Battle ship builds
    July 2006
Battle ship builds
Posted by constructor on Monday, May 18, 2015 11:48 PM
My Pontos blue deck is arriving in a week and I want to start my Missouri built. I want to find out from those who had experience in using this decks what is the proper procedure and the order of the build. Do I attach the deck first or the painting of the superstructure and the PEs and others others, etc...
    September 2012
Posted by GMorrison on Monday, May 18, 2015 11:53 PM
No experience with that deck on that model, but...
You know the drill. You just need to figure out what makes the most use of your skills. In general I would put the deck down last.
Funny thing, my ships usually go back-and-forth, back-and -forth. They take forever, but it's all in the execution, right?
In other words, I doubt it much matters- there's no certain Fubar.
    July 2008
Posted by jeffpez on Tuesday, May 19, 2015 7:50 AM
In the couple of builds I've done with Pontos decks I've installed them after painting the hull and adding the decks but before the smaller pieces like P/E parts. It's simply too difficult to fit the decks while working around small parts. Larger pieces can be done first. Start building and think it thru and you'll be fine.
    July 2014
Posted by modelcrazy on Tuesday, May 19, 2015 8:01 AM
I agree with the above. I've never worked with AM decks, but it would seem to me that you just have to "feel it out". Ships are an interesting breed when it comes to building them. Sometimes it makes sense to do a thing first on one kit and something else first on another. Having built the Tamiya Missouri, I would think installing the deck right after painting the hull and before installation of anything else would make sense , although I would think you would need to pre fit it first. I know...duh... right?
Steve
Steve
Posted by Don Stauffer on Tuesday, May 19, 2015 8:58 AM
I used a Pontos deck on my Olympia, and put it on after finishing the hull, but before putting on any superstructure or PE. I built up the superstructure as subassemblies, added each subassembly when complete, added main deck PE last.  PE on superstructure went on as last step in each superstructure.
    September 2013
Posted by Marcus McBean on Tuesday, May 19, 2015 9:03 AM
I agree with Don, put the deck on before adding the superstructure and all the deck pieces.
    September 2005
Posted by warshipguy on Tuesday, May 19, 2015 12:13 PM
I built my 1/350 Missouri using the Artwox blue deck. I added it before the superstructure and have had no difficulties with lifting or warping at all.  It fit well and the adhesive backing is effective. I recommend them.
Bill
    August 2008
Posted by tankerbuilder on Friday, May 22, 2015 7:58 AM
I definitely agree here , Don . I have NEVER put a deck on after doing any detailing . In any size !
