Today was an epic day for model building...I put in around 8 hours...yippy.
The hull is finished and I am finalizing the deck houses and furniture. I tosses the unscale and erronious railing system and began from scratch. I cut out the access door for the main cabin access and built an open one. Now I am adding some scale barrels that will chain lashed to the aft deck house...to induce the feeling of externally stowed stores...sometimes done when the hold was full or namely when a short trip meant them being removed at a later date before the long journey began.
This kit is an earlier version so the detail is very well represented.
Next will be finishing off the main house and I will be changing out the unaccurate boat with one more accurate and better to scale. I will be changing out the short inaccurate galley stove pipe as well.
I found after some patient soaking that the nearly 50 year old water transferes still worked well....just after I trimmed them prior to soaking..so they would fit their locations better.
Well...off till next time......I hope to have some images by then.
Rob
