Tamiya Big-E - USS Enterprise 1/350
    September 2010
Posted by A.M.Jorge on Monday, March 28, 2011 9:38 AM
Dear friends, I'm continuing to the bow assembly. The pieces come with safety nets, so I must remove them (the nets) in order to glue the PE later. The top piece of the parts fit very well with the low. Note that each part is different, designed to be attached to each specific track of each catapult. As I sanded a lot this part of the bow, the fit between the pieces and the deck was very poor, with a failure quite reasonable. This is an area that will be show, so the finishing has to be good. Another problem is that the flight deck is mostly in high relief. I'm thinking of scratching the raised deck lines and so I will could sand to get a better finish.
I also do some more simple joints of hull. There's no secret, fill the gap with super glue and sand.
Genuine Parts Kit
Assembled and without the safety nets
Glued on the flight deck, watch the size of the gaps
Super glue  to fill the gaps between ship's hull and small platforms
Two more
Sanding and filling again
Sanding the other two
Filling the big one
Sanding the two that were filled again
Posted by Tojo72 on Monday, March 28, 2011 3:40 PM
looking good,it seems all your hard work is starting to come together now.
    September 2010
Posted by A.M.Jorge on Tuesday, March 29, 2011 7:13 AM
I continued to fill the gaps of the joints of some parts, now, mainly, the front ends of catapults. We are nearing the end of this novel. But already I foresee that  these catapults will give me some work to leave this with good aspect. Also spent much of my time doing the support of another flight deck elevator. It takes time, but even that is not so tiring, gets to be fun.
Once filled, sanded joining the larger platform.
More super glue to fill the joint of the front ends of catapults.
Oh yeah, have not given up the last recessed door.
We will finish a new elevator base, first we drill
From the rear.
Half an hour later ...
An hour later ...  only two more ...
    September 2010
Posted by A.M.Jorge on Thursday, April 14, 2011 7:21 AM
Dear friends,
After two weeks, we're here again.
Today I completed pieces that have been delayed by my distraction. I painted a piece that was forgotten in the tree; I painted that piece that I had assembled in the wrong way, that become very good by the way; I took the piece that closes the rear deck off and repainted it, a good job of a good dual-action airbrush; and finally I conclued that the door of the hangar will have to be redone, because my part was very ugly.
Painting parts
The part of the hangar door that I created is very ugly (below left)
The rear part of the platform that I took off just before repainting with the airbrush to paste again
In the picture may not give notice, but was much better than before
More glue to fill the joint
Starting from scratch
The last chance to get well
A bit of putty and will be good
    September 2010
Posted by A.M.Jorge on Monday, April 25, 2011 3:45 PM
Continuing our assembly, without any big news, I need to use a little more putty in the receased elevator door piece and, while the putty cures, I used my time to prepare one more elevaotr base. It is the third of four. It takes a reasonable time, about 2.5 hours per piece. But it will be very good.
A bit of putty to be very smooth, then we will complete.
Meanwhile, let us take over and do an elevator.
Even after almost an hour, the progress seems small.
Once cured and sanded our door will be good
    January 2007
Posted by John Lyle on Monday, April 25, 2011 5:28 PM
Anybody tried to convert one of these suckers to R/C? To me a hull that size just screams "PUT A MOTOR IN ME"
Can't help it I'm an R/C nut.Toast
Winters may be cold in Canada but at least there are no mosquitoes or blackflies
    January 2007
Posted by Pavlvs on Monday, April 25, 2011 6:51 PM
You read my mind!!!  I think ballasting that beast will be a challenge to keep her balanced port to starboard unless a kind of weighted keel that may be removable might be fitted but that is child's play compared to getting her to look authentic below the waterline and be under power at the same time.  It would definitely be worth a try!Captain
Deus in minutiae est. Fr. Pavlvs
On the Bench: 1:200 Titanic; 1:16 CSA Parrott rifle and Limber
On Deck: 1/200 Arizona.
Recently Completed: 1/72 Gato (as USS Silversides)
    September 2010
Posted by A.M.Jorge on Wednesday, May 4, 2011 9:35 AM
Hi guys. Yes, I saw some Big E conersion projects. You can find a lot of them at Google.
http://www.rcgroups.com/forums/showthread.php?t=593475
Dear friends, I finally managed to finish the elevator's door that comes pre-shaped in hull. The hard part was cutting the 3mm thickness of the hull. The knife could not cut less than 1 mm distance between one and another because the thickness. Conclusion, I began to cut laterally with a 0.5 mm drill, which has broken. I put a thicker drill, 1mm, and finished the job. Then it was sanded with patience and care, and soon the hole was open.
I finished making the "box" recessed door. It was good, but I had to dismount and adjust to the hole.
The most important is that the final result was good.
Drawing the box pieces of the door
Already cutted
The "box " assembled
The marathon begins drilling the 3mm hull
After about 15 minutes, just finished to drill the holes
The rear view
The knife did not work with this 3mm thickness, so I use the 0.5 mm drilling laterelly until it has broken. Put a 1mm new one and finished the job
Finally I did the main hole
Once sanded, fitted and glued, the door was good looking
    March 2004
Posted by subfixer on Thursday, May 5, 2011 12:14 AM
A.M.Jorge
http://i.min.us/imp5r6.JPG
I am interested in whether you are planning to drill out the portholes that the little disks (the represent the armored porthole covers) seem to be covering. These covers are/were rarely ever closed except in very heavy seas (and even then, closing them is rare). There are small viewing slits cut into them to enable to used for such when closed and are probably not worth trying to duplicate at this scale, and pull handles to facilitate lifting them up to close them. This portion of the ship is known as SECONN, or Secondary Conning Station. It is a fully equipped navigation bridge as on the island structure above the flight deck. This station is manned during General Quarters and has a full navigation team. The ship's Executive Officer, XO, has this space as his battle station. During normal working hours, it is used by the Navigation Department's Quartermasters to correct charts and to goof off in. It is pretty much isolated and a quiet place to go.
Here is a preety good shot of Enterprise's bow portholes as they are normally configured:
File:USS Enterprise (CVN-65) high speed bow view.jpg
I'm from the government and I'm here to help.
    September 2010
Posted by A.M.Jorge on Thursday, May 5, 2011 7:02 AM
Thank you.
    September 2010
Posted by A.M.Jorge on Thursday, May 5, 2011 2:52 PM
Today, just another elevator support.
Forty minutes later ...
Now, one more only.
    September 2010
Posted by A.M.Jorge on Friday, May 13, 2011 8:04 AM
Hi folks.
Wow !!!
A "must see" decal artwork:
http://public.fotki.com/Obironkenobi/uss-enterprise-cvn65/viewcomments.html
    March 2004
Posted by subfixer on Friday, May 13, 2011 10:42 PM
I'm betting that you won't be using all of those aircraft decals as you seem to be a sane person.
    September 2010
Posted by A.M.Jorge on Wednesday, May 18, 2011 8:18 AM
Stardate 18052011.
The USS Enterprise project continues ...
Today I finished the last support of the deck elevators. I believe that repetitive work is behind us and we will make progress and see assembly to evolve.
The last of four ...
An hour and a half later ...
Finally we have the four supports
The four lifts in PE with their bases
It'll be good!
    September 2010
Posted by A.M.Jorge on Monday, May 23, 2011 9:21 AM
After finishing the supports of the elevators, it's time to work on some details of the deck and hull in the bow. I decided to fold and glue the staircase in PE. Never needed to bend PE before. Already noticied that they crumple easily. But you can bring to the position. I used the basis of styrene and details of stairs in PE. It was good. I took a deal to give those two joints of "teeth" in front.
Look at the ladder in PE there
The little piece in place with the base of the original piece
From another angle
The original part
The original piece with the base cutted
The stairs in PE, very small
One more ladder on site
Supporters of the antennas
The staircase in the middle of the brackets
Two more joints to make
Done, but some detail is gone
    March 2004
Posted by subfixer on Tuesday, May 24, 2011 3:30 AM
Just to let you know that the "teeth" in the bow are bridle arrestors. Some older aircraft used to require a wire bridle in their launch configuration. The arrestor caught the bridle as it slung the aircraft off of the flight deck. I believe that only one (I may be wrong on that point as I can't remember for sure from the last time I saw her before her present deployment) is retained on the bow presently and is said to be kept to ensure that the Big E remains the longest ship in the US Navy. I think the USS George Washington still has one, too, making her the longest Nimitz class CVN.
    September 2010
Posted by A.M.Jorge on Tuesday, May 24, 2011 7:02 AM
Good explanation. Thanks a lot.
    September 2010
Posted by A.M.Jorge on Friday, May 27, 2011 8:41 AM
After setting up some details, it became clear that it will be necessary to mount the flight deck first, so, then return to smaller parts.  For me, this is the Achilles heel of the model. There are two joints too large and very visible. A bad job now won't be recoverable. In addition, the deck's joints needs to be leveled.
Do not know if it's my pet peeve, but I had already built this model around the year 2000.This new kit seems pretty vague compared to that I assembled the first time. It has some parts that are not cut out for each other. Gaps of more than 1 mm, pieces that do not touch.
The first tip to mount the flight deck is to follow the manual and put the bow first, then part of the stern and, finally, the biggest piece in the middle. It is extremely important to test fit parts before glue anything.
Once test fit is done, it's time to put glue (too much glue!), and join the hull and deck. Should be given the utmost attention to all around because there are many dropouts.
Then you do the same with the centerpiece. But it has a further difficulty: This piece is joining with the other two and are the largest and most visible of all model. Take it easy and caml down.
Let's see the pics:
It's time of more critical of the assembly of this model, which is the assembly of the flight deck.
  The first step is to assemble the metalic structure that will support the deck
Next, mount the arrest cables with nylon line
Pass line through the hole and stretches
 The wire should be stretched to simulate the arrest cable
I dripping a drop of cyanoacrylate (Superglue) at the knot and at the ends
The last step is to cut the line
Make each wire independently, do not try to do both with the same line because it will loose
Final result in part from the stern
 Same thing for the other part: tie, stretch, paste and cut
The centerpiece
Test fitting with the cables already assembled
Note that besides the normal joint space, the pieces are uneven
"Time of the jaguar drink water", getting all the fittings, as with the glue and secure with tape
Fixation with the tapes is very important
Now the most important part, the middle piece with the two
More fixing
The the stern joint, with a small gap that could not take
And  the bow's joining at the time of bonding was almost 1mm uneven and gave me a lot of work to leave a small gap
    March 2004
Posted by subfixer on Friday, May 27, 2011 9:35 PM
"Time of the jaguar drink water"  This is a very intriguing phrase, what does it mean? A pause between major events?
    March 2004
Posted by Mikeym_us on Friday, May 27, 2011 10:24 PM
subfixer
I believe your thinking of either the Nimitz or the Eisenhower as both were built in the late 70's and still embarked the F-4 which used the Bridle.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    September 2005
Posted by warshipguy on Sunday, May 29, 2011 9:40 PM
Wow! I am watching your build with a lot of interest.  I have one of these kits waiting in the wings and I am getting anxious to start it.  Terrific job!
Bill
    September 2010
Posted by A.M.Jorge on Monday, May 30, 2011 7:27 AM
subfixer
It´s an indian expression.
In brazilian ancient times, after 1500's, year of Brazil's "discovery" by portuguese admiral Pedro Álvares Cabral, when the "white people" (portuguese) came to Brazil, the indians watched a lot of them be killed by the onça (Panthera onca - in english I think the better translation is jaguar) because they (the portugueses) came to river margins to pick up water at the same time that the jaguar does. So the jaguar got a free meal.
In other way, the indians knew the jaguar habits and keeped away from the river margins at certain hours of the day.
Here, we use this expression as the "decisive moment", when the things really happen or the eve of the most import events.
That's it.
    September 2010
Posted by A.M.Jorge on Tuesday, May 31, 2011 7:48 AM
Following the assembly, it's time for the elevators. The first one I will make will be the cutted one from de deck.
We will need the cutted piece, the support and the PE part.
We will need the side of this cutted elevator
Now we have all that we need
First, I glued the side part to use it as a guide
The support goes to the right place. A test fit is needed because of the marks between the PE part and the support.
Other pics
In place at the ship
    March 2004
Posted by subfixer on Tuesday, May 31, 2011 10:00 PM
Mikeym_us
 subfixer:
You're right, Mike. And, after checking more recent photos, I realized that only the Enterprise still has bridle arrestors installed.
 Numnutz:
USS Nimitz (CVN-68) at sea near San Diego, CA
Ike:
Vince:
The USS Carl Vinson
Teddy R:
USS Theodore Roosevelt (CVN-71)
Abe:
USS Abraham Lincoln, supporting Operation Southern Watch, 28 November 2002
G-Dub:
USS George Washington participating in a photo exercise with other U.S. Navy and Japan Maritime Self-Defense Force ships at the culmination of ANNUALEX 2008.
And the rest, no arrestors.
    September 2005
Posted by warshipguy on Wednesday, June 1, 2011 8:16 AM
Okay . . . as a career submariner who has never been on the flight deck of a carrier, I hate to show my ignorance!  But, are the surfaces of the elevators really grated like that?
Bill
    March 2004
Posted by subfixer on Wednesday, June 1, 2011 9:40 PM
warshipguy
Bill
Nope! There is a metal skin (not sure if it is steel or aluminum, probably steel) over the entire surface. I was wondering about why this photoetch is trying to replicate. I thought that was to be a thin plastic overlay and that the photoetch was supposed to rplicate the undersurface. I don't recall even being able to see through the tie-down padeyes for that matter.
    September 2009
Posted by Echo210 on Wednesday, June 1, 2011 10:30 PM
From what I have read in the past, Enterprise actually had the grated elevators up until the early 2000's refit.  I beleive that the elevators were designed that way so as to absorb the blast from a nuclear detonation.  feel free to correct me if I am wrong.
    March 2004
Posted by subfixer on Thursday, June 2, 2011 1:44 AM
Well, I have walked the flightdecks of quite a few US carriers over the years, including the Enterprise's and do not recall ever seeing any of the elevators in that configuration, at least in the last 39 years. But early in her career, she did have that type of elevator, it is true. When the change was made had to have been longer than 12 years ago. But if this is the version Mr. Jorge is building, I do not recall.
[edit: After some research, I have determined that the elevators were changed in 1996.]
Here is a picture clearly showing this type of elevator:
    September 2010
Posted by A.M.Jorge on Thursday, June 2, 2011 2:14 PM
CVN-65 grated elevator:
CVN-75  "solid" elevator:
    September 2010
Posted by A.M.Jorge on Thursday, June 2, 2011 2:17 PM
You are right, even being grated you must can't see under.
I will need to redo the elevators.
