18, 2012.
    September 2010
Posted by A.M.Jorge on Monday, January 23, 2012 12:10 PM
Dear friends,
Let us return to the assembly.
I had to solve some "technical problems" with the airbrush hose today, but there was still time to mask a little bit more of the flight deck catwalk.
And speaking of flight deck, my black NATO paint should have been confiscated for being sent by air. So soon, I will create a "Jorge Gray" to paint the flight deck. Stand by.
Before ...
Later ...
    September 2005
Posted by warshipguy on Monday, January 23, 2012 7:16 PM
I am most impressed with your patience in masking and your obvious attention to detail!  You are building a most impressive model.
Bill
Gar
    January 2012
Posted by Gar on Tuesday, January 24, 2012 7:25 PM
Hi Jorge!
But you use xf-66 tamiya light grey?
    September 2010
Posted by A.M.Jorge on Wednesday, January 25, 2012 4:29 PM
Today I masked and painted the catwalk. I have not found a better way to do this, but even that was fun.
Final result:
    September 2010
Posted by A.M.Jorge on Wednesday, January 25, 2012 4:53 PM
Next chapter: flight deck.
It's the foundation of my home town, holyday here. So let's do somethink funny: mask the contour of the flight deck, being careful to keep a fine line color of the hull, as the photos of my research.
Ah yes, the drama of color is history. I used the "Jorge Gray", two parts Dark Grey XF24 + one part of Flat Black XF-1. My impression was great after the paint dries, it seems that was very similar to the NATO Black.
Masking ...
A bit of alchemy to create a flight deck grey.
Final Result:
Gar
    January 2012
Posted by Gar on Wednesday, January 25, 2012 6:12 PM
The result is excellent congratulations
In summary you use:
For bottom of the ship = x-7 red
For the lateral walls = ? (xf-66 light grey)?
For the flight deck = xf-24 + xf1 (Dark Grey/Flat Black)
Thanks!
    September 2010
Posted by A.M.Jorge on Thursday, January 26, 2012 6:49 AM
Hi, I used:
Hull color - XF - 19 Sky Grey
flight deck color - NATO Grey
catapult track color - a mix of flight declina color + X - 10 Gun Metal
all other horizontal surfaces - XF - 24 Dark Grey
waterline - XF - 1 Flat Black
under hull - XF - 7 Flat Red.
    September 2010
Posted by A.M.Jorge on Friday, January 27, 2012 6:06 AM
Flight deck, chapter two: masking the landing marks. Despite being one of the most rewarding task when the mask is removed, put the tape in place with some precision takes a long time.
Starting a new mask ...
Tape never seems to be sufficiently accurate. I think using decals could be a good idea.
Two hours later ...
    November 2006
Posted by dupes on Friday, January 27, 2012 7:31 AM
Ooooh, wish I had seen this from the start...following along now!
GREAT looking build. YesBig Smile
    March 2004
Posted by Mikeym_us on Saturday, January 28, 2012 6:50 PM
Ok now mask the areas that you are not painting so that you prevent overspray from ruining your flightdeck like what happened last time. Just use paper towels taped down with tamiya tape.
A.M.Jorge
http://farm8.staticflickr.com/7141/6770324177_acf4c2e31d_z.jpg
http://farm8.staticflickr.com/7174/6770324263_0747ecca31_z.jpg
Two hours later ...
http://farm8.staticflickr.com/7157/6770324339_019329b92f_z.jpg
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    September 2010
Posted by A.M.Jorge on Saturday, January 28, 2012 7:01 PM
For sure !!!
    September 2010
Posted by A.M.Jorge on Saturday, January 28, 2012 7:09 PM
Recalling flight deck details:
Posted by Tojo72 on Sunday, January 29, 2012 5:51 AM
Lots of patience required,looking good
    September 2010
Posted by A.M.Jorge on Tuesday, January 31, 2012 1:18 PM
Today I painted the flight deck. Because it's white, once again the layer of paint was a little thick, requiring a wear with filter paper. Overall, it's also needed some finishing touches.
Masking to avoid the spray:
Generous coat of white paint:
Masking for painting of the yellow bands:
Busted out the removal of the mask
    March 2004
Posted by Mikeym_us on Tuesday, January 31, 2012 4:42 PM
Looks way better now that you masked the rest of the flight deck and kept that pesky white paint from spoiling such a good deck. Though this would have been better done before attaching the flight deck to the hull so that you wouldn't have had to constantly fix the arresting wire.
    September 2010
Posted by A.M.Jorge on Monday, February 13, 2012 6:00 AM
Flight deck, the next step: dirty!
With a  filter paper, which acts like sandpaper, rubbed very carefully against the flight deck. The result was an appearance of anything used, worn and dirty. Smeared all tracks taking any aspects of "new car".
Also painted the tracks of catapults, mixing metallic paint with the color of flight deck. The result was an effect that is perceived only when it hits the light and gives a bit of reflection. Otherwise do not realize that the tracks are there painted.
Using filter paper wears away the paint from the deck.
Worn and dirty. Note some blots to retouch.
First, masking catapults tracks.
The tracks are only visible if there is a light reflexion.
    September 2010
Posted by A.M.Jorge on Friday, February 17, 2012 7:25 AM
More flight deck. Next step: number and one more line. The first is a little complex and the second demands attention.
    March 2004
Posted by Mikeym_us on Friday, February 17, 2012 3:57 PM
now Jorge your mistake last time was going heavy with the paint. what you need to do is mask the area for the 65 and the line so that you don't overspray again and use light coats to get the desired effect.
A.M.Jorge
http://farm8.staticflickr.com/7176/6891227653_f89d90b8a0_z.jpg
http://farm8.staticflickr.com/7187/6891227845_9817f385db_z.jpg
http://farm8.staticflickr.com/7209/6891227743_8fa3910403_z.jpg
    November 2006
Posted by dupes on Saturday, February 18, 2012 2:26 PM
Good stuff!
    September 2010
Posted by A.M.Jorge on Monday, February 27, 2012 10:49 AM
One more step on flight deck.
Masking to avoid the "snow spray".
A generous thick white paint
Result befere retouch.
    March 2006
Posted by TD4438 on Tuesday, February 28, 2012 5:26 AM
I could be wrong,but that does not look like fun.
    August 2004
Posted by four-star on Tuesday, February 28, 2012 6:39 AM
TD4438
I always think that aircraft carriers have a high effort to impact ratio - you have to put in a huge amount of effort to make them look good.  But when people do, they can be spectacular looking models with huge amounts of detail.
    September 2010
Posted by A.M.Jorge on Thursday, March 8, 2012 6:46 AM
In this next step I make some corrections on some points that have blurred and other glitches. After that, I apply the gloss varnish - would be better to paint with gloss paint - to prepare the decals application.
Improving painting using coffe filter.
Retouching ...
"Gloss bath" using Jonhson's Future floor polish.
Posted by Tojo72 on Thursday, March 8, 2012 11:36 AM
really enjoying this one Yes
    September 2005
Posted by warshipguy on Thursday, March 8, 2012 11:57 AM
Jorge,
What do you do with the coffee filter?
Bill
    September 2010
Posted by A.M.Jorge on Friday, March 9, 2012 7:53 AM
I gently sand  using it.
    March 2009
Posted by surfsup on Friday, March 9, 2012 5:15 PM
I really enjoy what you have done so far. Will keep watching with great interest.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    September 2010
Posted by A.M.Jorge on Saturday, March 17, 2012 12:07 PM
Now the fun really begins. Time to apply some decals on the flight deck.
First, however, the checklist: decals shett, towel paper, tweezers, decal softener, a brush to apply the softener and position decals, a container with water for decals and s smooth surface in the model, made ​​with gloss paint or a gloss cover.
The original decal with yellow and white markings and the GMM with red and yellow, just like the aircraft carrier.
First I cut, then I put it in the water.
After I applied a bit of decal softener in the brush and applied on the surface. Put the decal on the surface arranged in position with the brush itself.
The GMM's decals are easier to handle compared to the original Tamyia, for me.
Found that these bands would be a problem, but with the marking of the deck was very fast and easy to apply. And they were very well aligned. From now on, between painting and applying decals, much easier, faster and has better results apply the decals.
The yellow line of the original Tamiya decals were very difficult to put on the catapult and even comes with a wrong dimensions. End result of this first step:
    September 2010
Posted by A.M.Jorge on Saturday, March 17, 2012 3:10 PM
Flight Deck, more decals.
Deck elevators stripes. This time I have to cut one by one.
Some results:
