Revell 1/96 Cutty Sark
    December 2012
Posted by rwiederrich on Wednesday, February 6, 2013 4:53 PM
Closeup across the deck.......
Now two more masts to go..then the top mast and top gallant stays.......fun fun fun...
    December 2012
Posted by rwiederrich on Thursday, February 7, 2013 10:24 PM
Main mast shrouds rigged
    December 2012
Posted by rwiederrich on Thursday, February 7, 2013 10:26 PM
Wider view
    December 2012
Posted by rwiederrich on Thursday, February 7, 2013 10:27 PM
Wider even still
    September 2010
Posted by madcitydave on Friday, February 8, 2013 7:55 AM
Hi Rob, is each foot rope tied around each shroud or are the ends tied and the interior intersections just glued?  This is a much better system than making each assembly in a jig.
    December 2012
Posted by rwiederrich on Saturday, February 9, 2013 4:32 PM
Well I use many methods..and yes I have used that one in tying the ratlines..but in this case I simply cut small lengths of ratline thread and then apply wood glue in the appropriate places on the shrouds and by grabbing the ratlines by each end press them into the glue on the shrouds and roll the ratline till it is incorporated into the glue..stretch it a bit to align it then let it dry.  I move along quite quickly.  Once to the top I then cut all excess line off of each ratline end with a sharp surgical knife blade.  Done...and it moves along very quickly and is very clean and looks nice too..You have to know where you can skip tedious tasks...and tying every knot is tedious.
I'm working the mizzen mast today.  Main's done. :)
    December 2012
Posted by rwiederrich on Monday, February 11, 2013 8:42 PM
Mizzen main shrouds done
    December 2012
Posted by rwiederrich on Monday, February 11, 2013 8:44 PM
Closeup of the tops
    December 2012
Posted by rwiederrich on Monday, February 11, 2013 8:46 PM
Finished the main shrouds and ratlines..........now a break and then onto the stays and their rigging
    March 2004
Posted by subfixer on Wednesday, February 13, 2013 8:24 AM
That is really looking good, Rob. You deserve a break.
I'm from the government and I'm here to help.
    December 2012
Posted by rwiederrich on Wednesday, February 13, 2013 12:46 PM
Break's over.   Now onto the jibboom and more stays.......Opting to NOT use the kits ratlines means all the rigging for the lanyards and shrouds needs to be done by hand.  This makes the model more realistic and believable IMV.......thanks for the fine comments.....
Rob
    December 2012
Posted by rwiederrich on Wednesday, February 13, 2013 8:27 PM
Working on the head rear rigging.  bowsprit shrouds and bobstays.
    December 2012
Posted by rwiederrich on Thursday, February 14, 2013 9:19 PM
Head gear is rigged..here are some pics
    December 2012
Posted by rwiederrich on Thursday, February 14, 2013 9:21 PM
Another angle
    December 2012
Posted by rwiederrich on Thursday, February 14, 2013 9:23 PM
top view
    December 2012
Posted by rwiederrich on Thursday, February 14, 2013 9:25 PM
Feel like I'm  right down by the dry dock
    December 2012
Posted by rwiederrich on Thursday, February 14, 2013 9:32 PM
Final image of the head gear finished, jib boom finished...now onto the stays...since I needed to finish the jib stays to get the angle of the mast for the backstays.
Posted by Big Jake on Sunday, February 17, 2013 8:18 AM
I always did like the headgear rigging of the CS.The lines,angles and design always seemed like the epitomy of "nauticle".  I have a water and heat damaged CS that I cut the bow section from and am making a fore section only modelmainly becasue of the setup.
    December 2010
Posted by 1943Mike on Sunday, February 17, 2013 2:06 PM
Rob and all you CS experts out there:
I'm working on my CS again (inspired by Rob's masterful work!) and do NOT understand how the anchor chains are placed according to the Revell plans. Unfortunately I've already installed the parts involved so it's too late for me to change them now but I just don't think it's possible that a working ship would have their anchor chains rubbing along the rim of a hatch! I would imagine that the wood of the hatch (assuming it's wood) would be worn away rather quickly.
The next CS I build (should I live long enough) will have the two covers for the outlets of the anchor chain placed farther apart so that the chain clears the edges of the hatch.
If I had not drilled holes for the chain in the deck I might attempt to reposition the two "covers" but, as it stands, it would be beyond my ability to fill the holes in any realistic way.
I did use the anchor chain from another kit to run both chains through the deck in holes I'd drilled under the forecastle and used wire to grab them and pull them through the holes on the hull for the chain.
Has anyone seen the actual arrangement on the Cutty Sark as she is now?
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 3:01 PM
Yes...I agree..the chain tunnels are far to close to the forward hatch....then again, the hatch cover may be too large itself on the model.  Only the CS purists will find restless nights because of it.  I'm glad to hear my efforts have encouraged you to begin your CS model.  :)
I finished the top shrouds/lanyards/deadeyes and rigging for the mainmast.  I am also adding all the blocks to the mast head with wire hooks...replicating the originals.
Post some images of your efforts if you can......:)
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 3:19 PM
The CS head gear is impressive and sleek .  Here is a B/W image of the jibboom rig.
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 3:22 PM
The only historical image I have of the forward area of the forward hatch is of the Ferreira.
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 3:48 PM
I plan on(when I'm finished with this kit), to then build the Ferreira from the Revell CS kit......that will be fun.
    December 2010
Posted by 1943Mike on Sunday, February 17, 2013 4:46 PM
Rob,
I'm a horrible modeler!Embarrassed But I have FUN doing this!!!Big Smile I'm too embarrassed to post pictures directly but I'll add some links to my pictures of where the CS stands with me now.
I try hard but I still end up with a terrible paint job (I'll get better - I hope), some gouges in the bow, and many, many small but irritating mistakes. I believe I'm doing slightly better than when I built the Connie two years ago, but I still need to build a dozen or so models before my skills improve to the point where I might have the courage to post a bulld log.
For what they're worth:
http://michaels.0catch.com/_2170001.jpg
http://michaels.0catch.com/_2170006.jpg
http://michaels.0catch.com/_2170002.jpg
http://michaels.0catch.com/_2170008.jpg
http://michaels.0catch.com/_2170009.jpg
Hector Berlioz
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 5:28 PM
Are you kidding me...that is not bad at all...not at all.  You are working on your technique...and it is technique that helps distinguish a good modeler from someone who just throws them together..for the sake of getting it done.
If I may.....can I offer a few suggestions?
One..never tear parts from the runners..always cut them off with ample left overs..so you can cleanly hand trim and sand the sprue clean...leaving no sign,
Only remove the parts you need at the time and cut away excess sprue so they do not clog your work area.
Try masking...especially when painting along long lines or up against 90 deg angles.  I use a roll of fine painters blue tape...I cut with a hobby knife a thin strip all the way around the roll....allowing me to have a nice narrow strip I can roll out as much as I need.  Then you can mask in tight spaces..giving you those crist paint lines.
Here is one more..just for fun.  On many wooden ship models..they come in molded brown..but the hull needs to be a darker or lighter brown...don't bother painting the highlighted areas...simply draw your hobby knofe across the raised area..removing the paint and revealing the other color......sharp..looking and very easily done.  It can be messy...but paint dust is easy to deal with..then squigly over painted areas.
With these simple techniques in hand..you can master even the toughest paint job...:)
Rob
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 5:33 PM
One more trip....especially with sailing ship models...you have to think like a chess player...many moves ahead..so you are not having to rig in tight places or trying to add detail after the fact..It's easier to add those blocks now then when you have a web of rigging to work through........
I hope I  have been of some assistance......you're coming along and doing great....keep it up.
    December 2012
Posted by rwiederrich on Sunday, February 17, 2013 5:44 PM
I can assure you my build is far from perfect.....loads of mistakes and blunders.
    December 2010
Posted by 1943Mike on Sunday, February 17, 2013 6:58 PM
Rob,
Thanks for the suggestions. I did try to mask the rub rail but paint got under it anyway. I guess I'll have to be more careful about making sure the tape is nice and snug against whatever I plan to paint in the future.
As to planning ahead, I will do my best. I was soooo frustrated when I rigged the Connie - tweezers in both hands, standing over the masts, trying to see where I should put this line or that through the shrouds...a real challenge. This time I will TRY to plan ahead.
Anyway, your build continues to inspire me. Thank you.
Hector Berlioz
    September 2010
Posted by madcitydave on Sunday, February 17, 2013 7:21 PM
Mike:  For the white rub rails spray the general area white then apply Tamiya masking tape over the rails and smooth it down tight against the hull using round tooth picks.   Then simply run a sharp  #11 blade along each juncture of the rub rail and the hull.  Peel off the tape that remains against the hull and then again smooth down the edges with a toothpick. You can then spray the hull color and will have a very sharp rub rail line when you remove the tape.
    December 2010
Posted by 1943Mike on Sunday, February 17, 2013 7:42 PM
Dave, Thanks for that. Next time I'll try it that way.
Hector Berlioz
