Tamiya Big-E - USS Enterprise 1/350
    September 2005
Posted by warshipguy on Friday, June 3, 2011 7:08 AM
Thanks guys!  I appreciate your responses to my question!
Bill
    September 2010
Posted by A.M.Jorge on Friday, June 10, 2011 1:12 PM
Hi folks.
I will be on vocation soon, so I think I won't post anything before 15 july.
Regards.
    June 2011
Posted by pjratpatrol on Saturday, June 18, 2011 11:17 PM
Hi
Its Looking good.
I am currently attempting the same project Im trying the scratchbuilt hanger deck and with LED lighting, I  have the WE PE and will use Trumpeter Aircraft.
Good luck and I will be watching closely
Cheers
    June 2004
Posted by knoxb on Monday, June 20, 2011 4:38 PM
How's he going to paint the flightdeck with the fishing line/arresting wire in place already?
So what was decided about the grated elevators?...PE set ok or not?  what about putting sheet plastic under the PE grating? or just glueing the PE over the kit part?
    September 2010
Posted by A.M.Jorge on Monday, June 20, 2011 5:35 PM
knoxb
Hi,
I'm no sure, but I'm thinking in using a plastic sheet under the PE part.
Paint flight deck will be easy, as the arrest line does not exists.
But I only will "work" again in july 15 or later.
Thanks and regards,
    September 2010
Posted by A.M.Jorge on Monday, June 20, 2011 5:38 PM
pjratpatrol
Hi
Its Looking good.
Cheers
Hi, thanks.
Yes, scratchbuilt hanger deck will make difference. I saw a lot of them, very very detailed, very very nice. Please, post some pics when you done !
Cheers
    September 2010
Posted by A.M.Jorge on Monday, July 11, 2011 11:46 AM
Hi, I'm back.
    September 2005
Posted by warshipguy on Monday, July 11, 2011 4:25 PM
I just received a copy of Detail and Scale USS Enterprise (CVAN-65) off of ebay.  It seems that A.M. Jorge was correct to do the elevators the way he did.  Photos clearly show that one can look directly through the grated elevators to the sea, and that there was no underlaying solid platform under the gratings, at least until the 1990 refit.  The book stops at that point.
Bill Morrison
    March 2004
Posted by subfixer on Monday, July 11, 2011 6:45 PM
Senor Jorge is doing a later version, if I am not mistaken. Look at this thread a little closer, we had a long discussion about this and have posted pictures showing both versions.
I'm from the government and I'm here to help.
    September 2005
Posted by warshipguy on Monday, July 11, 2011 8:20 PM
Subfixer,
Since our earlier discussion, several people commented that there must have been a solid sheet under the grating.  None of the links demonstrated anything conclusively either way.  There have been comments about placing a solid sheet under the GMM PE elevator pieces. There are very conclusive photos of the grating in the Detail and Scale book in which there is nothing except the supporting structure under the grated surface of the elevators, at least until the 1990 refit, which the book does not cover.  My comment was intended to clarify this point.
Bill
    March 2004
Posted by subfixer on Monday, July 11, 2011 10:35 PM
I gotcha, Bill. Please pardon me.
    September 2005
Posted by warshipguy on Tuesday, July 12, 2011 7:21 AM
No problem!
Bill
    September 2010
Posted by A.M.Jorge on Tuesday, July 12, 2011 10:25 AM
Hi, in the D&S, despite the pics are not conclusive, the text clear says that the sea could be seen through the grates. It appears that there is no doubt about it. I think that after paint, this effect will be reduced.
Thank you guys to find the right answer.
I 'm building a 1982/83 cruise model.
So, the PE part will be glued over the support, as I already done.
    September 2010
Posted by A.M.Jorge on Wednesday, July 13, 2011 7:41 AM
Elevator number two.
The only difficulty of making these lifts two to four is to remove the plastic surface, taking advantage of the whole structure of the original part of the elevator. Just take a drill 1 mm, 1.5 mm or 2 mm and make several holes, removing the most part. Finally, file up to leave everything to the right thickness and smooth.
So, just paste the part in PE over the structure of the original piece. Then glue the support lattice underneath. Finally, we glue the elevator guide is snapped to the track.
Easy, easy ... but a little slow.
The original elevator part.
The piece with the perimeter of holes
The original piece with the base removed
The three pieces that will form the elevator
The part in PE glued to the original base
Now the complete set with the lattice and the guide
Top view
At the place
Elevators one and two
    September 2005
Posted by warshipguy on Wednesday, July 13, 2011 8:34 PM
Beautiful job!
Bill
    September 2010
Posted by A.M.Jorge on Monday, July 18, 2011 8:34 AM
Elevators 3 and 4.
To make these two elevators, just follow the same steps from the elevator 2. First, make a perimeter of holes and remove the central part of the original piece. Next, filing and leave the edges smooth. Then glue the part in PE. Finally, glue the base lattice and the lift tab.
The two pieces that will be modified
The perimeter of holes, in order to remove the central part
The original pieces with the center removed
The original pieces completed and ready for use
The four parts that make up the whole elevator set
The two already mounted elevadortes
At the place
The four elevators at the place
Posted by Tojo72 on Monday, July 18, 2011 8:57 AM
making some nice progress,Jorge
    September 2010
Posted by A.M.Jorge on Tuesday, July 19, 2011 8:12 AM
Dear friends, today we the Achilles' heel of this model: the joint of the flight deck. As the assembly and bonding were reasonably accurate, we should not have major problems. Just nearby marks are off, but they are only guides for painting. I put tapes and filled with putty. Once cured, I removed the tapes and put them on the side not used, a distance slightly greater. To set the level, and the joint, had to use a 240 grit sandpaper. I used 600 sandpaper and then 1000, just to see through the reflection of light, it was all right.
After the putty cure, took the tapes
" style="background-color:#fff;">
We use the unused side of the tape
We use a coarse sandpaper to hit some bumps
We use 600 sandpaper to give the basis for painting
" style="background-color:#fff;">" style="background-color:#fff;">
During the process of sanding, I busted one of the arrest wire
And I had to stretch and paste in the hole
Final result
    July 2011
Posted by Gus97 on Tuesday, July 19, 2011 7:21 PM
1) The Bow Ramps weren't just for F-4's, they were used for other planes of the same period also. They were actively used until '99-'00 when we still used TA-4's for trainers.
2) The Big E DID in fact have slotted EL's, they changed the design and made them solid in the yard period after our '98-'99 Cruise due to safety in rough seas. Long story short, the last straw was we were in rough seas, at night, and had to make an EL run with two fully loaded birds tied down to EL 3. Me and four others ended up holding on to the main mounts with all we had cause a wave hit and came right up through the slots in the EL with enough force that it lifted both tied down birds off the EL 4 inches, with us on them. We could have lost both birds along with myself and the four others because of it.
    March 2004
Posted by subfixer on Tuesday, July 19, 2011 9:24 PM
And thus, the mystery of why they were changed is resolved. I wonder how often in her history this happened.
    July 2011
Posted by Gus97 on Tuesday, July 19, 2011 10:18 PM
Probably quite a few times whenever you had a Handler that wasn't too bright, luckily we had a good Chain of Command on board at the time and a good NNSY crew to update the EL's for us.
    March 2004
Posted by subfixer on Wednesday, July 20, 2011 3:23 AM
Gus97
NNSY as in Newport News Shipbuilding and Drydock Company (NNSD) or Norfolk Naval Shipyard (NNSY)?
    April 2011
Posted by COChef on Friday, July 22, 2011 2:58 PM
Here are almost all the decals you need to do the Big E's hanger deck it's a pdf file its been uploaded to megafile just download it for free then all you need to do is print them or decal paper.
Here is the link
http://www.megaupload.com/?d=880NJ43U
David
    June 2011
Posted by pjratpatrol on Sunday, July 24, 2011 1:15 AM
Thanks very much for that link David. I was wondering how to detail the one I am attempting That will really help
Cheers
Peter
    September 2010
Posted by A.M.Jorge on Monday, July 25, 2011 8:23 AM
Good morning.
Continuing with the assembly, now glued a series of platforms and small antennas supports that will receive some minor details. Also I cerrected and glued the JBD (jet blaster deflector), the jet deflector panels that are at the beginning of the track of catapults. Here I had to make two small corrections in JDBs one and three: they have, in fact, six segments and not three as has been molded in the kit.
Supports and platforms that will be assembled
At the place
Three deck supports
JBD number one, with only three sections
Corrected for six sections
JBD number three, also with three sections instead of six
Corrected
Catapults four and three
Catapults two and one
Barricade triangular support
    September 2010
Posted by A.M.Jorge on Monday, July 25, 2011 8:25 AM
Thanks David.
    September 2005
Posted by warshipguy on Monday, July 25, 2011 3:35 PM
Thanks, David!  I have added that link to my favorites.
Bill
    September 2010
Posted by A.M.Jorge on Wednesday, July 27, 2011 8:48 AM
Good morning.
Today I assembled smaller parts. I have a serious problem here at home, some pieces are already assembled being torn by the beast of the cleaner. So I'll leave those details to glue as late as possible. I also began to assembly the propulsion system.
Two pieces that form the side radar
Assembled
The parts that compose the automatic landing system
The assembled system
The first axis of the four, with the support
Assembled and at the place, after an intense burr cleaning session
The four axes, and brackets in place, after much tuning and cleaning of burrs
From another angle
    December 2008
Posted by psstoff995's lbro on Thursday, July 28, 2011 10:18 PM
Awesome work! You're doing a great job on this one, can't wait to see it done! Yes
-Will young modeler Test fit master
    September 2005
Posted by warshipguy on Friday, July 29, 2011 1:42 PM
Once again, you are doing a beautiful job!  I will admit to being a little surprised that you are not substituting brass rods for the propellor shafts, but it is a minor issue. Keep up the terrific work!
Bill
