Tamiya Big-E - USS Enterprise 1/350
    March 2004
Posted by Mikeym_us on Thursday, September 22, 2011 8:15 PM
You ever thought of just using post it notes to fix overspray just stick it on your stencil and then spray your deck color to fix your little mistake.
A.M.Jorge
Hi. I'm sorry about delay.
White is usually a color that requires some care not to to stay with colors of the base on which is painted. At the most, just use the airbrush. I made a mistake that will cost me more time: I forgot to cover the deck area which was splattered with white. It's almost imperceptible, but it gets ugly.
Material.
http://i.minus.com/ibdEpnDxBSbNl0.jpg
The airstrip.
 http://k.minus.com/jbumlQLpNXiyQx.jpg
"65."
http://i.minus.com/iLWCOdShhYwQv.jpg
The spray of white on the deck gray. I'll have to retouch.
http://i.minus.com/iL0VV6VtnkkzE.jpg
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    September 2006
Posted by raider-hall on Sunday, October 2, 2011 8:37 PM
any updates?
    September 2010
Posted by A.M.Jorge on Monday, October 3, 2011 7:12 AM
Sorry, guys, a lot of job to do.
No enought time to work on Big E.
I will try, at least, remove the tapes and post pictures.
    September 2010
Posted by A.M.Jorge on Monday, October 10, 2011 1:23 PM
Hio guys, I'm here, but not new yet. Still a lot of work to do.
    September 2010
Posted by A.M.Jorge on Monday, October 17, 2011 7:24 AM
Dear friends,
I was wondering, the deck is a little bluish. I'm thinking about remove this grey tone and use black instead.
Regards.
    March 2004
Posted by Mikeym_us on Friday, October 21, 2011 8:16 PM
A.M.Jorge
Dear friends,
Regards.
Try Tamiya Nato Black or White Ensign Flight deck grey.
    September 2010
Posted by A.M.Jorge on Monday, October 24, 2011 6:33 AM
Thanks.
    September 2010
Posted by A.M.Jorge on Monday, October 24, 2011 7:56 AM
I just bought the Tamiya XF-69 NATO black.
While I wait for her arrival, I remove paint from the deck using ethyl alcohol.
Any suggestions?
Thank you.
    March 2004
Posted by Mikeym_us on Monday, October 24, 2011 2:57 PM
What did you paint the deck with in the first place Enamel or acrylic?
    September 2010
Posted by A.M.Jorge on Monday, October 24, 2011 3:01 PM
Hi. I used tamiya acrylic.
    March 2004
Posted by Mikeym_us on Monday, October 24, 2011 3:04 PM
Well I hope you didn't strip the deck yet as you can paint over the German Gray with the Nato Black. Stripping is a bit time consuming and there is always the chance of goofing up the paint job on the hull if your not careful.
A.M.Jorge
Any suggestions?
Thank you.
    September 2010
Posted by A.M.Jorge on Friday, November 4, 2011 8:56 AM
Dear friends,
I'm still on the rush, but at least we have removed the masking tape. I'm wanting to redo the painting for several reasons: it was a bit thick, it is with some risks, I still can not decide whether the color is similar, and, anyway, I'll have to redo because of spray of white paint that has tainted the entire deck.
The white markings also were a little thick, and when removing the tape, they fouled the dark a bit. It would be easier if all the paint used was gloss, but still have a lot of flat paint.
Let's remove the tapes:
See some defects: the most serious is the part that was not masked became whiter.
Top view:
Some defects in the marking of "65" beyond the paint is too thick.
Does it snowed on the left?
    March 2004
Posted by Mikeym_us on Friday, November 4, 2011 2:41 PM
Ok A.M.jorge your first problem is that you didn't mask past where you painted a simple solution is to tape sheets of paper towel to the edges of your paint masks. same goes for the masking tape stencil for the number 65 . Just paint over it with the Nato black and you should be fine and also when doing the stencils for the lines and the number 65 use light coats of paint as it looks like you used a heavy coat on the number 65.
BTW the center line on a aircraft carrier is white and yellow.
A.M.Jorge
Dear friends,
http://farm7.static.flickr.com/6235/6311619645_cd7ea5d9fd_z.jpg
http://farm7.static.flickr.com/6091/6312139930_5504c0925a_z.jpg
Top view:
http://farm7.static.flickr.com/6114/6311619723_3c9d6bb207_z.jpg
http://farm7.static.flickr.com/6057/6312139996_ce04c8e162_z.jpg
http://farm7.static.flickr.com/6231/6311619581_7d0c18a054_z.jpg
http://farm7.static.flickr.com/6221/6311619479_cea2e65357_z.jpg
    September 2010
Posted by A.M.Jorge on Tuesday, November 8, 2011 5:45 AM
See next post.
    September 2010
Posted by A.M.Jorge on Tuesday, November 8, 2011 5:49 AM
Dear friends,
Today I did something never done before: remove the painting. The paint was too thick and the color was not pleasing, so I removed to redo using NATO Black. The process was easier than I imagined. The paint I used was Tamiya acrylic. Regular cleaning alcohol was enough and lots of towel paper. I believe that I have removed the equivalent of 8 ml bottle.
Starting work.
Ten minutes later ...
Twenty minutes later most of the paint has been removed, we now have to be careful with the corners.
Half an hour later, the surface is ready to receive new paint.
Seeing more closely, it seems that was applied a giant wash.
More details.
It is important to avoid the accumulation of paint to prevent future defects. In my opinion it is not necessary to be 100% clean, but surface must be leveled. Despite the care I had to fix some details.
Ready for another paint coat.
Highly flammable material. Soak in water before throwing in the trash.
    September 2010
Posted by A.M.Jorge on Tuesday, November 8, 2011 5:59 AM
"BTW the center line on a aircraft carrier is white and yellow."
OK, I will do it.
    September 2010
Posted by A.M.Jorge on Wednesday, November 9, 2011 7:02 AM
I've started the hull painting. I found some imperfections as pics shows. However, I'm doing some mistake. The paint is still thick and not smooth.
The pics:
    September 2010
Posted by A.M.Jorge on Thursday, November 10, 2011 6:02 AM
Today, the paint dryed and I removed the masks. The water line was well defined and the bottom of the hull is still great looking. However, as already said, the gray part is rough. Thanks to a fellow model, used toilet paper to smooth it. And it worked fine! Just move gently, without force, to not harm the paint. Only one drawback: paper dust spread throughout the model, requiring a subsequent cleaning. Now I only need to hit a few details, but in overall it was good. I'll have to touch up a few more horizontal surfaces, dark gray.
By removing the tape, we see that the painting was good, not blurred, although some details to settle. The shading was a bit dark and had to cover more clear-ink. In a next time, it is best to use a gray instead of black.
Work of "sanding" with toilet paper.
Posted by Tojo72 on Friday, November 11, 2011 7:41 AM
Wow  Jorge,really coming together now,looking good.
    September 2010
Posted by A.M.Jorge on Monday, November 21, 2011 11:30 AM
Dear friends,
Today I removed the masking tapes that were there for almost one year. A lot of painting strips, but easily correctible.
A lot of job to do and time is becoming very short to modeling.
Regards.
    September 2005
Posted by warshipguy on Wednesday, November 23, 2011 9:23 AM
Jorge,
Don't get discouraged!  We all encounter some difficulties when modeling difficult projects.  You are doing a terrific job!
Bill
    September 2006
Posted by raider-hall on Friday, November 25, 2011 7:52 AM
your BigE is looking great. also today is BigE's 50th birthday.
    March 2004
Posted by subfixer on Saturday, November 26, 2011 6:00 AM
The Mobile Chernobyl (also known as the Enterprise) was planned to deploy just one more time prior to her decommissionig in 2013, but it looks like they may squeeze an additional one in after that. She is like the Energizer Bunny.
I'm from the government and I'm here to help.
    March 2004
Posted by Mikeym_us on Saturday, November 26, 2011 8:21 AM
How many times did she almost melt down?
subfixer
http://upload.wikimedia.org/wikipedia/en/thumb/e/e0/Energizer_Bunny.png/220px-Energizer_Bunny.png
    March 2004
Posted by subfixer on Sunday, November 27, 2011 6:10 PM
Mikeym_us
 subfixer:
Never!   But with eight 1950s era reactors and all of the peripheral components associated with them, maintenance is difficult. That nickname is an inside joke among us who are involved with keeping her in good working order.
    September 2010
Posted by A.M.Jorge on Tuesday, December 13, 2011 10:05 AM
Dear friends,
Sorry about the delay, but time is still short.
Regards.
    September 2010
Posted by A.M.Jorge on Tuesday, December 20, 2011 7:53 PM
Today I done two basic tasks, first I painted the PEs trees using the hull color.
Second, I retouched some "hull color" areas. This ones were "sanded" using toilet paper.
Painting the PEs:
Before:
After:
Hull color retouches: good after paint dries.
    September 2010
Posted by A.M.Jorge on Tuesday, December 20, 2011 7:58 PM
The last task before paint the flight deck again, I must paint the catwalk using hull color at "walls" and dark grey over the bottom. Is there an easiest way to do this  ?
Masking ...:
First step is done after more than half hour:
Results after a careful airbrush work:
And after the brush work:
    September 2010
Posted by A.M.Jorge on Wednesday, December 21, 2011 7:44 PM
Dear friends, I decided to start the bridge. I intend to do the basic structure first, and only at the end paste the PEs. Actually it is very difficult to do any assembly without damaging an PE.
Starting the bridge:
You have to look at the manual of the kit and the PEs. In this piece, let's remove a fire hose reel of the bridge.
Just as a test, we will build the stairs and railings in PE. Following the instructions, it is quite easy:
And the result is good, because the fit is very precise:
After an hour ...
    March 2004
Posted by Mikeym_us on Wednesday, December 21, 2011 9:46 PM
Well I noticed with that molded on hose reel you could have made a scratch built reel using the molded on holder minus the molded on reel in the center and just simply substituting a smaller diameter rod as the core of the reel(the bulk is actually made up of the hose itself). Just use a razor saw to slice up the center reel then use a knife to clean it up and then sand it to smooth it out then take your plastic rod (diameter is up to you the builder) and get some tape and cut that into narrow strips the same width (The tape will stand in for flattened fire hose). Take the tape strips and wrap it around the rod till you get a good layer of tape that will at minimum be 2 layers thick  at maximum 4 layers thick. Paint the roll of tape strips white then once dry you could do a wash of black to highlight the edges of the hoses. Paint the reel holders and bulkhead desired color install the finished reel in the center of the holder to maintain a gap between the reel and the bulkhead and behold you have a realistic firehose reel.
BTW I have never done this myself but somehow the idea for this somehow popped into my head a few seconds ago.
A.M.Jorge
http://farm8.staticflickr.com/7156/6551778329_152e4fd8be_z.jpg
http://farm8.staticflickr.com/7035/6551778467_2b25402e6c_z.jpg
http://farm8.staticflickr.com/7006/6551778681_500c778a16_z.jpg
http://farm8.staticflickr.com/7027/6551778767_6a977a86a4_z.jpg
http://farm8.staticflickr.com/7172/6551778851_d6e70649e7_z.jpg
After an hour ...http://farm8.staticflickr.com/7024/6551778575_1016b3248f_z.jpg
