temp glue
    March 2016
temp glue
Posted by ardvark002 on Saturday, June 11, 2016 9:16 PM
hi all.  I known i've seen reference to tempory hold glue in reply to a question, but I can't find it. I sure would appericate it if someone could tell me where I could obtain some,or who makes it. thanks much.   aardvark
    July 2013
Posted by modelmaker66 on Sunday, June 12, 2016 1:25 AM
Hi!
I thought Micro Inustries made a temporary adhesive not long ago. They make micro sol. I checked but they dont make it now. You could use white glue like elmers. It could be made temporary and just peel the residue away or use water.
Posted by Don Stauffer on Sunday, June 12, 2016 12:40 PM
I sometimes use a small bit of blue tack (poster tack) to temporarily hold parts together.  I use it a lot for things like holding gear doors in while painting (I only permanently glue gear itself in place after all painting is done.  The blue tack keeps the paint out of the gear wells while I paint, yet lets me paint gear doors bottom color.
    March 2016
Posted by ardvark002 on Sunday, June 12, 2016 6:37 PM
thanks Don, I thought that if anyone would it would probably be the one. You have always responded to my posts, appreciate it . You put out alot of great info, have used much. Many great builds , got me workin on some new kits.thanks again aardvark
    January 2013
Posted by seastallion53 on Tuesday, June 14, 2016 8:17 PM
There is Formula 560 canopy glue.It is a sort of white glue with a better bond that can be pulled apart easily.
cml
    March 2007
Posted by cml on Thursday, June 16, 2016 6:50 PM
I normally use a small amount of Maskol whenever i need temporary adhesion.  Once it's set, it holds fairly well.
I've used it to hold things like tools etc in place whilst sparying armour, then just pull off and scrape it away.
Chris
Posted by Don Stauffer on Friday, June 17, 2016 9:17 AM
I have used CA debonder when I made mistakes gluing on a piece before I should have.  The stuff works fine.  I have not actually used it as a temporary glue, but I don't see why CA and debonder wouldn't work as a temporary glue.
