No Joke...
    April 2012
No Joke...
Posted by pianodog on Saturday, June 27, 2015 4:46 PM
This is an honest question,
I purchase this little cute MInion figures made of resin, can I use my regular Model master Liquid Cement For Plastic Models type of glue? Thank you all for your answers.
On The Bench:
Hasegawa Egg Plane F14 Tomcat
Moebius Penguin
Moebius Robin
Meng WWT-001 Tiger I
Meng WWT-002 Sherman
    September 2012
Posted by GMorrison on Saturday, June 27, 2015 4:58 PM
No. Resin glues with CA (superglue).
    April 2012
Posted by pianodog on Saturday, June 27, 2015 4:59 PM
GMorrison, do you have any particular brand?
Thanks for your answer by the way,...
On The Bench:
Moebius Penguin
Moebius Robin
    September 2012
Posted by GMorrison on Saturday, June 27, 2015 5:05 PM
I prefer the gel to the runny stuff just because I tend to not glue my fingers together so much, seriously. But it sets slowly.
For gel I use stuff called zap-a-gap, or more recently Locktite makes a good one in a neat little bottle that has these kind of squeeze pads on the side. The advantage there is that if you point the end downwards, the whole bottle doesn't run out.
For thin stuff I use anything. I actually like the little tiny tubes that come in multipacks. The stuff dries up anyways, so why have a big bottle go hard.
Like any glue, it's better to squirt it out on something like a piece of tape and apply with a toothpick, rather than aim it at the model.
Those are just my preferences though.
Good luck!
Posted by Don Stauffer on Sunday, June 28, 2015 11:29 AM
I also like the gel- it sets a bit slower and gives me a bit more time for getting the piece in the right location. I really like Loctite brand- about the best gel brand I have tried. I have begun using their thin stuff now too.
    August 2008
Posted by tankerbuilder on Sunday, June 28, 2015 3:16 PM
Ditto !
But for normal use I prefer the  BSI product out of Atascadero , Ca.
    July 2014
Posted by modelcrazy on Sunday, June 28, 2015 3:48 PM
BSI,BSI yea! (Bob Smith Industries pianodog). It sells in most hobby shops (with a label under the shops name usually), or you can get it off the internet. I also use the gel and just a drop of accelerator when I have the part where I want it.
Steve
Steve
    April 2012
Posted by pianodog on Monday, June 29, 2015 11:06 AM
Thank you so much guys, listen I found the BSI but they have several products, do you mind telling me which one out of them is the one you like? Thank you again.
On The Bench:
Moebius Penguin
Moebius Robin
    July 2014
Posted by modelcrazy on Monday, June 29, 2015 11:45 AM
From what I remember, they have thick, medium and thin. They also have a gold label which doesn't off gas, or at least very little, which is good for clear plastics. I used that once with good results, but now I use Mod Podge for clear plastic.
I will typically use the medium for assembly and use the thin if I want capillary action along seams. I will use all three consistencies for wood builds. You can also use the med and thick for filling, but it's a bugger to sand, so I only do that if I am confidant I can place a bead which probably won't need sanding.
For resins, I use their standard mix, medium or thin.
I hope that helps.
Steve
Steve
    August 2008
Posted by tankerbuilder on Tuesday, June 30, 2015 10:11 AM
I use the " Maxi-Cure " Red "
    November 2008
Posted by plasticjunkie on Friday, July 3, 2015 8:16 PM
The Dollar stores sells the small tubes in 3 viscosities and works great.
 GIFMaker.org_jy_Ayj_O
    April 2006
Posted by waynec on Saturday, July 4, 2015 10:28 PM
you might try the KRAZY glue with a brush on applicator. i get mine at ACE Hardware.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    August 2013
Posted by Jay Jay on Sunday, July 5, 2015 8:52 AM
To Waynec;
Funny you mentioned the Crazy Glue.  When I first started using CA on models,  i happened to have a bottle of crazy glue on hand so i used that.  I have since tried all the other stuff and found that the Crazy glue turned out to be my go to brand .  I really like the one with the brush in it as it is very convienient to use.  I usually trim down the brush so i can get smaller drops in tighter places with it as well.
    November 2008
Posted by plasticjunkie on Tuesday, July 7, 2015 3:50 PM
LOL. Every time I hear about Crazy Glue  I think of the guy hanging from his hardhat glued to a beam!
www.youtube.com/watch
    December 2013
Posted by CodyJ on Wednesday, July 8, 2015 6:05 PM
Yup I use BSI medium.   Just a medium-thick superglue
    April 2006
Posted by waynec on Thursday, July 9, 2015 10:35 PM
plasticjunkie
me too
    April 2012
Posted by pianodog on Thursday, July 9, 2015 10:55 PM
Want to hear something interesting I was part of the production of that commercial more than 25 years a go... wow time really goes by quickly.
Thank you all for the great comments.
On The Bench:
Moebius Penguin
Moebius Robin
