Revell 1/96 Cutty Sark
    December 2012
Posted by rwiederrich on Wednesday, January 23, 2013 10:25 PM
little larger view of the entire ship
    December 2012
Posted by rwiederrich on Thursday, January 24, 2013 10:20 PM
I finally figured out what to do with my model.  create a diorama..yep.
I built a *ways* from strip redwood..1/8" and mounted and supported the CS...then I decided I would create a ficticious scene where she was getting her gurry rigged rudder replaced...a ficticious scene based on actual events.  I will also make replacement of some copper sheets being depicted as well.
Fun fun fun.
pictures will follow later.
Rob
    September 2010
Posted by madcitydave on Friday, January 25, 2013 7:21 AM
If you need another rudder I will send you one, free.
Dave
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 12:19 PM
Thanks..I appreciate that..but I will be using the rudder that comes with the kit as the replacement rudder in the diorama..........:)
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 6:04 PM
Here are some pics of the CS on its ways for repairs
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 6:05 PM
Some closeups of the bow getting some new copper
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 6:07 PM
Looking down the ways
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 6:08 PM
More closeups of the jurry rudder being replaced
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 6:09 PM
Showing scafold
    December 2012
Posted by rwiederrich on Friday, January 25, 2013 6:12 PM
Top view of scapold and new rudder to be installed
    March 2004
Posted by subfixer on Saturday, January 26, 2013 7:28 AM
Howzabout a ladder so we yardbirds can get up onto the scaffold to do some work??
I'm from the government and I'm here to help.
    December 2012
Posted by rwiederrich on Saturday, January 26, 2013 9:25 AM
Lots of ladders will be added  and wood and tools and stuff..........minor issues....but great details.
Rob(thanks for your fine comments)
    May 2003
Posted by jtilley on Saturday, January 26, 2013 9:35 AM
I'll take the liberty of making a small suggestion.  (I wouldn't do it if it wasn't an easy fix.)  The rudder pintles and gudgeons on a copper- (or Muntz metal-) sheathed ship can't be made out of iron.  When iron and copper (or Muntz metal) are put in contact with each other and submerged in salt water, galvanic corrosion takes place and the copper dissolves.  Pintles and gudgeons on such ships have to be cast from either copper or bronze.  (I don't know whether Muntz metal can be cast into such shapes or not; I guess it probably can.)
Shipwrights made this discovery in the early days of copper sheathing.  They nailed the sheathing plates in place with iron nails.  After a few months the sheathing plates started to fall off, because corrosion had eaten away the material adjacent to the nails.  From then on, shipwrights used copper spikes for the purpose.
So the pintles and gudgeons should be the same color as the surrounding sheathing - not black.
    December 2012
Posted by rwiederrich on Saturday, January 26, 2013 10:16 AM
Thanks for the fine observation...I know about the disimilar metal issue..but chose(through license) to paInt the pintles nd gudgeons black...a detail most will never be aware of and less familiar with the metal issue.   Thanks a lot.
    December 2012
Posted by rwiederrich on Saturday, January 26, 2013 10:17 AM
I enjoyed building the ways and detailing them along with weathering them.....I had fun.  I think it looks good too.
Rob
Posted by Big Jake on Sunday, January 27, 2013 7:23 AM
Nice to see the depliction of the busted rudder event.  Can you imagine doing that at sea with the weight and seas running? Wooden ships - Iron Men
    December 2012
Posted by rwiederrich on Sunday, January 27, 2013 10:22 AM
I agree.........much happened to the CS...so I wanted to depict one instance.....the most memorable
    December 2012
Posted by rwiederrich on Sunday, January 27, 2013 1:27 PM
I did further research and I will wash over the pintles and gudgeons with a green/brown wash to discuise them as bronze.  Thanks for the *clue*.
Rob
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:25 AM
Some more work.  I added some details...like a ladder
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:27 AM
And repair tools and parts
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:28 AM
Finished the bow railing
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:32 AM
I worked in the jury rudder control..which was done via outboard blocks and rope/chain attached to the rudder.  This side is still intack and tide off at the ways........
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:34 AM
You can see the outrigged set up a bit clearer in this image.
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:37 AM
one from the bow.......a wood gang is present on the port side just at the prow.
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:40 AM
Little closer image of the work on the rudder and the tools and parts
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 11:48 AM
I also added a barrel of copper nails for the copper sheets
Posted by Big Jake on Tuesday, January 29, 2013 9:58 PM
damn that looks neat!
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 10:51 PM
I added a portable foundry and a portable anvil with hammer...they had to heat and pound the metal components on site.
    December 2012
Posted by rwiederrich on Tuesday, January 29, 2013 10:53 PM
one from atop.
    May 2006
Posted by Shipwreck on Wednesday, January 30, 2013 6:03 AM
That is beautiful work madcitydave. The 1872 photo of CS in drydock for the new rudder shows that she has crosed the Atlantic a few times. Do you plan on weathering your model?
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5-2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
